Impulse buys
35 replies to this topic
#26 Opry99er OFFLINE
Opry99er
  • 9,797 posts
Posted Sun Apr 23, 2017 1:49 PM
I am at work now, so I will take a pic when I get home.
Thanks for the help. :)
#27 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Sun Apr 23, 2017 2:19 PM
Top 2 on the pack ?
#28 Opry99er OFFLINE
Opry99er
  • 9,797 posts
Posted Sun Apr 23, 2017 3:47 PM
IIRC
#29 Schmitzi OFFLINE
Schmitzi
  • 4,340 posts
  • ToXiC
Posted Sun Apr 23, 2017 4:23 PM
which one do you have ? Shugart SA455 ?
Attached File  Shugart-SA455-SA465-Minifloppy-drives.pdf   2.21MB   8 downloads
Attached File  Shugart-SA455-SA465-Service.pdf   5.86MB   6 downloads
#30 Opry99er OFFLINE
Opry99er
  • 9,797 posts
Posted Sun Apr 23, 2017 4:55 PM
I want to say it is this one
https://goo.gl/images/RcpQNf
SA400
Edited by Opry99er, Sun Apr 23, 2017 4:56 PM.
#31 Opry99er OFFLINE
Opry99er
  • 9,797 posts
Posted Sun Apr 23, 2017 8:33 PM
#32 Schmitzi OFFLINE
Schmitzi
  • 4,340 posts
  • ToXiC
Posted Mon Apr 24, 2017 8:02 AM
I found a webpage on that
http://www.swtpc.com...SA400_Index.htm
#33 Lee Stewart OFFLINE
Lee Stewart
  • 3,728 posts
Posted Mon Apr 24, 2017 8:47 AM
The resistor pack is that A-B 314B151 DIP chip next to the shunt DIP socket.  I believe each resistor is 150 Ω.
...lee
#34 marc.hull OFFLINE
marc.hull
  • 1,297 posts
Posted Mon Apr 24, 2017 4:27 PM
Matbe try and pull those copper traces and install a dip switch. The as400 manual says that all 5 lines need termination. Try setting to on pos 1,2,5,6&7.
The manual description does not match the picture so it may be a shot on the dark.
I am also assuming that your 5.25" drive is the only on on the internal cable ?
#35 Opry99er OFFLINE
Opry99er
  • 9,797 posts
Posted Mon Apr 24, 2017 5:03 PM
It is... I have one internal cable with one card edge connector connected to the 5.25" drive.
I believe I have a spare internal cable with two card edge connectors for half height drives, but I have not used that.
My two external drives work perfectly now, so I am not 100% sure what changing the shunt termination configuration would do the drives 2 and 3.
When I get home (If it is early enough) I will pull the drive back out and try to jumper the slots you suggested.
Thanks again. :)
#36 Ksarul OFFLINE
Ksarul
  • 4,741 posts
Posted Mon May 22, 2017 5:11 AM
Here's a source with some new 5.25 disks of the right type for us. . .and the price isn't bad either.
