screwing with pirates
209 replies to this topic
#1 2600problems OFFLINE
2600problems
    Chopper Commander
  • 234 posts
Posted Tue Mar 28, 2017 6:04 PM
I've decided that the best way to fuck with pirates is to password protect the games that I make. so here's a small snippet of my code:
10 print "are you a pirate"
20 input a$
30 print "hello, my name is c64..., please give password
40 input a$
50 if a$=  1000 to 9000  (or brute forced) goto 80
60 if a$= 8145 or 99872 goto 90
70 goto 80
80 (loops)
90 (unlocks computer)
what I want to do is separate them into 2 different code batches. 1 to protect any games I make or upload to this site
2. to unlock it if needed. (I trust those I give the password to will not spread it over the internet)
currently in alpha stage
#2 fujidude OFFLINE
fujidude
  • 4,972 posts
Posted Tue Mar 28, 2017 9:43 PM
I'm (rather atypically) at a loss for words here at this moment.  :?:
#3 pirx OFFLINE
pirx
    Moonsweeper
  • 423 posts
Posted Wed Mar 29, 2017 1:40 AM
bloody pirates!!!
#4 Goochman OFFLINE
Goochman
  • 6,906 posts
  • Moongates to the Past
Posted Wed Mar 29, 2017 5:54 AM
Edited by Goochman, Wed Mar 29, 2017 5:54 AM.
#5 Rybags OFFLINE
Rybags
  • 15,627 posts
Posted Wed Mar 29, 2017 6:00 AM
If the password is in the program it'll be found in no time.  If you do fancy encryption it'll take seconds/minutes longer.
In the modern day, emulation and debugging means you can't hide much at all.
The way to go with a password would be to encrypt most of the program then have the password actually form most of the decryption key.
By doing that, it's not discoverable by any other way than actually getting it right.
Then again, brute force password hacking is easy with fast modern CPUs.
#6 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,730 posts
Posted Wed Mar 29, 2017 6:18 AM
Exactly who is supposed to be pirating Atari Basic programs these days?
#7 Stewart_Pidd OFFLINE
Stewart_Pidd
    Star Raider
  • 51 posts
Posted Wed Mar 29, 2017 6:49 AM
Who would have known that my plans for world domination would be thwarted by a password subroutine in basic?
#8 zzip OFFLINE
zzip
  • 2,424 posts
Posted Wed Mar 29, 2017 8:03 AM
20 input a$
40 input a$
70 goto 80
80 (loops)
Add these lines for additional protection:
5 print "Please pry off the Break key with a screwdriver before continuing, then press any key to continue"
6 input $a
#9 Stephen OFFLINE
Stephen
  • 7,003 posts
  • A8 Gear Head
Posted Wed Mar 29, 2017 9:00 AM
I wouldn't worry too much about a strong password generator.  It's getting that damn pesky PEEK command in C64 BASIC to work.
#10 MrFish OFFLINE
MrFish
  • 4,809 posts
Posted Wed Mar 29, 2017 9:25 AM
Excellent, now you're down to only 2,599 problems!
Edited by MrFish, Wed Mar 29, 2017 10:16 AM.
#11 MrFish OFFLINE
MrFish
  • 4,809 posts
Posted Wed Mar 29, 2017 9:26 AM
6 input $a
Come on man, he's still in the "alpha" stage...
#12 tep392 OFFLINE
tep392
  • 3,045 posts
Posted Wed Mar 29, 2017 11:40 AM
It might help if you add this.
5 REM IGNORE THE NEXT TEN LINES OF CODE. NOTHING TO SEE HERE.
#13 Stephen OFFLINE
Stephen
  • 7,003 posts
  • A8 Gear Head
Posted Wed Mar 29, 2017 12:31 PM
Perhaps it would be better to distribute the games to trusted individuals, if you get the source printed at Kinkos.
#14 CharlieChaplin OFFLINE
CharlieChaplin
  • 2,818 posts
Posted Wed Mar 29, 2017 12:37 PM
Control-3
Error 136
L.
