Which of these buttons says "Atari!" to you?
39 replies to this topic
#1 hizzy OFFLINE
hizzy
    Dragonstomper
  • 849 posts
Posted Thu Apr 6, 2017 4:44 PM
Hi Everyone,
I'm finally building a custom joystick for my 2600/7800. I'm trying to capture some of the iconic elements of the old Atari sticks, so I've been looking at the CX-10 and the CX-40. It's funny, but I have a hard time pinning down the color of the joystick button. Sometimes, the button looks orange. Other times, it looks red. I'm curious to ask: What do other people see it as? Below, I have attached some pictures of the buttons that I think could be a good fit for my stick. Which one of them says "Atari" to you?
Thanks for your feedback!!
h
#2 robbievgb OFFLINE
robbievgb
    Chopper Commander
  • 120 posts
Posted Thu Apr 6, 2017 4:49 PM
Hi Everyone,
h
Oh man, It's between 1 & 4 for me, but they all look good. that's a tough one!
#3 hizzy OFFLINE
hizzy
    Dragonstomper
  • 849 posts
Posted Thu Apr 6, 2017 4:56 PM
Hi!
I'm thinking to rule out # 3. 4 is quite red. Do the all black sticks, like the ones that come on the vader, have red buttons?
Thanks!
#4 xucaen OFFLINE
xucaen
  • 1,140 posts
  • Job searching.
Posted Thu Apr 6, 2017 6:02 PM
I like this one. Shiny.
post-44563-0-12043000-1491518316_thumb.j
#5 hizzy OFFLINE
hizzy
    Dragonstomper
  • 849 posts
Posted Thu Apr 6, 2017 6:34 PM
Wow! Two people for the red!!
#6 Wyluli Wolf OFFLINE
Wyluli Wolf
    Moonsweeper
  • 319 posts
Posted Thu Apr 6, 2017 6:37 PM
Number one is probably the closest in color the to cx-40 but personally I like #2.  The whole atari dotted line around the joystick handle is a nice orange color and that would match nicely instead of dropping a "reddish" button there.  Just my opinion though.
Do post pics when you finish :)
#7 82-T/A OFFLINE
82-T/A
  • 3,904 posts
Posted Thu Apr 6, 2017 6:51 PM
1 and 4 are basically the same, but with a different method of mounting. One has a screw-back while the other snaps in.
But yeah... 1 and 4 look Atari. It's up to you how you want it mounted.
#8 hizzy OFFLINE
hizzy
    Dragonstomper
  • 849 posts
Posted Thu Apr 6, 2017 6:53 PM
Hi!
Thanks for your reply! 1 is called "vermilion" and 4 is a straight red. They look similar to me, too :P
#9 Osgeld ONLINE
Osgeld
  • 5,001 posts
Posted Thu Apr 6, 2017 7:15 PM
dunno I like 2, its more burnt orange like the consoles
#10 Atarikid96 OFFLINE
Atarikid96
    Star Raider
  • 94 posts
  • Buy the ticket, take the ride.
Posted Thu Apr 6, 2017 7:35 PM
I think it would be cool as hell to have a yellow button like #3. Different, and totally custom. Be sure to post pics, please!
#11 BassGuitari ONLINE
BassGuitari
    Glorified Toaster
  • 6,361 posts
  • Remember how bright the future used to look?
Posted Thu Apr 6, 2017 7:56 PM
First one if you're going for a classic CX40 look, or the last one if you're going for a Vader/Junior CX40 or ProLine look.
#12 Flojomojo ONLINE
Flojomojo
    I say boom boom boom
  • 11,664 posts
  • You say bam bam bam
Posted Thu Apr 6, 2017 8:34 PM
1 or 4. Red not orange. Please post pics when done!
#13 Osgeld ONLINE
Osgeld
  • 5,001 posts
Posted Thu Apr 6, 2017 8:47 PM
if its got to be 1 or 4 as the popular vote says I say not 1
not the color but the mounting style, whatever you try to clip a button in will be too thin which will spin and break wires eventually, or two thick, which will eventually hammer itself back out as you play
then there's drilling the hole, all drills and bits have wobble, bezel and nut is easiest unless you really really pay attention (though epoxy is an option)
Edited by Osgeld, Thu Apr 6, 2017 8:51 PM.
