gfreige Posted April 27, 2017 Share Posted April 27, 2017 What's the Ti/99's version of the SD2IEC like for the Commodore? Also soldering joystick jacks is quite annoying. Could you folks help me decipher the plans for the Adapter. It doesn't look like it matches up with the Atari joystick standard.. the male plugs seem... backwards? http://www.mainbyte.com/ti99/hardware/cables/joystick.html Lotharek HxC. It´s actually an SD based floppy drive emulator for any device using standard Shugart interface (as the TI, or the PC). You need a PEB and a Floppy Drive Controller Card too. Another option is a NanoPEB (if you can find one). It's a CF based floppy drive emulator/32K expansion combo sidecar unit. 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted April 28, 2017 Share Posted April 28, 2017 (edited) What's the Ti/99's version of the SD2IEC like for the Commodore? Also soldering joystick jacks is quite annoying. Could you folks help me decipher the plans for the Adapter. It doesn't look like it matches up with the Atari joystick standard.. the male plugs seem... backwards? http://www.mainbyte.com/ti99/hardware/cables/joystick.html the diagram is correct, two male one female connector. I sell these assembled and also just a pcb here: https://www.arcadeshopper.com/wp/?page_id=11#!/Joysticks-and-adapters/c/21773047 Edited April 28, 2017 by arcadeshopper 1 Quote Link to comment Share on other sites More sharing options...
