Can someone explain pointers to me?
25 replies to this topic
#1 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sat Apr 1, 2017 10:38 PM
...and how they're used for animated sprites?
I've looked at multiple examples and it still makes no sense.
#2 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sat Apr 1, 2017 10:53 PM
I honestly have no idea what language you're talking about, but having a general knowledge of what pointers are can go a long way.
In short, you use pointers to access addresses in memory. This is useful if you want to read side-by-side variables with really efficient code.
For example, if I wanted to animate an 8x8 sprite, I would first set up each frame sequentially (following the first frame). To animate, you would set the pointer to the address of the first frame, and then add 8 to the pointer to go to the next frame, and so on.
I'm pretty sure you've heard that before, so what's causing trouble for you?
#3 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sat Apr 1, 2017 11:01 PM
Sorry, 6502 Assembly
I've been trying to do this but I'm having trouble with it.
I'm confused about the whole high and low pointers thing and how to animate a sprite.  I guess I don't understand it enough.  Any links/resources I could check out?
#4 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sat Apr 1, 2017 11:20 PM
Random Terrain's Page is a good source for almost all 2600 programming, along with the 6502 Opcodes List. And you can always ask me :)
There are multiple ways to accomplish this. The most efficient way would be to use the X register as a pointer to go through the frames. Just read the row by LDA row_foo,X and add 8 to the X register as often as needed
You won't need to do it any other way for sprites but for maps it can be really handy to store an address in memory and go off that address. These are "true" pointers, and work by storing the entire address of a variable (say my map is at 0xF000) in ram. To access the data pointed to by them you would use an opcode like LDA (foo_pointer)
Finally, I'll try to explain the high and low bytes. An absolute address on the 6502 is two bytes long. The high byte is equivalent to the 1 in 10, while the low byte is equivalent to the 0. On big endian machines, the high byte comes first, and on little endian it's the opposite. The 6502 is big endian the last time I checked, but I'm probably wrong so it wouldn't hurt to check yourself
#5 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sat Apr 1, 2017 11:35 PM
I've actually been using those exact links lol
They've been very helpful so far.
I try to be as self-sufficient as I can, but sometimes I can't figure something out.
Thanks!
I don't get it.  What do you mean by "comes first"?
Edited by Electrk, Sat Apr 1, 2017 11:35 PM.
#6 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sat Apr 1, 2017 11:40 PM
Comes first in RAM. Let's say you have the number 256 (0x100 in hex). You store it in a big endian machine, and in memory it looks like the bytes 0x01 0x00.  On a little endian, it looks like 0x00 0x01.
#7 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sat Apr 1, 2017 11:48 PM
How does that affect programming?
#8 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sat Apr 1, 2017 11:51 PM
If you wish to write an address manually, it helps to know which order to put the bytes in. Other than that, I don't know. It's just a piece of trivia more or less
#9 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sat Apr 1, 2017 11:53 PM
What's the < and > stuff then?
#10 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sat Apr 1, 2017 11:56 PM
I've never hear of it
#11 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sat Apr 1, 2017 11:58 PM
This stuff
#12 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sun Apr 2, 2017 12:01 AM
This stuff
That's if you want to grab the high byte or the low byte of a 16 bit address (following the rules given in the previous post). The > presumably meaning the low byte and the < the high byte
#13 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sun Apr 2, 2017 12:03 AM
I guess I just don't understand why it's used/what it's useful for
#14 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sun Apr 2, 2017 12:12 AM
It's kinda useless compared to other methods for sure, but if your sprite is at address 0xF000 you could keep the high byte(0xF0) and increment the low byte
Edited by Gip-Gip, Sun Apr 2, 2017 12:12 AM.
#15 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sun Apr 2, 2017 12:19 AM
I'm really not getting this, sorry.  I'll just have to read more, I guess.
My problem has been solved though as I got sprite animation to work.  Thank you!
#16 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sun Apr 2, 2017 12:21 AM
No problem. It took me a while too; it isn't that easy to learn entirely new concepts. Hope everything works out!
#17 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sun Apr 2, 2017 4:27 AM
When you see < and >, you are seeing the 8 bit 6502 handle a 16 bit number.  Think of it like our use of  comma when writing a big number- like 65,536.  Telling the machine to LDA <... and LDA >... would be like saying fetch the 536 and then fetch the 65 from the above number.  Note- since we only use binary, 65,536 is really 11111111,11111111.  So that's 16 1s.  We fetch 8 at a time to move the whole number.
In your case, you are fetching a memory address, those are 16 bits so you have to do it this way.
#18 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Sun Apr 2, 2017 4:51 AM
Pointers are used because the Atari's graphics are done one line at a time.
For example, if your sprite starts at line 100 of the screen, you would set your pointer 100 places above your graphics in the code.  The code in that location is useless to you and is not used.  The goal is to just start counting from there.  So when your kernel reaches line 100, your pointer has also moved 100 places to the exact starting point of the graphics you want on the screen.  Then at line 101, the pointer is on the second line of your graphics, and so on.