#14 Allen Schweitzer OFFLINE
Allen Schweitzer
    Space Invader
  • 28 posts
  • Demon Attacker
Posted Thu Apr 6, 2017 10:01 PM
I was going to say it's a toss up between 1 and 4, but then I read what everybody else said, and I don't want to sound like a broken record...
#15 Zonie OFFLINE
Zonie
  • 1,929 posts
Posted Thu Apr 6, 2017 11:41 PM
If you're modding a CX10/40, then too red may be too red. This is my "NEStari" Stick where I hacked a NES controller into it so I can kick my son's ass at NES games. It was a bit challenging to make the second button hole, but patience patience patience. I'm currently waiting for some new mini switches like your number 2 above to make a 7800 controller the same way.
The second button is the actual button from a NES controller.
The black buttons are the start and select. They are the tiny radio shack ones.
I painted the dashes silver to be more "NESSY".
Edited by Zonie, Thu Apr 6, 2017 11:45 PM.
#16 Tangentg OFFLINE
Tangentg
    Moonsweeper
  • 394 posts
Posted Fri Apr 7, 2017 2:20 AM
If you're building one I like 4 a bit more than 1.
#17 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 16,545 posts
Posted Fri Apr 7, 2017 3:17 AM
Hi Everyone,
h
Bottom left. FYI, it's preferable to use screw type buttons in custom enclosures. If your hole isn't perfect or the enclosure isn't a precise thickness, the snap ins will become loose or rotate in place. Screw type will form a secure connection every time, provided the control panel isn't too thick.
Happ/IL plunger style buttons use 28mm  (1+1/8") holes and up to 3/4 inch thick panel.
Sanwa/Simitsu use 24mm (15/16") for small button and 30mm (1+3/16") for standard button. Screw types accept up to 6mm (1/4") panels. 1+3/16" bits are a very uncommon part in the US so you may order a metric 30mm online or a specialty 1+3/16" spade bit for "rain barrels."
#18 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,084 posts
  • Always left from right here!
Posted Fri Apr 7, 2017 3:51 AM
#1 for me.
#19 Jin OFFLINE
Jin
    Solar Striker
  • 2,259 posts
Posted Fri Apr 7, 2017 3:59 AM
I'd say none of the above, only because none of them are concave like the button on a CX-40. If you want a button that's really authentic looking and high performance I'd recommend buying two Industrias Lorenzo concave buttons, one black and one red. Take the plunger out of the red one, stick it in the barrel of the black one (which is very simple to do), add a nice 20g soft touch microswitch, and you're good to go. :)
#20 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,084 posts
Posted Fri Apr 7, 2017 4:01 AM
That's my main concern here too.
#21 spriggamortis OFFLINE
spriggamortis
    Chopper Commander
  • 120 posts
  • Retro-Maniacal Douchebag
Posted Fri Apr 7, 2017 4:11 AM
Agree with Jin.  Concave like the original.  That color looks good on that Lorenzo as well.  Sanwa do a snap-in SDM-20 button in various colors, including red.  20mm or just under under 13/16" overall width I believe.
#22 Schizophretard OFFLINE
Schizophretard
  • 4,928 posts
Posted Fri Apr 7, 2017 4:35 AM
#2 looks the closest to the reddish orange color of an Atari joystick.
#23 Atarian7 OFFLINE
Atarian7
  • 3,351 posts
Posted Fri Apr 7, 2017 5:58 AM
The first one on the left.
#24 hizzy OFFLINE
hizzy
    Dragonstomper
  • 849 posts
Posted Fri Apr 7, 2017 7:34 AM
Wow! The concave button never occurred to me. I looked at Japanese buttons because I like their responsiveness, but I will try the IL buttons, too! For button size, I was leaning towards a 30mm button. I thought more surface area would help in games which require quick hits of the button.
It's interesting to see how people interpret color. I thought a red button wouldn't be popular at all. Did Atari change button color over the years?
Thanks!! :)
Edited by hizzy, Fri Apr 7, 2017 7:44 AM.
#25 Zonie OFFLINE
Zonie
  • 1,929 posts
Posted Fri Apr 7, 2017 9:25 AM
Yeah, I prefer the concave buttons too.
