tschak909 Posted April 16, 2017 Share Posted April 16, 2017 Before I go writing out my own, is there a routine in the Atari OS to convert a word to an atascii #? -Thom Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 16, 2017 Share Posted April 16, 2017 Atascii is virtually the same as ASCII for the visible non-graphic characters. The main differences are stuff like cursor movement, delete character, line etc. In some cases such codes don't even exist in normal ASCII and when they do they're usually in the 1-31 range. Probably the closest thing to such conversion is in the S: routine to do text mode character output. Since "screen codes" are different to ATASCII in many cases the top 2 bits are used as index into a table where the character is modified so it displays properly. For doing conversion from Atascii to Ascii and back, an efficient way would probably be to do bounds check to whitelist valid characters then a table with Atascii to Ascii values for characters not whitelisted should do for the remainder. The control chars for Atascii are spread around somewhat but most (all?) for plain Ascii are in that 1-31 range. Quote Link to comment Share on other sites More sharing options...
phaeron Posted April 16, 2017 Share Posted April 16, 2017 If you're looking for a number printing routine, the OS routines would be IFP + FASC in the math pack, though not that fast. You're better off doing it by hand -- either shift bits left out of the word in binary mode while shifting bits in left in decimal mode and then use a hex-to-ATASCII routine, or just count off digits at a time. Quote Link to comment Share on other sites More sharing options...
drac030 Posted April 16, 2017 Share Posted April 16, 2017 though not that fast. Precisely for what purpose they are not fast enough? Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 16, 2017 Share Posted April 16, 2017 (edited) I would venture that if you want to have a status line in a text editor showing things like file position, row and column and free RAM constantly updated after every keystroke and redraw of the screen (the latter usually being expensive enough in itself), calling the OS FP pack to generate integer strings isn't the best use of machine cycles. Edited April 16, 2017 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 16, 2017 Author Share Posted April 16, 2017 ok, that's what I wanted to know. I figured. -Thom Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 16, 2017 Share Posted April 16, 2017 Loads of useful examples at Codebase64. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 16, 2017 Author Share Posted April 16, 2017 I found a nice 8-bit ascii output here: http://6502org.wikidot.com/software-output-decimal -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 16, 2017 Author Share Posted April 16, 2017 Yup, that worked out well... 2006 DISP8 PROC 2006 A202 LDX #02 2008 A04C LDY #$4C 200A 8C5820 .1 STY .B 200D 4A LSR A 200E 2A .2 ROL A 200F B005 ^2016 BCS .3 2011 DD5520 CMP .A,X 2014 9004 ^201A BCC .4 2016 FD5520 .3 SBC .A,X 2019 38 SEC 201A 2E5820 .4 ROL .B 201D 90EF ^200E BCC .2 201F A8 TAY 2020 AD5820 LDA .B 2023 202D20 JSR OUTPUT 2026 98 TYA 2027 A013 LDY #$13 2029 CA DEX 202A 10DE ^200A BPL .1 202C 60 RTS 202D 48 OUTPUT PHA ; PUSH A 202E 8A TXA 202F 48 PHA ; PUSH X 2030 98 TYA 2031 48 PHA ; PUSH Y 2032 A200 LDX #$00 ; IOCB 0 2034 A90B LDA #$0B ; PUTCHR 2036 9D4203 STA ICCOM,X 2039 A908 LDA #$08 ; OWRITE 203B 9D4A03 STA ICAX1,X 203E A900 LDA #$00 2040 9D4B03 STA ICAX2,X 2043 9D4803 STA ICBLL,X 2046 9D4903 STA ICBLH,X 2049 AD5820 LDA .B ; DIGIT IN A 204C 2056E4 JSR CIOV 204F 68 PLA ; PULL Y 2050 A8 TAY 2051 68 PLA ; PULL X 2052 AA TAX 2053 68 PLA ; PULL A 2054 60 RTS 2055 80A0C8 .A DB 128,160,200 2058 = 0001 .B DS 1 EPROC ; END DISP8 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 17, 2017 Author Share Posted April 17, 2017 Anyone have a favorite for outputting ascii from a 16-bit value in registers? -Thom Quote Link to comment Share on other sites More sharing options...
