SiberianSpForces Posted April 15, 2017 Share Posted April 15, 2017 Long story short, I narrowed down to the transformer. After popping the RF shield off and seeing a very clean board, I did a volt test. It's only getting 10.85 volts to the supply board. Then I started to check the ribbon connector. The first pin, if I recall, was fine. The next 2 were under the normal voltage. Before I could test the last pin, the transformer got hot enough to smell and I shut it down. The only thing that was warm on the supply board was the smaller of the 2 large caps. Right now I'm looking around on eBay for either a transformer or parts system. Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted April 23, 2017 Author Share Posted April 23, 2017 Scored a Partstellivision off eBay and it arrived yesterday. I swapped out the transformer and within 30 seconds, a small cap blew. So I swapped power supplies and so far, nothing burning up. The picture on channel 3 is scrambled lines while channel 4 has multicolored snow. I am open to suggestions on what to tinker with next. Quote Link to comment Share on other sites More sharing options...
mr_me Posted April 24, 2017 Share Posted April 24, 2017 Is this a model 2609. Are all the voltages correct now. https://console5.com/wiki/File:Intellivision-I-Power-Supply-Test-Points.png More experts will see this if posted in the Intellivision forum. Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 24, 2017 Share Posted April 24, 2017 If not done already, have you checked to make sure the voltages to the 7805 and 7812 are correct and that both are outputting correct voltage? I believe on my Sears (Basically a 2609), that I had +10 going into the 7805 and something along the lines of +24 into the 7812. I've since swapped both out with comparable DC/DC converters but obviously the if the incorrect voltages aren't getting where they should it would prevent or take out the regulators affecting everything else downline of that. As suggested, checking the voltage at the ribbon cable on the game PCB side will help determine this. Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted April 25, 2017 Author Share Posted April 25, 2017 Did some testing. I started at the 2 prongs that would connect to the logic board. That came out at 12.68. Then the ribbon plug; 5.16 11.98 13.81 0 -2.16 On the 7805 and 7812, I tested both outside prongs. I had to test the 7812 from the backside of the board. 7805-12.70/5.16, 7812-17.85/11.99 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted April 25, 2017 Share Posted April 25, 2017 Then at this point besides the small cap that blew on the power supply board, it has to be something in the logic on the main PCB. But I wouldn't know where to start exactly. I've tinkered with my Intelly a few times in that I did a cap kit on it and modded it for comp video, but nothing else. Quote Link to comment Share on other sites More sharing options...
mr_me Posted April 25, 2017 Share Posted April 25, 2017 I would think the picture would be the same on channels 3 or 4 unless the RF modulator channel switch is broken. Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted April 25, 2017 Author Share Posted April 25, 2017 I was using the RF box from a NES. I just found the original cable and I have a coax adapter on. It just does a black screen. Quote Link to comment Share on other sites More sharing options...
mr_me Posted April 26, 2017 Share Posted April 26, 2017 A black screen is normal with no cartridge. It could be the cartridge connection. How many cartridges have you tested? Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted April 26, 2017 Author Share Posted April 26, 2017 Tested 5 so far. The cart contacts so far are still shiny. I also sprayed a little bit of contact cleaner on the cart plugin and bent the pins down just a hair. Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted May 3, 2017 Author Share Posted May 3, 2017 *Post move bump* Quote Link to comment Share on other sites More sharing options...
