F18A and XB
28 replies to this topic
#1 Opry99er OFFLINE
Opry99er
  • 8,807 posts
Posted Mon Apr 17, 2017 10:39 AM
Would it be possible to develop a set of assembly routines (linkable via XB) to take advantage of some of the features of the F18A VDP?
I am particularly interested in the extended color sets...
Edited by Opry99er, Mon Apr 17, 2017 10:40 AM.
#2 RXB OFFLINE
RXB
  • 2,905 posts
Posted Mon Apr 17, 2017 11:29 AM
After I get the XB ROMs disassembled and done this is possible.
Just load he F18 version of ROMs.
But it would help if some Assembly programmers would you know pitch in on this.
Edited by RXB, Mon Apr 24, 2017 11:22 AM.
#3 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Mon Apr 17, 2017 12:04 PM
See http://atariage.com/...ssing-f18a-link
#4 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Mon Apr 17, 2017 1:17 PM
The main problem is XB's use of the VDP memory and table locations.  You can't have more colors without using more VRAM, i.e. additional pattern tables, or a larger color table (256 bytes instead of the original 32 bytes), etc.  Rasmus provided a way to get access to the F18A registers from XB (see the link he provided above), but I don't know enough about XB to know if you can rearrange some of the VDP tables to reserve the extra room?
Some things are safe, like scrolling, changing the palette, 32-sprites on a line, etc. because they do not require VRAM use.  But getting more colors for tiles and sprites requires more pattern memory.  Hmm... I just had a thought.  Since V1.6 or so (I'll have to look) the F18A has the ability to limit the number of tiles and move the pattern tables closer together.  This would allow you to have, for example, two pattern tables (i.e. 4-colors per pixel) of 128 tiles, using the same VRAM as the original pattern table.  XB would not know this is happening and it should not cause any problems.  I'll have to review those changes and see what kind of flexibility we have.
#5 Opry99er OFFLINE
Opry99er
  • 8,807 posts
Posted Mon Apr 17, 2017 1:43 PM
Very cool stuff! :)
Thanks guys. I always wanted an "orange" and a "brown" in the palette.
#6 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Mon Apr 17, 2017 4:51 PM
So I looked, and you can change the tile pattern generator "stride" (offset) as of F18A V1.6.  So, how to explain this quickly and easily...
Basically, to get more colors per pixel you need more bits to select a color.  On the original 9918A family, the pattern chooses if the pixel is a foreground or background color, and the color table defines what color is actually displayed.  So with one pixel you get two colors, and in a single byte you can define eight adjacent pixels.  This should be completely familiar to everyone here.
For the F18A to add more color capability, I needed to add more bits per pixel.  There are basically two ways to do this:
1. Use more bits in a byte to select colors.  For example, using two bits in each byte allows for up to four colors (00, 01, 10, 11) per pixel, but now you can only define four pixels in a single byte.  This also has a side effect that it makes all existing pattern definitions incompatible with this kind of color selection.
2. Bit planes.  This is where you take the same bit position from multiple bytes, then combine them to make the color selection.  This is the method used on the NES (which uses a modified 9918A core) and some other systems, so I used this method in the F18A.  Doing this means all existing pattern definitions remain compatible and that newer multi-color patterns only need to add additional bit-planes to define extra colors.
Defining patterns for bit-plane tiles can be somewhat of a pain in the ass, but thankfully Magellan supports the F18A muli-color tile definitions!
Now you have to store the extra bytes that make up the bit-planes for the extra colors.  Since the original Tile and Sprite Pattern Generator Tables (PGT) are 2K in size (256 tiles * 8-bytes per tile = 2048 bytes), when you enable the extra colors (via Enhanced Color Mode (ECM) 2 and 3), the extra pattern data is pulled from VRAM immediately following the original PGT.  Essentially the PGT in ECM2 is 4K, and in ECM3 it is 6K.
