tschak909 Posted April 15, 2017 Share Posted April 15, 2017 Hi guys, chugging along on the first bits of a programmer text editor that uses CIO functions for output (so that it is compatible with lots of display outputs). But I'm scratching my head a bit... I of course, can read whether a character is gated via CH, and I do so, to tell CIO to grab the ATASCII key from the K:eyboard...but after the CIOV happens, I get back a 0, regardless, and it hangs from that point..._YET_ when I run from Amoeba, I can get the correct behavior that I'm looking for (because it's obviously clearing something). My example code uses the value to set background color, (just so i can debug the thing for now and get it right)...and I'm really scratching my head, because it's something so simple, but I'm missing it... ?? ATARI Macro Assembler Ver 1.0C Page 1 KEYPUNCH EDITOR FOR ATARI D2:MAIN.ASM MAIN FILE ? LIST D, I 0000 ;** ;* MAIN.ASM - MAIN FILE ;* -------------------- ;* THE MAIN FILE TO ASSEMBLE FOR THE ;* EDITOR. ;** 0000 = 2000 ORG $2000 INCLUDE D2:CIOEQU.ASM ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ATARI Macro Assembler Ver 1.0C Page 2 KEYPUNCH EDITOR FOR ATARI D2:CIOEQU.ASM CIO EQUATES ? 2000 ;*********************************** ;* CIO EQUATES ;*********************************** = 0003 OPEN EQU $03 = 0004 OREAD EQU $04 = 0008 OWRITE EQU $08 = 0005 GETREC EQU $05 = 0007 GETCHR EQU $07 = 0009 PUTREC EQU $09 = 000B PUTCHR EQU $0B = 000C CLOSE EQU $0C 2000 453A9B EDEVICE DB 'E:',$9B 2003 4B3A9B KDEVICE DB 'K:',$9B = 0000 IOCB0 EQU $00 = 0010 IOCB1 EQU $10 = 0020 IOCB2 EQU $20 = 0030 IOCB3 EQU $30 = 0040 IOCB4 EQU $40 = 0050 IOCB5 EQU $50 = 0060 IOCB6 EQU $60 = 0070 IOCB7 EQU $70 = 0054 ROWCRS EQU $0054 = 0055 COLCRS EQU $0055 ; ATASCII CHARS = 007D CH_CLR EQU $7D = 001C CH_UP EQU $1C = 001D CH_DN EQU $1D = 001E CH_LF EQU $1E = 001F CH_RT EQU $1F = 00A0 CH_LIN EQU $A0 INCLUDE D2:EDIT.ASM ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ? ATARI Macro Assembler Ver 1.0C Page 3 KEYPUNCH EDITOR FOR ATARI D2:EDIT.ASM MAINLINE EDITOR CODE ? 2006 ;** ;* EDIT.ASM - THE MAIN EDITOR ;** 2006 = 0001 NUMROWS DS 1 2007 = 0001 NUMCOLS DS 1 2008 = 0001 TEMP1 DS 1 2009 = 0001 KEYBUF DS 1 200A START ; OPEN KEYBOARD IOCB: 200A A210 LDX #IOCB1 200C A903 LDA #OPEN 200E 9D4203 STA ICCOM,X 2011 A904 LDA #OREAD 2013 9D4A03 STA ICAX1,X 2016 A900 LDA #$00 2018 9D4B03 STA ICAX2,X 201B A903 LDA #LOW KDEVICE 201D 9D4403 STA ICBAL,X 2020 A920 LDA #HIGH KDEVICE 2022 9D4503 STA ICBAH,X 2025 2056E4 JSR CIOV ; CLOSE THE EDITOR IOCB: 2028 A200 LDX #IOCB0 202A A90C LDA #CLOSE 202C 9D4203 STA ICCOM,X 202F A900 LDA #$00 2031 9D4A03 STA ICAX1,X 2034 9D4B03 STA ICAX2,X 2037 2056E4 JSR CIOV ; OPEN EDITOR BACK UP. 203A A903 OPENED LDA #OPEN 203C 9D4203 STA ICCOM,X 203F A908 LDA #OWRITE 2041 9D4A03 STA ICAX1,X 2044 A900 LDA #$00 2046 9D4B03 STA ICAX2,X 2049 A900 LDA #LOW EDEVICE 204B 9D4403 STA ICBAL,X 204E A920 LDA #HIGH EDEVICE 2050 9D4503 STA ICBAH,X 2053 2056E4 JSR CIOV ; AND SEND EXPLICIT CLEAR 2056 A90B EDCLR LDA #PUTCHR 2058 9D4203 STA ICCOM,X 205B A908 LDA #OWRITE 205D 9D4A03 STA ICAX1,X 2060 A900 LDA #$00 2062 9D4B03 STA ICAX2,X 2065 9D4403 STA ICBAL,X 2068 9D4503 STA ICBAH,X 206B 9D4803 STA ICBLL,X ? ? ? ? ? ATARI Macro Assembler Ver 1.0C Page 4 KEYPUNCH EDITOR FOR ATARI D2:EDIT.ASM MAINLINE EDITOR CODE ? 206E 9D4903 STA ICBLH,X 2071 A97D LDA #CH_CLR 2073 2056E4 JSR CIOV ; DETERMINE SCREEN SIZE BY SENDING ; AN UP ARROW, AND A LEFT ARROW ; CHARACTER, WHICH WILL MAX OUT ; ROWCRS AND COLCRS, AND THEREBY GIVE ; US THE MAXIMUM TERMINAL SIZE. 2076 A91C TRMSIZ LDA #CH_UP 2078 2056E4 JSR CIOV 207B A91E LDA #CH_LF 207D 2056E4 JSR CIOV 2080 A554 LDA ROWCRS 2082 8D0620 STA NUMROWS 2085 A555 LDA COLCRS 2087 8D0720 STA NUMCOLS ; NOW DO AN INITIAL DRAW OF SCREEN. 