Would love to see this for TI programming
26 replies to this topic
#1 Airshack OFFLINE
Airshack
    Dragonstomper
  • 596 posts
Posted Mon Apr 10, 2017 11:28 AM
http://64bites.com/
#2 TheBF OFFLINE
TheBF
    Moonsweeper
  • 481 posts
Posted Wed Apr 12, 2017 1:54 PM
I was thinking that the TI world needs training videos too.
Hmmm....
BF
#3 --- Ω --- OFFLINE
--- Ω ---
    Kwisatz Haderach
  • 11,108 posts
Posted Wed Apr 12, 2017 2:26 PM
Definitely a niche yet to be filled.  Question... who is ready, willing and able to take on such a herculean task?
#4 Opry99er ONLINE
Opry99er
  • 8,772 posts
Posted Fri Apr 14, 2017 11:08 AM
I'd love to... I have quite a bit of stuff out there already... but it would be pretty cool to create a uniform format.
My computer is down right now... bad HD.
If nobody takes on the task by the time I have access to a computer again, I will start the process.
Will need help from some experienced GPL and Assembly programmers. I can demo some stuff in assembly, but I am not an advanced programmer.
Edited by Opry99er, Fri Apr 14, 2017 11:10 AM.
#5 RXB OFFLINE
RXB
  • 2,900 posts
Posted Sat Apr 15, 2017 12:22 AM
I have done quite a few GPL HOW 2 Videos?
GPLHOW2A to GPLHOW2K
#6 Airshack OFFLINE
Airshack
    Dragonstomper
  • 596 posts
Posted Thu Apr 20, 2017 1:34 PM
There's a dude on here named Rich who seems to have a firm grasp of the fundamentals of GPL.
Sent from my iPhone using Tapatalk
  • RXB likes this
#7 Opry99er ONLINE
Opry99er
  • 8,772 posts
Posted Thu Apr 20, 2017 3:35 PM
Yep... RXB. He has quite a few videos up on GPL.
  • RXB likes this
#8 RXB OFFLINE
RXB
  • 2,900 posts
Posted Fri Apr 21, 2017 12:21 AM
Thanks just wish I have more people interested in GPL, most seem to want only Assembly which is faster, but one hell of a lot more complicated to debug.
Want proof take a look at the XB ROMs....example:
* COMPCT  ROUTINE (GARBAGE COLLECTION)
GRBAGE EQU  $
LN73D8 MOV  R11,R7
LN73DA MOV  @FREPTR,R0 * Pointer free space under symbol table
LN73DE MOV  @STRSP,R5  * End string space (high address)
LN73E2 MOV  R0,@STRSP  * New pointer end string space
LN73E6 INC  R5         * WTF does this do?
LN73E8 DEC  R5         * WTF does this do?
LN73EA C    @STREND,R5 * End of string space?
LN73EE JL   LN73F6     * No, shift if necessary?
LN73F0 MOV  R0,@STREND * New pointer start string space, low address
LN73F4 B    *R7
WTF INC R5 then DEC R5? And no they do not jump into the DEC address at LN73E8 so this kind of stuff is baffling at best!
#9 mizapf OFFLINE
mizapf
  • 2,892 posts
Posted Fri Apr 21, 2017 1:43 AM
Maybe they are jumping back to LN73E8 somewhere; in that case the INC-DEC makes sense.
#10 RXB OFFLINE
RXB
  • 2,900 posts
Posted Fri Apr 21, 2017 2:36 AM
Actually there is a section, but hard to see what it is doing:
GRBAGE EQU  $
LN73D8 MOV  R11,R7
LN73F4 B    *R7
LN73F6 MOV  R5,R2      * Get string space (high address)
LN73F8 MOV  R5,R3      * Get string space (high address)
* WRITE ADDRESS, READ BYTE
LN73FA BL   @>1880
LN73FE MOVB R1,R6
LN7400 SRL  R6,8       * Swap bytes
LN7402 S    R6,R5      *
LN7404 AI   R5,>FFFD   * Upper 24K address+R5
LN7408 MOV  R5,R3
LN740A BL   @LN6C9E
LN740E MOV  R1,R1
LN7410 JEQ  LN73E8
LN7412 C    *R6+,*R6+
LN7414 MOV  R2,R3
LN7416 MOV  R0,R4
LN7418 BL   @>1880
LN741C BL   @LN6422
LN7420 DEC  R3
LN7422 DEC  R4
LN7424 DEC  R6
LN7426 JGT  LN7418
LN7428 ANDI R4,>3FFF
LN742C MOV  R4,R0
LN742E INC  R4
LN7430 MOV  R4,R3
LN7432 BL   @LN6C9E
LN7436 MOV  R3,R6
LN7438 AI   R6,>0003
* WRITE ADDRESS, WRITE 2 BYTES
LN743C BL   @>18AE
LN7440 JMP  LN73E8 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Here it is, the only one.