For example, say you ware talking about ECM2 (2-bits per color):
Bytes in PGT:
   0 .. 2047 - MSbit of pattern color index
2048 .. 4095 - LSbit of pattern color index
First pixel row for tile 0 in ECM2 requires 2-bytes:
|1 |0 |1 |0 |1 |1 |0 |1 | bits from byte 0
|0 |1 |1 |1 |0 |0 |0 |1 | bits from byte 2048
|10|01|11|01|10|10|00|11| bits form to make color index
| 2| 1| 3| 1| 2| 2| 0| 3| decimal color index for pixel
Because of the extra memory needed for the the additional bit-planes, this can cause problems for XB since it uses VRAM for program and variable storage.  To try and help better utilize VRAM when using ECM2 and ECM3, in V1.6 I added the ability to define how far apart in VRAM the bit-plane tables are.  By making the offset between the bit-planes smaller, you reduce the VRAM requirements with the trade-off that you have fewer unique tiles available.
To implement this there are two bits in VR29 to define the offset size for both Tile and Sprite PGTs:
-- Usable      Memory Used
-- Tiles    ECM0/1  ECM2  ECM3
-- 0-31     256     512   768
-- 0-63     512     1K    1536
-- 0-127    1K      2K    3K
-- 0-255    2K      4K    6K
-- 11 = +256, 10 = +512, 01 = +1K, 00 = +2K (default)
VR29:
      7      6            5              4          3      2          1              0      Bit number (TI numbering)
    >80    >40          >20            >10        >08    >04        >02            >01      Bit value
| Sprite Pattern | Tile Layer 2 | Tile Layer 2 | Tile Pattern | Tile Layer 1 | Tile Layer 1 |
| Generator      | Horziontal   | Vertical     | Generator    | Horizontal   | Vertical     |
| Offset Size    | Page Size    | Page Size    | Offset Size  | Page Size    | Page Size    |
  00 = 2048        0 = 1 page     0 = 1 page     00 = 2048      0 = 1 page     0 = 1 page
  01 = 1024        1 = 2 pages    1 = 2 pages    01 = 1024      1 = 2 pages    1 = 2 pages
  10 =  512                                      10 =  512
  11 =  256                                      11 =  256
So, by setting VR29 to >04 (1024 bytes between bit-plane bytes) and enabling ECM2 (VR49 to >30), you get 2-bits per pixel color for 128 tiles in the same 2K as the original PGT.  The only other concern is that in all the ECMs, the enhanced color attribute table is automatically enabled (this gives you per-tile attributes like x/y flip, priority over sprites, transparency, individual palette select), so the color tables goes from 32 bytes to 256 bytes.  Although in this case only the first 128 entries in the color table would be required.  I'm not sure about XB's use / placement of the color table, but if it could be put somewhere that has the extra room, then this would be totally possible and transparent to XB.
#7 RXB OFFLINE
RXB
  • 2,905 posts
Posted Mon Apr 17, 2017 9:11 PM
Yea a plain console this would be tough at best and you could imbed the Assembly routines into XB GPL then move and executed them from Scratchpad in a Console.
How much space is needed to do this?
Actually you could do this for most modules provided the space needed is to to much.
VDP memory for XB we have:
>0000 - >02FF Screen image table
>0300 - >036F Sprite Attribute table
>0370 - >03EF XB pointers and flags and VDP Rollout buffer
>03F0 - >077F Pattern Character Table
>0780 - >07FF Sprite Motion Table
>0800 - >081F Color Table
>0820 - >08BE Crunch Buffer (XB program lines are converted to tokens here)
>08C0 - >0957 Edit Buffer (lines typed are saved here as you typed them and not tokenized)
>0958 - >0967 Value Stack (used by everything from XB ROM to Floating Point and subroutine GPL)
>0968 - >37D7 XB Stirngs, Dynamic Symbol Tables, Static Symbol Table, PABs.(Numeric values, Line Number Table, Program Space)
As you can see bleed over moving stuff is a issue and major care must be taken to change this, unless you do like I want to do and just rewrite XB ROMs and GPL.