JamesD Posted April 17, 2017 Share Posted April 17, 2017 Anyone have a favorite for outputting ascii from a 16-bit value in registers? -Thom 16 bit value? ASCII is 8 bit. That's either two characters or you need to dump the most significant byte. As for output on the Atari... someone else will have to answer that. One question... output how? To the screen? Or to a device? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 17, 2017 Author Share Posted April 17, 2017 yes, sorry, to take a 16 bit binary value, and output as an ascii string from 0 to 65535. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 17, 2017 Author Share Posted April 17, 2017 The routine I posted above does this for an 8 bit quantity...and in an insanely bizarre and clever way. -Thom Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 17, 2017 Share Posted April 17, 2017 I favour a table (10000, 1000, 100, 10): subtract each from the number while number>=table value and keep count. Count+ASC("0") yields digit. What's left over at the end is the unit. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 18, 2017 Author Share Posted April 18, 2017 Found this, but have been unable to get it to work properly... OUTDEC16Z LDX #4 LDY #$26 .1 LDA VALUELO CMP TABLO,X LDA VALUEHI SBC TABHI,X BCC .3 .2 LDA VALUELO SBC TABLO,X STA VALUELO LDA VALUEHI SBC TABHI,X STA VALUEHI SEC .3 TYA ROL A BCS .4 TAY ASL VALUELO ROL VALUEHI BCS .2 BCC .1 .4 JSR OUTPUT LDY #$13 DEX BPL .1 RTS .VALUELO DB 0 .VALUEHI DB 0 .TABLO DB $00,$00,$00,$00,$40 .TABHI DB $40,$50,$64,$7D,$9C Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 18, 2017 Share Posted April 18, 2017 (edited) Works fine for me - you need to supply an OUTPUT sub. It then stores or prints the digits (high thru low without stripping leading zeros). The sub needs to preserve registers and not otherwise disturb the main part. I pasted into a Mac-65 emulated instance and adjusted to work there. I've used locations $4000-1 to hold the 16-bit input value (lo/hi). *= $8000 .OPT OBJ,NO LIST OUTDEC16Z LDX $4000 LDY $4001 STX VALUELO STY VALUEHI LDA #0 STA OUTIND LDX #4 LDY #$26 BR1 LDA VALUELO CMP TABLO,X LDA VALUEHI SBC TABHI,X BCC BR3 BR2 LDA VALUELO SBC TABLO,X STA VALUELO LDA VALUEHI SBC TABHI,X STA VALUEHI SEC BR3 TYA ROL A BCS BR4 TAY ASL VALUELO ROL VALUEHI BCS BR2 BCC BR1 BR4 JSR OUTPUT LDY #$13 DEX BPL BR1 RTS BRK OUTPUT STY SAVEY LDY OUTIND STA RESULT,Y INC OUTIND LDY SAVEY RTS VALUELO .BYTE 0 VALUEHI .BYTE 0 TABLO .BYTE $00,$00,$00,$00,$40 TABHI .BYTE $40,$50,$64,$7D,$9C OUTIND .BYTE 0 SAVEY .BYTE 0 *= $8100 RESULT .BYTE "00000" Edited April 18, 2017 by Rybags Quote Link to comment Share on other sites More sharing options...
+David_P Posted April 18, 2017 Share Posted April 18, 2017 Do you need to output decimal, or could you output in hex? If you can do the latter, life just got a lot easier. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted April 18, 2017 Author Share Posted April 18, 2017 David_P: Well, these are for user outputs, such as row, column so.. Rybags: oh, thanks, I was close... I just find it odd that given that you often need to display numbers etc in a routine that more individuals wouldn't have fast outputs for 8 or 16-bit quantities to ASCII (ATASCII). Meanwhile, I am in the middle of studying buffer gap implementations, so I can fully understand what I need to do. -Thom Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 18, 2017 Share Posted April 18, 2017 Doing hex output is easy given that it's directly related to powers of 2, but of course not real user-friendly. For most applications it's just easier to do calculations in BCD which is easy to convert and output. Some games in fact just work directly with ASCII or even screen codes. Binary not necessarily as useful as you'd think - additional to the pain of converting to decimal, you don't get much range with only a 16-bit value. So really it's just easier to use 3 bytes worth of BCD which gives a 1 million range. It's only if you're dealing with big arrays of data that you'd worry about the storage disadvantage. Quote Link to comment Share on other sites More sharing options...
