Antonia 4MB or Ultimate 1MB which one and why?
14 replies to this topic
#1 scotty OFFLINE
scotty
    Moonsweeper
  • 357 posts
  • I have, but have **YOU** played Atari today?
Posted Sun Apr 16, 2017 1:17 PM
Things i like about each...
Ultimate 1MB
Lotharek - Class act.  Dealt with him before
RTC
still uses 6502 for full comparability
Sparta Dos X built in
Hardware write protect
More popular - easier to get help
Antonia 4MB
4X the memory
8 OS slots
W65C816 CPU
HELP!!
#2 Gunstar ONLINE
Gunstar
    Gunstar
  • 8,758 posts
Posted Sun Apr 16, 2017 2:18 PM
I didn't even know the Antionia had a 65C816 on board. But as far as I know, there is nothing yet in software that takes advantage of 4MB, with 1Mb you have at least Space Harrier, Atari Blast! and maybe a demo or two to use it for something other than ramdisk(s). In my current 1200XL, I'm using older upgrades, but I have an 800XL and 1200XL that I was going to upgrade with all Lotharek device, going with a U1MB, Side 2 and Rapidus, maybe vbxe...
I'm just not convinced I ever need more than 1MB on my Atari, at this point I'm happy with 256/512K Rambo upgrade, unless it's in conjunction with the VBXE.
#3 JamesD ONLINE
JamesD
  • 7,935 posts
Posted Sun Apr 16, 2017 2:21 PM
First I'd check to see if anything you want to run doesn't work with the 65816. That would be the biggest reason not to go with Antonia.
Also, is there anything that only runs on the 65816 you want to run.  That would be the biggest reason to go with the Antonia.
Ease of installation would be the next thing to check.
#4 ProWizard OFFLINE
ProWizard
  • 4,546 posts
  • Into Stampede
Posted Sun Apr 16, 2017 3:34 PM
with 1Mb you have at least Space Harrier...
As far as I know there isn't a file version of Space Harrier taking advantage of the 1Mb in the U1MB. If there is a 1Mb file version, I would love to have it.
#5 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 355 posts
Posted Sun Apr 16, 2017 3:55 PM
If you have more than one Atari 8bit computer, why not get both? U1MB is a must have and if I had to choose only one, it would be the one. Antonia doesn't require any soldering and plugs right in. You can also use Antonia on a stock 16K 600XL without upgrading it to 64K first. 16K to 4Mb in just a few minutes is pretty cool.
#6 scotty OFFLINE
scotty
    Moonsweeper
  • 357 posts
Posted Sun Apr 16, 2017 4:23 PM
Is the Ultimate 1MB compatible with the 130XE?    By compatible, I do not mean can it be installed in the machine, as I already know that to be the case.   What I mean is... Is the Rambo or Compy Shop bank switching compatible with what the 130XE uses, so software intended for the 130XE will run no problem?
Antonia has a 128MB XE listed in its config screen, whereas Ultimate 1MB does not.
Edited by scotty, Sun Apr 16, 2017 4:30 PM.
#7 DrVenkman ONLINE
DrVenkman
  • 2,565 posts
  • Back off, man! I'm a scientist.
Posted Sun Apr 16, 2017 4:47 PM
In a nutshell, yes. Use the 320K or 1088 RAMBO setting in the U1MB for basically a "320XE" or "1088XE" machine configuration.
#8 scotty OFFLINE
scotty
    Moonsweeper
  • 357 posts
Posted Sun Apr 16, 2017 5:24 PM
Awesome!  Thanks for the info.
#9 JamesD ONLINE
JamesD
  • 7,935 posts
Posted Sun Apr 16, 2017 8:16 PM
Except on a 130XE right?  Lucky me.
#10 ndary OFFLINE
ndary
    Moonsweeper
  • 476 posts
Posted Mon Apr 17, 2017 7:27 AM
You can see them in the videos i made
https://www.youtube....h?v=a5lqlkmTvG0
and
https://www.youtube....h?v=xkyXepEq4WI
 Nir
#11 scotty OFFLINE
scotty
    Moonsweeper
  • 357 posts
Posted Tue Apr 18, 2017 6:10 PM
I have seen your videos before.  I really like them.  Never realized it was you.  Thank you, and please keep up the good reviews.
#12 Kyle22 OFFLINE
Kyle22
  • 3,174 posts
Posted Tue Apr 18, 2017 7:16 PM
Personally, I would like to see a CPU/RAM module only.  That way it could co-exist with U1M.  The RAM should start at Bank 1.
00000 - 0FFFF -> Whatever the machine has, nothing touched here.
10000 - FFFFF -> Onboard the device, and logic included to prevent $xDxxx accesses from touching $0Dxxx hardware chips.
This is what I would like to see.
Just my opinion.
Edit: changed 1 to x
Edited by Kyle22, Tue Apr 18, 2017 7:17 PM.
#13 Larry OFFLINE
Larry
  • 3,946 posts
Posted Wed Apr 19, 2017 5:11 AM
U1MB is nice, but can cause video interference in some machines.  More likely if you have something hooked onto the ECI/PBI.  I was never able to get a U1MB to perform without video interference in NTSC 130XE's. (I gave up long ago.)  U1MB has some nice feature not present in Antonia thanks mainly to Flashjazzcat.
As mentioned, Antonia has 65816 cpu. Could cause incompatibility with some games. (?)  I've yet to see any issues with that, but hard-core gamers might chime in.  There is a 65816 OS and a 65816 BASIC interpreter.  It allows limited operations with the linear ram.  There is a 65816 Assembler and provides access to Antonia's linear ram, also.  Antonia is very easy to install, and I have found no video interference.
In hindsight, this would be an easy decision for me in favor of Antonia.  But don't know if they are still being sold. Both would be a good choice, if you care to spend the extra money.
-Larry
#14 Gunstar ONLINE
Gunstar
    Gunstar
  • 8,758 posts
Posted Wed Apr 19, 2017 2:48 PM
Sorry, I didn't realize that, I thought it had several formats like Atari Blast! I guess it's a good thing I have it on cartridge myself. It's an 8Mb AtariMax, so I can re-flash it with Atari Blast! or Space Harrier.
#15 _The Doctor__ OFFLINE
_The Doctor__
  • 3,231 posts
Posted Fri Apr 21, 2017 3:40 PM
correct Space Harrier was on disk during every step until the music was changed and was then re-arranged for AtariMax cartridge. The cartridge form was the only completely and properly stitched together final product. An industrious person could possibly put it back in file/disk form using memory upgraded (1088k) form. as to bank switching or romdisk / yanking the flash save and putting disk save back in.... well the sky is the limit.... but remember in it's final form... DOS is an issue segments of the game become an issue... putting it on cartridge removed a lot of issues... but with some effort and some alchemy it might be a nice project... fast drives and large memory a plus.