#15 2600problems OFFLINE
2600problems
    Chopper Commander
  • 234 posts
Posted Wed Mar 29, 2017 2:19 PM
great answers, i'm laughing so hard right now
#16 2600problems OFFLINE
2600problems
    Chopper Commander
  • 234 posts
Posted Wed Mar 29, 2017 2:22 PM
I also did this for the BBC micro:
10 print "are you a dick?"
20 input a$
30 rem yes or no doesn't matter
40 if a$= "yes" goto 50
50 print "shutting down"
60 print "good, shutting down"
#17 Kyle22 OFFLINE
Kyle22
  • 3,301 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Wed Mar 29, 2017 7:29 PM
Control-3
Error 136
L.
This actually worked for me on a particularly difficult BASIC program.  It shall remain nameless because of how I "re-used" some of the code I was able to unprotect.
It was a combination of rapid fire hitting break and Ctrl-3 and pressing System Reset here and there, but I finally got a READY prompt.  This disk had no DOS, it booted directly to the BASIC program, and all disk I/O was handled by the program.
Once I got READY, I had to save it, but no DOS was booted.  I had to use C:.  What a pain, but it worked.  Booted a DOS disk, loaded from C: then saved to D:
#18 TMR ONLINE
TMR
  • 3,410 posts
  • Beeping the horn on the data bus
Posted Thu Mar 30, 2017 3:05 AM
What stops the pirates from simply viewing the BASIC listing and spotting the password or removing the "protection"? There's nothing you can do as a BASIC programmer to obfuscate your program that a cracker - someone who usually has a lot of "in the field" machine code knowledge - can't undo and even if the program is compiled it doesn't take much picking around for someone with that skillset to find the password.
The bigger question that springs to mind though is why would you bother in the first place?! Even something that'd put up a fight from assembly language is pretty pointless because one password leak or weak algorythm later and everything is undone.
#19 fujidude OFFLINE
fujidude
  • 4,972 posts
Posted Thu Mar 30, 2017 9:25 AM
Guys.... um let's just indulge the enthusiasm without bothering with the wider scope of it  all.  I'm pretty sure there's a reason for it all.
#20 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 8,907 posts
Posted Thu Mar 30, 2017 9:57 AM
Actually, I wouldn't mind having something that I could check to make sure my game is running on actual AtariAge boards.  Be it 2600, 5200 or 7800.
#21 zzip OFFLINE
zzip
  • 2,424 posts
Posted Thu Mar 30, 2017 11:18 AM
I don't think OP was actually serious, read his followups
#22 TMR ONLINE
TMR
  • 3,410 posts
Posted Thu Mar 30, 2017 11:42 AM
Okay, so who fancies explaining the reason behind "screwing with pirates" then...? Enthusiasm is fantastic, but piling all of that energy into something like this is akin to driving up a cul-de-sac in a rocket-powered car, it's going to end messily...
#23 fujidude OFFLINE
fujidude
  • 4,972 posts
Posted Thu Mar 30, 2017 4:08 PM
Okay... I'll just get it over with.  The OP has either started a humorous exercise in futility, or he's suffering from some kind of mental affliction.  In the 1st case, there's not much fun in pointing out the futility, as that kills the joke/humor.  In the second case, it's best not to tear down his grand ideas as he enthusiastically explores programming an Atari 8-bit, less he have some kind of mental episode or psychotic break.  ;-)
  • jhd likes this
#24 TMR ONLINE
TMR
  • 3,410 posts
Posted Fri Mar 31, 2017 3:34 AM
Assuming there was something to kill in the first place...
If he's losing the plot that's going to happen sooner or later anyway, probably around the time he tries to use players from BASIC. But okay, i won't bother responding to his posts any more because i'm not going to waste time working out if he's being serious or not.
#25 flashjazzcat OFFLINE
flashjazzcat
  • 13,480 posts
Posted Fri Mar 31, 2017 4:43 AM
It becomes clear why [sarcasm] and [irony] tags are always required on Internet forums.