#11 sometimes99er OFFLINE
sometimes99er
  • 4,080 posts
Posted Fri Apr 21, 2017 2:49 AM
And LN7410 JEQ LN73E8.
#12 RXB OFFLINE
RXB
  • 2,900 posts
Posted Fri Apr 21, 2017 8:17 AM
Wow correct  why did my TEXT search not see that one?
Edited by RXB, Fri Apr 21, 2017 8:17 AM.
#13 Asmusr ONLINE
Asmusr
  • 2,579 posts
Posted Fri Apr 21, 2017 1:45 PM
I can easily debug machine code in an emulator. How do you debug GPL?
Edit: I ask out of interest, because when I developed my emulator I spent a hell of a time debugging GPL from machine code.
#14 RXB OFFLINE
RXB
  • 2,900 posts
Posted Fri Apr 21, 2017 7:49 PM
Honestly are you saying Machine Code and Assembly are more easy to read and debug then GPL?
I even wrote a article on this in Micropendium magazine:
ftp://kirklanduncorked.com/programming/GPL/Gilbertson/gplsup.txt
To simplify what each one does, the Extended BASIC program's
version of each program explains what is going on. If you are not
one who understands Extended BASIC either, now is your chance to
start learning and at the same time see two other languages.
EXTENDED BASIC PROGRAM BYTES USED 14 * NOTE USES GPL Routine.
100 CALL CLEAR
GPL PROGRAM BYTES USED 2     * NOTE SUPPORT NOT NEEDED AS
    ALL 32                     OPERATING SYSTEM IS BUILT IN.
ASSEMBLY PROGRAM BYTES USED 16  * NOTE I AVOIDED COUNTING THE
    LI   R0,>2000                 ASSEMBLY SUPPORT ROUTINES IN
    LI   R1,767                   ORDER TO MAKE THIS PROGRAM
J1  BLWP @VSBW                    WORK. SPACE OF ARTICLE IS
    DEC  R1                       LIMITED. 1k IS NEEDED FOR
    JNE  J1                       SUPPORT ROUTINES.
EXTENDED BASIC PROGRAM BYTES USED 10
100 GOTO 100
GPL PROGRAM BYTES USED 2 OR 3
    BR   LABEL
    BS   LABEL
    B    LABEL
ASSEMBLY PROGRAM BYTES USED 2 OR 4
    JMP  @LABEL
    B    @LABEL
EXTENDED BASIC PROGRAM BYTES USED 41
100 CALL JOYST(1,X,Y1) :: CALL KEY(1,K,S)
GPL PROGRAM BYTES USED 4
        ST   >01,@>8374
        SCAN
ASSEMBLY PROGRAM BYTES USED 12
    LI   >0100
    MOVB R0,@8374
    BLWP @KSCAN
EXTENDED BASIC PROGRAM BYTES USED 17
100 GOSUB 1000
1000 RETURN
    CALL SUB
SUB RETURN
ASSEMBLY PROGRAM BYTES USED 6
    BL   @SUB
    SUB RT
EXTENDED BASIC PROGRAM BYTES USED 30
100 CALL HCHAR(12,16,42)
GPL PROGRAM BYTES USED 6
    ST   42,V@368
    LI   R0,368
    LI   R1,>2A00
    BLWP @VSBW
EXTENDED BASIC PROGRAM BYTES USED 58
100 CALL GCHAR(10,10,G) :: CALL HCHAR(20,20,G,4)
GPL PROGRAM BYTES USED 18
     ST   V@298,@FAC
     DST  >1714,@837E
LOOP ST   @FAC,@837D
     DEC  @837E
     CEQ  >13,@>837E
     BR   LOOP
ASSEMBLY PROGRAM BYTES USED 30
         LI       R0,298
         CLR  R1
         BLWP @VSBR
         LI   R2,3
         LI   R0,628
    LP   BLWP @VSBW
         AI   R0,32
         DEC  R2
         JNE  LP
EXTENDED BASIC PROGRAM BYTES USED 45
100 CALL SUBROUTINE
1000 SUB SUBROUTINE
1010 SUBEND
    CALL SUB
SUB RTN
ASSEMBLY PROGRAM BYTES USED 42
SUBWS  BSS  32
SUB    DATA SUBWS
       DATA SUB2
SUB2   RTWP
       BLWP @SUB
EXTENDED BASIC PROGRAM BYTES USED 21
100 CALL MAGNIFY(3)
GPL PROGRAM BYTES USED 3
    ST   >E2,#1
ASSEMBLY PROGRAM BYTES USED 8
    LI   R0,>01E2
         BLWP @VWTR
100 RANDOMIZE(8)
    RAND >08
    LI   R0,>0800
    MOVE R0,@>83C0