drac030 Posted April 18, 2017 Share Posted April 18, 2017 I would venture that if you want to have a status line in a text editor showing things like file position, row and column and free RAM constantly updated after every keystroke and redraw of the screen (the latter usually being expensive enough in itself), calling the OS FP pack to generate integer strings isn't the best use of machine cycles. What I mainly mean is that the slowness of the FP package is often greatly (or even grossly) overestimated. Roughly estimating, a call to IFP/FASC occupies about 30 scanlines - not specially fast, but at the other hand, how many times per second one needs to do that conversion? After a keystroke it would not be noticeable, and why it should be called after every screen redraw, I cannot see. But even if, IFP/FASC is fast enough for most applications, and certainly it is not worth to waste RAM for a custom routine which is faster while 99% of the time the program spends waiting for a keystroke. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 18, 2017 Share Posted April 18, 2017 (edited) I feel that if effort has been expended making the editor's screen redraw as efficient as possible, it's worth ensuring that re-displaying - say - four numbers after each keystroke (totalling 120 scan lines plus rendering overhead using your FP package estimate) doesn't introduce unnecessary lag. It's rather like the adage "look after the pennies and the pounds will look after themselves", which is to say that if the worker routines (display, number conversion) are kept efficient, code which repeatedly calls this stuff from higher up will stay responsive. In addition, my perception is that it seems wasteful to convert an integer to FP, then an FP value to a string when all we want to do is display an 8 or 16-bit integer value. I realise that saving cycles isn't the only concern, but a text editor is a good example of an application which does a sufficient amount of heavy redrawing that it's wise to spend a lot of time optimising anything which might introduce unnecessary lag. EDIT: Another bonus when using the table approach is that you can employ a couple of simple flags and get leading zeros and/or right justification for free, while with the INT/FP/ASCII conversion you need to scan the buffer to get the length of the string and then pad it after the event. Edited April 18, 2017 by flashjazzcat Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 18, 2017 Share Posted April 18, 2017 Another reason not to use the FP - it frees up plenty of zero-page area that would otherwise only be usable temporarily. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted April 18, 2017 Share Posted April 18, 2017 Another reason not to use the FP - it frees up plenty of zero-page area that would otherwise only be usable temporarily. Good point... forgot that one, and it's one of the best reasons. Quote Link to comment Share on other sites More sharing options...
drac030 Posted April 18, 2017 Share Posted April 18, 2017 (edited) This is only important when someone is truly short of the 84 free bytes at $80-$d3. It is not a problem in most programs, though. I do realize that IFP/FASC is not the fastest, but my point is that its use is very simple (two jsr calls and you are done with the conversion) and really few programs are so time critical to need such a routine faster. I may be wrong, but I think that even in a text editor in a really bad case when a keystroke causes the entire screen to be redrawn (inserting a character in the first line of the screen, which causes re-folding all the remaining lines being displayed) calling the IFP/FASC should not cause a noticeable effect, because hardly anyone can type more than 4-5 characters per second, and the IFP/FASC pair can do 500 conversions per second. So in any case most CPU time will be consumed by the screen redraw and only a tiny fraction of it by the numeric conversion through FP. PS. Speaking of folding: why the AAge reply field does not fold lines? It is a bit annoying. Edited April 18, 2017 by drac030 Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 18, 2017 Share Posted April 18, 2017 This version of the forum software is weird and I reckon has some annoying bugs. I've twice put in sections of code, looks fine on the first 1 or 2 previews then for whatever reason the next time gets double-spaced. Quote Link to comment Share on other sites More sharing options...