You could currently move some tables but you give up program and string space in return. (TML comes to mind)
Edited by RXB, Mon Apr 17, 2017 9:43 PM.
#8 senior_falcon OFFLINE
senior_falcon
  • 1,051 posts
Posted Tue Apr 18, 2017 5:40 AM
Post #9 in the thread  "80 columns with F18A and Extended BASIC" has the source code for the 80 column routines.  It shows how to reserve additional space in the VDP RAM.  Adapt that to your needs and you can do just what you are talking about.
  • RXB likes this
#9 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Tue Apr 18, 2017 5:53 AM
The second tile layer (TL2) would be a good place [to start] since this is independent of the ordinary tile/character/pattern layer (TL1). The normal XB display routines would continue to work and you could add new ones for TL2.
#10 RXB OFFLINE
RXB
  • 2,905 posts
Posted Tue Apr 18, 2017 11:29 AM
So as it is interrupt driven it can not allow other interrupts like a mouse driver. But 1920 bytes is not bad though.
This could easily be included in XB  with a XB call like CALL F18 that does both a CALL INIT and loads the routine.
#11 PeBo OFFLINE
PeBo
    Dragonstomper
  • 907 posts
Posted Tue Apr 18, 2017 3:14 PM
So how about simply setting dip switch functions through XB?
Even something simple like a CALL INIT to toggle the emulated scanlines on and off?
It would be nice if we lowly basic programmers could have even minimal access to the F18A feature set.
#12 senior_falcon OFFLINE
senior_falcon
  • 1,051 posts
Posted Tue Apr 18, 2017 3:20 PM
Actually, it's not hard to run more than one interrupt routine.  Lets say a routine for a mouse driver is running.  The address of that routine will be at >83C4.  Just before plugging the address of your routine into >83C4, copy the address there into some memory location.  Then load the address of your routine to >83C4 which will turn it on.  When your routine is finished, before returning take a look to see what used to be at >83C4.  If it was >0000 then just return; otherwise branch to that address which is the address of the interrupt routine that was running when you loaded yours.
When the 80 column routines start up, the top of the stack is modified to reserve additional VDP ram.  But the XB roms didn't get the message and when a garbage collection happens they reset the top of the stack to v0968.  The interrupt routine looks to see if there has been a garbage collection.  If so, then it resets the pointers to the top of the stack to be where I want them.  If you tweaked RXB a bit you could handle this automatically.  Find a place in vdp ram to hold the desired address for the top of the stack.  Default would be >0968.  Then something like CALL STACK(2000) would put >2000 there so that garbage collection would know to set the top of the stack to >2000.  Then just a little adjustment to the garbage collection routine and you could reserve as much or as little vdp ram as you want.  I don't think you'd want to do this within a running program.
#13 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Tue Apr 18, 2017 5:47 PM
Rasmus did just that.  See the link he included in post #3 above.  There are functions to write to the VDP registers, which lets you access any of the F18A's enhanced features.
#14 PeBo OFFLINE
PeBo
    Dragonstomper
  • 907 posts
Posted Tue Apr 18, 2017 7:27 PM
Thank you for pointing that out!!
#15 RXB OFFLINE
RXB
  • 2,905 posts
Posted Tue Apr 18, 2017 8:09 PM
You know we will need a different version for SAMS RXB that works with the F18 as there will not be any VDP Stack which will all be in SAMS RAM instead.
And there is a place already designed to hold top of stack: >83BD is top of VDP stack and >83AF is VDP Stack base.
Also there are like 4 other pointers that save copies Top of VDP Stack and VDP Stack base.
More than one stack DATA STACK and VALUE STACK.
TOPSTK  EQU  >8310            Top of data stack pointer
STVSPT  EQU  >8324            Value-stack base
LSUBP    EQU  >8348            Last subprogram block on stack
VSPTR    EQU  >836E           Value stack pointer
RSTK      EQU  >8388            Subroutine stack base
STKMIN  EQU  >83AF            Base of data stack
STKMAX EQU  >83BD            Top of data stack
VRAMVS EQU  >0958             Default base of value stack
These are all the Equates in GPL Source on Stack in XB.