EXTENDED BASIC PROGRAM BYTES USED 20
100 CALL SCREEN(5)
    ST   4,#7
    LI   R0,>0704
         BLWP @VWTR
100 IF VAR=8 THEN 200 ELSE 300
GPL PROGRAM BYTES USED 7
L100   CEQ   8,@VAR
       BS    L200
       BR    L300
L100   CI    8,@VAR
       JEQ   L200
       JMP   L300
GK EXTENDED BASIC PROGRAM BYTES USED 12
100 CALL BYE
    EXIT
    LWPI  >83E0
    BLWP  @>0000
You can see if you just look at the number of bytes used by each
language that all of them suffer in some area. At times Extended
BASIC approaches Assembly in memory usage, while at times
Assembly approaches GPL in memory usage. It is apparent that GPL
can't be beat even in the simplest of the routines that Assembly
should excel in. Texas Instruments did a great job with creating
GPL. It either matches Assembly in size or beats it ever time. By
the way, GPL also uses less memory than any other language I've
compared it to, including Forth and C.
Edited by RXB, Fri Apr 21, 2017 7:55 PM.
#15 sometimes99er OFFLINE
sometimes99er
  • 4,080 posts
Posted Fri Apr 21, 2017 10:56 PM
Obviously a GPL programmer would say no, and an Assembly programmer would say yes !? ;)
Unfortunately I'm not seeing one tiny hint of how to debug GPL in the material you referenced. :|
#16 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Fri Apr 21, 2017 11:20 PM
You can write crappy code in any language. Some of the worst code I have ever seen is written in C++, JavaScript, Python, Java, etc.  Don't blame the language for bad programming.
It depends on what you are used to, and everyone has an environment in which they are most comfortable or enjoy.  Certainly assembly can be tedious due to the small steps to get something seemingly simple done.  But assembly has the speed advantage and nothing is abstracted or getting in your way, which is perfect for things like operating systems, language interpreters, games, etc.
Since I don't know GPL, to me it is hard to read and it seems like it would be tedious to learn all the parameters to the instructions.  So yes, in my case, to me assembly is easier to read and debug than GPL.
As for "machine code", no it is not easier to read or debug.  Rarely do you write in machine code, unless you are writing some small routines using MiniMemory, and it is not pleasant IMO.  Writing machine code and assembly are not the same thing, and should not be used in the same sentence as you did above.
#17 Lee Stewart ONLINE
Lee Stewart
  • 3,549 posts
Posted Sat Apr 22, 2017 9:01 AM
There is a somewhat similar problem debugging high-level Forth words in fbForth, TurboForth, TI Forth, CAMEL99 Forth, ....  In an ALC debugger, one must track the pointers to the parameter and return stacks, current word and next word in the Forth workspace registers in addition to the normal ALC debugging.  It is simply an additional debugging level, which is complicated by not having it as part of the debugger’s function, i.e., you have to do it manually, which takes longer and is more tedious than it would be in a debugger tailored to the language.
...lee
#18 RXB OFFLINE
RXB
  • 2,900 posts
Posted Sat Apr 22, 2017 10:47 AM
I have unlike you made a bunch of GPLHOW2 videos....getting tired of you treating me like crap. (Maybe you think you are funny?)
