issues with CC Triple Tech
24 replies to this topic
#1 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 2:01 PM
All,
I seem to be having issues setting my date/time on the CC triple tech.  does not seem I can take it past 2013 for some reason.
Battery is good.
Any thoughts ?
#2 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Sun Apr 16, 2017 2:27 PM
That is just too weird!
Have you tried << THIS PROGRAM >> written by the late and great Gazoo and converted to FR99 format by Jedimatt42?
#3 arcadeshopper OFFLINE
arcadeshopper
  • 4,336 posts
Posted Sun Apr 16, 2017 2:52 PM
Pretty sure it only saves 2 digit year
Sent from my LG-H830 using Tapatalk
#4 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 2:54 PM
yup.  that was the first one I tried.
Then I used the typical XB program out of the tripletech manual.
#5 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 3:08 PM
when I go into SETCLOCK it will read the correct day of the week, but even though I put APR in for month it will show when it pulls it back up as 'AT'
#6 atrax27407 OFFLINE
atrax27407
  • 1,256 posts
Posted Sun Apr 16, 2017 5:19 PM
I think the CC works like the BWG- it accepts digital input (i.e., 01=January, 02=February. etc.). The year is 4 digits (i.e., 2017).
#7 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Sun Apr 16, 2017 5:28 PM
Chris,
   I'm not near mine for testing at the moment, but I remember Gazoo telling me that when the printer buffer chip goes bad the cards start acting funny.  He said when the 64K chip is pulled, the cards start acting normally.  If you have an IC extractor, you might want to try that... assuming you do not use the printer buffer.
#8 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 6:03 PM
Chris,
good suggestion.  If i recall correctly Gazoo recommended pulling the Z80 chip a couple of years ago or so.  i'll try that.
Edited by Shift838, Sun Apr 16, 2017 6:14 PM.
#9 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 6:23 PM
i pulled the Z80 chip.
Ran my XB program to set the clock and provided the below variables
Day = 0
Date = 04/16/17
Time = 19:21:00
Ran a program to pull the Day, Date and Time and it returned:
Day = 0
Date = 00/12/13
Time = 11:21:00
So something is off with the card some how.
#10 Schmitzi OFFLINE
Schmitzi
  • 4,525 posts
  • ToXiC
Posted Sun Apr 16, 2017 6:28 PM
does it work with an older date maybe ?
#11 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 7:02 PM
yes it seems to work with anything 2013, but after that it does not.
I remember having an issue with it a couple of years ago because of 2015, but have not messed with it since.
#12 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Sun Apr 16, 2017 7:35 PM
Do you have any other third-party cards in your box?  Battery is new?
Which cartridge is plugged in... grasping at straws here on the last one...
#13 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 8:06 PM
i measured the batter and it is putting out a bit over 3.2 volts so it's good.  I have tried XB 2.7 and standard XB as well as the FR99
#14 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Sun Apr 16, 2017 8:09 PM
What about 3rd party cards?  Anything funky or out of the ordinary?
#15 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Sun Apr 16, 2017 8:21 PM
Does anyone know if they ever updated the firmware?  Could there be two separate versions?  I'm totally stumped Chris.  I plugged in my P-Box for the first time in quite a while and checked mine, everything was right except the time.  It was two minutes slow.
  • Attached File  RTC.jpg   81.24KB   1 downloads
#16 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Sun Apr 16, 2017 8:29 PM
as far as out of ordinary.  I have a few, but all were running with it before.  WHT SCSI, 3MB HRD, SAMS 1024mb.
Not a big deal for now.  I pulled the tripletech for now.  I only had it to put my speech in the PEB and if I decided to run my BBS from the 99/4A, but I decided not to do that.  I still have my speech in the new All In One case.
#17 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,427 posts
Posted Wed Apr 19, 2017 11:10 PM
Day = 0
Date = 04/16/17
Time = 19:21:00
Day = 0
Date = 00/12/13
Time = 11:21:00
IIRC, each digit is converted from BCD to ASCII.  It would appear you have a stuck bit based on how the date values are being masked.
Try re-seating the clock chip and check for any broken resistors or resistor networks.   The time is off by a different bit, however, this could be the result of the program not getting a proper response to whether you are in 24 or 12 hour mode.  Try setting the time to "04:21:00" and "05:21:00" and see what happens.
#18 arcadeshopper OFFLINE
arcadeshopper
  • 4,336 posts
Posted Wed Apr 25, 2018 7:10 PM
Ever get anywhere with this?  Also anybody have a photo of one? I picked up one untested and it has empty sockets..  Assume something's supposed to be there
#19 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Wed Apr 25, 2018 7:30 PM
I have not revisited this since I have been back in the house..(yet).  Been more than a year.  I need to look at it again.
Here are a front and back pick of mine.
#20 arcadeshopper OFFLINE
arcadeshopper
  • 4,336 posts
Posted Wed Apr 25, 2018 8:16 PM
Missing u15 through 22 i assume ram
And the socketed one to the right PIO
corrected last chip..
#21 Flottmann1 OFFLINE
Flottmann1
    Chopper Commander
  • 153 posts
Posted Thu Apr 26, 2018 11:05 AM
here my Triple Tech
#22 arcadeshopper OFFLINE
arcadeshopper
  • 4,336 posts
Posted Thu Apr 26, 2018 12:09 PM
doh pio is for the cable ;)
I will stuff some 4164's in there and see if that helps
Greg
#23 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 594 posts
Posted Sat Apr 6, 2019 7:23 AM
Not really related to the problems here, but just in case anybody would ever need one, I once wrote a unit in Pascal, to be able to use the Triple Tech clock in the p-system.
#24 retroclouds OFFLINE
retroclouds
  • 1,698 posts
Posted Sat Apr 6, 2019 9:35 AM
Why is there a Z80 on the triple tech card? What is the Z80 used for?
#25 apersson850 OFFLINE
apersson850
    Dragonstomper
  • 594 posts
Posted Sat Apr 6, 2019 9:41 PM
To run the printer spooling, I'd presume. Don't see any other reason.
