write disabled?
18 replies to this topic
#1 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Apr 13, 2017 12:18 PM
I using SIO2PC USB, i cant write to disk
#2 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 13, 2017 12:42 PM
did you update RespeQt, and then this happened?
You're running on windows? what version?
What kind of SIO2PC-USB? FTDI based?
What kind of handshaking?
Edited by Joey Z, Thu Apr 13, 2017 12:55 PM.
#3 TheMontezuma ONLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Thu Apr 13, 2017 2:07 PM
Could you please switch the "Backend" to "Standard Backend" and re-check?
It could be a problem related to the "Qt Backend".
#4 TheMontezuma ONLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Thu Apr 13, 2017 2:42 PM
@w1k
thanks for the pointing the error.
I can confirm that this is a problem with the "Qt Backend" - I have never tested writing to a disk before.
#5 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 13, 2017 3:02 PM
quick test here shows no issues, let me try a longer write though....
EDIT: no issue formatting a disk here and copying a 293 sector file to it. I am running at 1X though, and I am using linux. I am using the Qt serial port backend.
Edited by Joey Z, Thu Apr 13, 2017 3:06 PM.
#6 DrVenkman ONLINE
DrVenkman
  • 3,986 posts
  • Back off, man! I'm a scientist.
Posted Thu Apr 13, 2017 3:44 PM
I was fooling with the Qt backend on my RPi setup last week (so Raspian Jessie Linux)  and got some strange timeouts a couple times in general use. Disabling emulation and re-enabling it seemed to clear them up but I later changed over to the standard backend and had no further problems. I will say though that I did no real troubleshooting, nor did I attempt to isolate the issues.
​Gives me a good excuse to fool around tonight.
EDIT: Okay, interesting bug with the Qt backend ... I'm using an SIO2PC device from Ray (FTDI based), connected through my ICD P:R: Connection. Using the Qt backend I can create an instant crash by selecting "Use Non-Standard POKEY Divisor" or whatever the exact phrasing is in the dialog, and then power-cycling my system for a cold boot. However, if the system is already up and running and I check the box, I can then do read/write operations between multiple drives - even between the flash-based IDE hard disk in my SIDE2 cart and a large SDX-formatted HD image in RespeQt - with no trouble. But as soon as I do a system power cycle, RespeQt crashes on me.
By contrast, the Standard backend works fine all the way up and down the speed range - no crash with a cold boot using non-standard POKEY divisors.
​This is using a build I made last weekend on my RPi from Joey's Main branch.
Edited by DrVenkman, Thu Apr 13, 2017 4:20 PM.
#7 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Apr 13, 2017 11:45 PM
i using lotharek sio2pc usb
http://lotharek.pl/z...-usb-manual.pdf
i just tried saving configure files (ice-t, fujichat)..
COM3, DSR, 57600 (3x)
#8 TheMontezuma ONLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Fri Apr 14, 2017 12:48 AM
The reason for introducing Qt Backend was that somebody reported me that his Arduino Micro Pro with the following sketch (acting as SIO2PC):
void setup()
   Serial.begin(19200);
   Serial1.begin(19200);
void loop()
  if (Serial1.available())
    Serial.write(Serial1.read());
  if (Serial.available())
    Serial1.write(Serial.read());
doesn't work with RespeQt under Windows (although works perfectly well under Linux).
He told me that PUTTY and Qt terminal (example code from Qt) show properly data coming from the ATARI.
I was curious and promised to help and ordered a Micro Pro board.
While I was waiting for delivery I implemented the Qt backend (as an experimental feature).
The real reason why RespeQt didn't work with Micro Pro under Windows, was the serial driver.
It expected the asserted DTR line and RespeQt was resetting the DTR (to low state).
A change for the DTR line helped.
However I already had the Qt backend code and decided to add it to Github.
Now it looks like it was too early.
I examined the w1k problem with a logic analyzer and realized that the Windows implementation of the QSerialPort seems to be too slow for the SIO protocol.
In this case I see no reason to keep it in RespeQt and I propose to remove it.
  • w1k likes this
#9 DrVenkman ONLINE
DrVenkman
  • 3,986 posts
Posted Fri Apr 14, 2017 8:54 PM
Just out of curiosity - did anyone duplicate my immediate crash with the Qt Backend by enabling non-standard POKEY divisors and a cold boot of the host Atari?
#10 TheMontezuma ONLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Sat Apr 15, 2017 1:55 AM
I trusted you and didn't actually duplicate it myself.
However the bug is gone now (together with the Qt Backend) ;)
#11 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Apr 20, 2017 9:59 AM
so, whats next? its a bug or problem with my sio2pc?
#12 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 20, 2017 10:08 AM
It's fixed, right? No more QtSerial backend. Try r4-beta2: https://github.com/j...es/tag/r4-beta2
#13 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Apr 20, 2017 10:13 AM
thank you:) but i cant compile, i must wait for release :) but thanks:)
#14 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 20, 2017 11:10 AM
Binaries have been compiled and are now available at the link.
Edited by Joey Z, Thu Apr 20, 2017 11:10 AM.
#15 mytek OFFLINE
mytek
  • 3,389 posts
Posted Mon Nov 13, 2017 8:00 AM
Did a binary for Ubuntu ever get compiled that fixes the write issue? Presently I'm just using the one that was done for Windows in VirtualBox under a Ubuntu distribution, but it would be nice to have it work natively under Linux as well.
- Michael
#16 DrVenkman ONLINE
DrVenkman
  • 3,986 posts
Posted Mon Nov 13, 2017 9:40 AM
Weirdness. I compile every release for Raspian right on my RPi boxes and haven’t ever had an issue writing to disk images.
#17 mytek OFFLINE
mytek
  • 3,389 posts
Posted Wed Nov 15, 2017 11:44 PM
The last time I ran a compiled version on Linux was R3 I believe, and it was still cranky as could be about writing to the disk (required dropping down to SIO stock speed), but it's always been fine when reading which luckily is most of the time. However on that same computer if I run WinXP in VirtualBox with any version of RespeQt I can write at Divisor zero all day long. So getting back to my original question, is there a compiled version beyond R3 that might work better for me under Linux? Or if the latest version of the sources has been corrected for this, I guess I could compile that myself, but I just wanted to double check before doing that only to discover that it still has problems.
- Michael
#18 TheMontezuma ONLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Thu Nov 16, 2017 2:49 AM
The original problem was related to the "Qt Backend" (implementation of the serial port access based on the Qt Serial Port library).
This was an experimental feature and was completely removed from RespeQt due to various issues.
So, you can compile RespeQt R4 by yourself.
#19 mytek OFFLINE
mytek
  • 3,389 posts
Posted Thu Nov 16, 2017 12:57 PM
Thank you  :) . I'll go grab it.
Edit: Picked up a compiled version HERE and it works just fine now when writing at divisor zero in Ubuntu.
- Michael
Reply to this topic