And  I DID provide examples in XB, GPL and Assembly so people can see the difference:
100 CALL CLEAR
100 GOTO 100
    BR   LABEL
    BS   LABEL
    B    LABEL
    JMP  @LABEL
    B    @LABEL
        ST   >01,@>8374
        SCAN
    LI   >0100
    MOVB R0,@8374
    BLWP @KSCAN
100 GOSUB 1000
1000 RETURN
    CALL SUB
SUB RETURN
    BL   @SUB
    SUB RT
    ST   42,V@368
    LI   R0,368
    LI   R1,>2A00
    BLWP @VSBW
     ST   V@298,@FAC
     DST  >1714,@837E
LOOP ST   @FAC,@837D
     DEC  @837E
     CEQ  >13,@>837E
     BR   LOOP
         LI       R0,298
         CLR  R1
         BLWP @VSBR
         LI   R2,3
         LI   R0,628
    LP   BLWP @VSBW
         AI   R0,32
         DEC  R2
         JNE  LP
100 CALL SUBROUTINE
1000 SUB SUBROUTINE
1010 SUBEND
    CALL SUB
SUB RTN
SUBWS  BSS  32
SUB    DATA SUBWS
       DATA SUB2
SUB2   RTWP
       BLWP @SUB
100 CALL MAGNIFY(3)
    ST   >E2,#1
    LI   R0,>01E2
         BLWP @VWTR
100 RANDOMIZE(8)
    RAND >08
    LI   R0,>0800
    MOVE R0,@>83C0
100 CALL SCREEN(5)
    ST   4,#7
    LI   R0,>0704
         BLWP @VWTR
L100   CEQ   8,@VAR
       BS    L200
       BR    L300
L100   CI    8,@VAR
       JEQ   L200
       JMP   L300
100 CALL BYE
    EXIT
    LWPI  >83E0
    BLWP  @>0000
#19 Asmusr ONLINE
Asmusr
  • 2,579 posts
Posted Sat Apr 22, 2017 12:24 PM
Back to my original question, if assembly is "one hell of a lot more complicated to debug" than GPL, how do you debug GPL?
#20 Tursi ONLINE
Tursi
  • 4,963 posts
  • HarmlessLion
Posted Sat Apr 22, 2017 4:49 PM
Rich, they are asking, when you write some GPL code and it crashes, how do you work out where the mistake is? Do you have some tools you lean on?
#21 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Sat Apr 22, 2017 5:56 PM
To the original topic.  How do you make assembly language programming videos that are engaging?  Programming is typically an independent activity, and programming classic computers usually requires a lot of reference information to look up memory locations, instruction parameters, etc.  I don't see how you get around reading...  I was hoping to get a feel for how those c64 videos are doing it, but they seem to be pay-to-view.
I also have a fundamental disagreement with the first statement you see on that site:
"Life is too short to read twenty-year-old books."
More than half of the books I own are more then 20 years old and they contain some of the best information you can get for computers that are over 30 years old.  That's like saying life is too short to mess with classic computers.
#22 RXB OFFLINE
RXB
  • 2,900 posts
Posted Sat Apr 22, 2017 11:50 PM
As I have explained in the article I wrote for Micropendium years ago looking at a gradient of ease of learning.
TI BASIC
Extended BASIC
GPL
ASSEMBLY LANGUAGE
MACHINE CODE
GPL sits between Assembly and XB for a reason, it does not require WORD instructions to learn and bit manipulations of BYTE swaps to be required to learn.
As a byte orientated language GPL unlike Assembly does not expect you to start using SRA or SRL from the very start.
Having myself run a Assembly Language Class for the PUNN and Vancouver User groups I know Assembly it much tougher to learn.
I mean just to clear the screen in Assembly is hard to explain as you need 1K of support routines before you can even begin to do this.
I mean in Assembly you need to do this to clear screen:
How the hell is this as easy as TI BASIC or XB:
CALL CLEAR
Or GPL
ALL 32
Really are you going to tell me this is easier in Assembly for a beginner? REALLY?
Edited by RXB, Sat Apr 22, 2017 11:53 PM.
#23 Lee Stewart ONLINE
Lee Stewart
  • 3,549 posts
Posted Sun Apr 23, 2017 4:21 AM
Rich, bludgeoning us with stories of how much easier GPL is to learn than Assembly Language is really not offering us any insight into debugging GPL.
...lee
#24 sometimes99er OFFLINE
sometimes99er
  • 4,080 posts
Posted Sun Apr 23, 2017 4:33 AM
I'm sorry you feel that way. And I'm not trying to be funny.
Yes, I honestly feel that Assembly (/machine code) is much easier to "debug" than GPL. And I think it's very well explained by Lee Stewart in post #17.
Yes, clearing the screen seems more complicated in Assembly than GPL. When "writing" longer and more complicated programs (than clearing the screen), - if the result (running the program) is not as expected, one starts to "debug". I hope we can agree on that.
I was interested in how one can possibly more easily "debug" GPL.
Edited by sometimes99er, Sun Apr 23, 2017 4:35 AM.
#25 Opry99er ONLINE
Opry99er
  • 8,772 posts
Posted Sun Apr 23, 2017 4:43 AM
As a novice 9900 coder, I can tell you that Rich is correct. Higher level languages are easier to learn than low level/machine level languages like Sam.
But I don't see how the ease of learning a language has anything to do with debugging source code. To be honest, I find debugging in assembly to be extremely straightforward, especially if errors occur on assembly. :D
Well structured, fully commented assembly code is sometimes easier to understand than even a BASIC listing.