HunterZero Posted May 6, 2017 Share Posted May 6, 2017 (edited) Tested 5 so far. The cart contacts so far are still shiny. I also sprayed a little bit of contact cleaner on the cart plugin and bent the pins down just a hair. Have you checked the voltages at the board? Do all the ribbon pins and blue wire have continuity? Is the blue wire with the 2 pin Molex connected properly? Do you get a screen flash when you press reset or nothing at all? Edited May 6, 2017 by HunterZero Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted May 6, 2017 Share Posted May 6, 2017 It sounds like you're working on an Inty 1. In case this helps someone else, I've built an Eagle schematic for the Inty II power board as it doesn't appear to be present in the service manual. I'm pretty certain that it's complete and correct, save for two specific items. I've made notes on the schematic detailing them. Inty_II_Power_Board.zip 2 Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted May 6, 2017 Author Share Posted May 6, 2017 It's the original. Here's what I got from the power supply board; 2 pin/blue wire - 12.68 Ribbon plug; 5.16 11.98 13.81 0 -2.16 Iirc, no flash when resetting, but I will double check this evening. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted May 6, 2017 Share Posted May 6, 2017 (edited) That's definitely not right. You should be getting +5.6V from the wire connected to the 2-plug connector. According to the service manual, the voltages on the 5-wire ribbon cable should be, in order: +5V, +12V, +16V (unregulated), 0V (GND), -2.1V. It looks like the cap that blew is C11 on the schematic. The Mattel service manual lists it as 0.22uF and the Sylvania one lists it as 0.1uF. I can't tell from your picture what the code on the blown cap says to be able to decode it. That said, that particular cap doesn't have anything to do with what you're getting out of the 2-pin connector: it's on the circuit that outputs +12V. I would take a very close look at the transformer and switch assembly. My gut tells me that you've got a short in the switch. It's a triple-pole, single-throw switch. Off the top of my head it looks like a short between S1-C and one of the other two poles could cause you to see an overvoltage on the 5V/-2.1V part of the power board. The fact that you're not getting 16V on pin 3 of the ribbon connector also makes me suspect that the 12V/16V part of the board is losing current from a potential short in the switch or somewhere along that pathway. Edited May 6, 2017 by JohnPCAE Quote Link to comment Share on other sites More sharing options...
mr_me Posted May 6, 2017 Share Posted May 6, 2017 If it's unregulated would that voltage be loaded or unloaded. Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted May 6, 2017 Author Share Posted May 6, 2017 The blown C11 is on the original supply. I got an eBay donor system to replace the original transformer. I could hear it cooking itself internally. Once I slapped on the donor transformer, that's when the C11 blew. I'll swap switches and see what happens, then get a new one to try. Quote Link to comment Share on other sites More sharing options...
HunterZero Posted May 7, 2017 Share Posted May 7, 2017 The "16V unregulated" reads about 22-25V without load IIRC. Did you check voltages coming from the transformer? You should get: Yellow Lead to Blue Lead - 18 VAC Green/Yellow lead to any Green - 9.25 VAC Green Lead to Green Lead - 18.5 VAC No flash on reset means the STIC is not working. If you have a spare you could try swapping the STIC. Quote Link to comment Share on other sites More sharing options...
HunterZero Posted May 7, 2017 Share Posted May 7, 2017 Across the 2 pin connector on the power supply board should be 12V. Apart from the unregulated voltage, everything else looks in spec. Quote Link to comment Share on other sites More sharing options...
JohnPCAE Posted May 7, 2017 Share Posted May 7, 2017 Are you sure? The schematic says +5.6V. The Sylvania schematic also says it should be 5V. Quote Link to comment Share on other sites More sharing options...
HunterZero Posted May 7, 2017 Share Posted May 7, 2017 100% sure. Mine measures 11.69V across those two pins. Watch from 1:30: Quote Link to comment Share on other sites More sharing options...
HunterZero Posted May 7, 2017 Share Posted May 7, 2017 Note the above vid is not mine And when I measure the unreg voltage it measures 23V and doesn't discharge to 0V. Maybe the meter he is using? Quote Link to comment Share on other sites More sharing options...
SiberianSpForces Posted May 7, 2017 Author Share Posted May 7, 2017 I swapped STIC's and still a black screen, but if I run a small Flathead or Allen key over the reset pad, it will flash vertical b&w lines and rarely purple/green flashes. Quote Link to comment Share on other sites More sharing options...
HunterZero Posted May 7, 2017 Share Posted May 7, 2017 No obvious issues visually with the board? Scorch marks? No broken small caps? Check the driver transistors near the CPU and electrolytics (although in my experience the SHOEI caps are quality and hold up well). If you have a logic probe or scope you can start checking for clock/data pulses on IC pins. Since you have spares, try resocketing or swapping the CP1610, RA-3-9600 SRAM and PROM/SROM. Check the sockets themselves are good too. Quote Link to comment Share on other sites More sharing options...
HunterZero Posted May 7, 2017 Share Posted May 7, 2017 And still concerned that your unreg volts are low - what did the AC from the transformer read? Quote Link to comment Share on other sites More sharing options...