208A A900 INIDRW LDA #$00 208C 8555 STA COLCRS 208E AC0620 LDY NUMROWS 2091 88 DEY 2092 8454 STY ROWCRS 2094 AC0720 LDY NUMCOLS 2097 C8 INY 2098 8C0820 STY TEMP1 209B A9A0 DRWLIN LDA #CH_LIN 209D 2056E4 JSR CIOV 20A0 CE0820 DEC TEMP1 20A3 D0F6 ^209B BNE DRWLIN ; AND SET SCREEN TO 0,0 20A5 A900 INIHOM LDA #$00 20A7 8554 STA ROWCRS 20A9 8555 STA COLCRS 20AB A920 LDA #$20 20AD 2056E4 JSR CIOV ; INITIAL KEY INPUT ROUTINE 20B0 ADFC02 KEYRT LDA CH 20B3 C9FF CMP #$FF 20B5 F0F9 ^20B0 BEQ KEYRT 20B7 A210 KEYINI LDX #IOCB1 20B9 A907 LDA #GETCHR 20BB 9D4203 STA ICCOM,X 20BE A904 LDA #OREAD 20C0 9D4A03 STA ICAX1,X 20C3 A900 LDA #$00 20C5 9D4B03 STA ICAX2,X 20C8 9D4803 STA ICBLL,X 20CB 9D4903 STA ICBLH,X 20CE 2056E4 KEYGET JSR CIOV ? ? ? ? ? ATARI Macro Assembler Ver 1.0C Page 5 KEYPUNCH EDITOR FOR ATARI D2:EDIT.ASM MAINLINE EDITOR CODE ? 20D1 8DC602 STA $02C6 20D4 4CB020 JMP KEYRT ; SIT AND SPIN 20D7 4CD720 LOOP JMP LOOP 20DA = 02E2 ORG $02E2 02E2 0A20 DW START no ERRORs, 140 Labels, $444A free. ? ? any ideas? Feel free to thwap me upside the head. -Thom keypunch_backup.atr Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 15, 2017 Share Posted April 15, 2017 You're running your program off of an INIT segment instead of a RUN segment, so IOCB #1 is still open by DOS to the executable and not the keyboard. Altirra> .iocb CIO IOCBs: # Dev Cd St Bufr PutR BfLn X1 X2 X3 X4 X5 X6 ZP D2: 07 88 2003 0D04 0000 04 00 62 0D 10 00 0 E: 0B 01 0000 F2AF 0000 08 00 00 00 00 00 1 D2: 07 88 2003 0D04 0000 04 00 00 00 00 01 2 0C 01 0000 E4DB 0000 00 00 00 00 00 00 3 0C 01 0000 E4DB 0000 00 00 00 00 00 00 4 0C 01 0000 E4DB 0000 00 00 00 00 00 00 5 0C 01 0000 E4DB 0000 00 00 00 00 00 00 6 0C 01 0000 E4DB 0000 00 00 00 00 00 00 7 0C 01 0000 E4DB 0000 04 00 00 00 00 00 By the way, testing CH isn't a reliable way of determining if K: will return since some keys like Caps Lock are eaten internally by that device. If you want to block, just read from K:. If you don't want to block, then you'll probably have to do like TBXL and have a lookup table of scancodes that don't cause K: to return. 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 15, 2017 Author Share Posted April 15, 2017 *BLUSH* thanks. as for scancodes, I really thought I could just ignore anything past $C0 .... shit. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 15, 2017 Author Share Posted April 15, 2017 also found the correct way to specify the run address. (the END keyword can take a run address without having to explicitly org and set a word.) -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 15, 2017 Author Share Posted April 15, 2017 phaeron, would it be better to just talk to POKEY directly to determine if a key is pressed ? -Thom Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 15, 2017 Share Posted April 15, 2017 You could do that, but then you'd be responsible for all of the auxiliary functions that the keyboard interrupt does -- like auto-repeat, debouncing, and clearing attract mode. It's a bit easier to just replace K:, and continue to use the OS keyboard IRQ handler. You'll still need to handle scancode-to-ATASCII conversion, Caps Lock, and Inverse functionality. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 16, 2017 Share Posted April 16, 2017 You can also get undesired behaviour allowing all keycodes <$C0. CTRL-1 will pause screen output if you're echoing to S: or E: or plotting pixels using S: It doesn't generate an Ascii code, in fact the pause flag toggling is dealt with in the key IRQ. CTRL-3 indicates EOF condition for the device. For that reason you should have a branch if negative after the CIO call to read keys to deal with that. This key combo is detected at the K: read level so you could test for it and mask it beforehand. You'd probably want to wrap SEI/CLI around the test and CIO call if masking keys in case they occur in between test and K: handler calls. You could probably get away with a 64 byte key lookup table. Then hardcode what's needed to deal with the likes of Caps Lock, Help, F1-F4 etc. Actually you could probably use the high bit in a keyboard table to signify special keys then have a second table with those keycodes and jump addresses to deal with them. 1 Quote Link to comment Share on other sites More sharing options...