#19 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sun Apr 2, 2017 2:18 PM
This is a great explanation!  It makes a lot more sense now.  Thank you!
Edited by Electrk, Mon Apr 3, 2017 3:39 PM.
#20 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 11,881 posts
  • Medieval Mayhem
Posted Sun Apr 2, 2017 5:33 PM
Have you worked through my Collect tutorial?  Do note the blog shows newest first, so start at the bottom of page 2.
In short pointers point at things.  In computers they point to memory.  Consider this bit of code:
lda #7
lda $7
The two instructions look very similar, but do different things. The first takes the value of 7 and puts it in the accumulator.  In the second instruction the number points to where the value is - and the value found there is what ends up in the accumulator (on the 2600 that'd be TIA register CXPPMM).  So that second LDA is using a pointer.  In this case it's a fixed pointer because it always points to the same place.
To make things more interesting, you can add the X or Y register into the mix like this:
ldx #1
ldy #2
lda $F800,x
lda $F800,y
; location $F800
.byte $00, $05, $0a, $0f, ...
So in this example we take the pointer, add X or Y to the pointer to get a new pointer, then go there to find the data.  The lda $F800,x would end up going to $F801 and put the $05 it finds there into the accumulator.  The lda $F800,y would go to $F802 so the accumulator ends up with $0f.  Adding labels makes the code clearer:
ldx #1
ldy #2
lda Times5,x
lda Times5,y
; location $F800
Times5:  .byte $00, $05, $0a, $0f, ...
Using pointers like this is handy for things like the playfield in games like Combat because those graphics don't change. They're not that useful for an animated sprite. For those we end up using a pointer that points to a pointer. This is known on the 6502 as Indirect mode. This instruction:
lda ($80),y
is an example of that. The first pointer is the $80, which points to address $80 in the computer. Address $80 and $81 (because we need a 16-bit address and only 8 bits can be held in a memory location) point to the next location. Finally add in Y to find the final location in memory to fetch the value from. The value in the parentheses must be $00-$ff, which is known as zero page memory.
lda #<$F800
sta $80
lda #>$F800
sta $81
ldy #1
lda ($80),y
ldy #2
lda ($80),y
lda #<$F880
sta $80
lda #>$F880
sta $81
ldy #2
lda ($80),y
ldy #3
lda ($80),y
; location $F800
; location $F880
.byte $00, $0a, $14, $1e, ...
Similar to before, but the first set of lda ($80),y return $05 and $0a while the second set return $14 and $1e. As before, labels help clarify things:
TimesTablePtr = $80
lda #<Times5
sta TimesTablePtr
lda #>Times5
sta TimesTablePtr+1
ldy #1
lda (TimesTablePtr),y
ldy #2
lda #<Times10
sta TimesTablePtr
lda #>Times10
sta TimesTablePtr+1
ldy #2
ldy #3
; location $F800
; location $F880
Times10: .byte $00, $0a, $14, $1e, ...
The instructions for DASM has this to say about the < and >:
20 <exp take LSB byte of a 16 bit expression
20 >exp take MSB byte of an expression
LSB is Least Significant Byte while MSB is Most Significant Byte. A 16-bit address written in hex is comprised of 4 digits, such as $1234. The LSB is the $34 part of the address while the MSB is the $12 part.
For the instructions
lda #<Times10
lda #>Times10
the compiler first replaces the labels with the values:
lda #<$F880
lda #>$F880
It then extracts the MSB and LSB:
 lda #$80
lda #$F8
When prepping indirect pointers the LSB goes into Pointer while MSB goes into Pointer+1
Note: there is an indirect mode using X, but it works different than the one with Y. You can ignore it for now, and maybe forever. I've never used it myself, and I started coding 6502 assembly on my VIC 20 back in 1982.
#21 bogax OFFLINE
bogax
    Dragonstomper
  • 738 posts
Posted Sun Apr 2, 2017 7:39 PM
um, notice one of those is even and one is odd?
#22 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sun Apr 2, 2017 7:42 PM
right, it's actually 2^16-1, or 65535.
#23 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Sun Apr 2, 2017 9:46 PM
-snip-
This helped a lot, thank you!
Thank you guys for all your replies!  They've been very helpful.
Edited by Electrk, Sun Apr 2, 2017 9:47 PM.
#24 BNE Jeff OFFLINE
BNE Jeff
    Moonsweeper
  • 320 posts
Posted Mon Apr 3, 2017 3:43 AM
aaaaand you lost me lol
Ha!-  Lost you where? Do you know how a television draws its pictures?
#25 Electrk OFFLINE
Electrk
    Space Invader
  • 13 posts
Posted Mon Apr 3, 2017 3:41 PM
OH
jesus
for some reason I read that as putting the pointer 100 lines above where the graphics start in the actual code.  I was like "what the fuck that doesn't make any sense" lol
your post makes sense now
Edited by Electrk, Mon Apr 3, 2017 3:41 PM.