I will put this on my todo list of RXB and RXB SAMS.
Edited by RXB, Tue Apr 18, 2017 8:10 PM.
#16 chue OFFLINE
chue
    Chopper Commander
  • 170 posts
Posted Sat Apr 22, 2017 6:46 AM
I stumbled onto the MLC site and noticed that it supports the F18A.  MLC is a set of extensions for XB.
I don't know enough about either MLC or the F18A to know how complete the support is.  Perhaps the author of MLC can comment on this.  He's a member on this site and started the MLC thread here:
http://atariage.com/...ated/?p=2399547
Here are some of the You Tube videos showing what MLC can do with the F18A:
There are more videos as well as documentation at the MLC site.
#17 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Sat Apr 22, 2017 9:33 AM
It doesn't look like MLC has been updated recently. I wonder if it still works with the latest F18A firmware updates?
#18 Lee Stewart ONLINE
Lee Stewart
  • 3,556 posts
Posted Sat Apr 22, 2017 9:46 AM
Gillaume was on this forum a couple of weeks ago, so perhaps he will be back ere long.
...lee
#19 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Sat Apr 22, 2017 11:19 AM
I changed the counter/timer in v1.6 based on a request from Gillaume. So hopefully it supports the other changes in v1.6.
#20 Retrospect OFFLINE
Retrospect
    Dragonstomper
  • 947 posts
Posted Mon Apr 24, 2017 5:31 AM
One of the only ways I could think of supporting the F18a without assembly was to stack up the sprites more than 4 in a line, I had a horse racing game that did this, but i was told once that not all F18A's are switched that way, is this still the case?
#21 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Mon Apr 24, 2017 11:29 AM
The default number of sprites on a line is selectable via a jumper, as well as via software.  I suspect most people have the setting to allow all 32-sprites on a line, since you get the most benefit from that.  Don't worry about everyone else though, write your games for yourself and let others adjust to you. ;-)
#22 Opry99er OFFLINE
Opry99er
  • 8,807 posts
Posted Mon Apr 24, 2017 1:03 PM
Matthew, can you INIT the 32 SPRITEs on a line at the start of your program (or vice versa)? The question would then be, "how do you reset back to the system default?"
Perhaps a memory location could be read prior to initialization of the setting... then set it, then (on program exit) reset back to standard if necessary.
Edited by Opry99er, Mon Apr 24, 2017 1:04 PM.
#23 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Mon Apr 24, 2017 1:31 PM
The F18A has a reset function that you can call in a quit key handler, but if the user presses a hard reset button the code will not be called.
In Skyway I have the opposite issue: I'm relying on the 4 sprites per line limitation to mask off sprites when they reach the lower third of the screen. But the jumper setting that most people are using on their F18As means that this trick doesn't work. So I will have to detect the F18A and set up the #sprites-per-line register in order to make my code work as intended, which is a bit annoying (note that I haven't actually done this yet).
#24 Opry99er OFFLINE
Opry99er
  • 8,807 posts
Posted Mon Apr 24, 2017 2:17 PM
I look forward to seeing your implementation. :)
#25 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Mon Apr 24, 2017 3:44 PM
Using Rasmus' functions for XB you can unlock the F18A and access the settings you need.  The F18A can set the number of sprites on a line from 1 to 32 by writing the value (1..32) to VR30.  If you write a 0 (zero) to VR30, if will reset the sprite max to the jumper setting (4 or 32).  Thus you can unlock, set your limit to 32, then when you are done you can reset to the user's default.
You can also unlock the F18A, change some of the enhanced settings, then relock the F18A if you don't want it to remain unlocked.  You might do this because certain things are enabled when you unlock the F18A that might cause undesirable side effects in the XB environment.  Probably not necessary, but it is possible if you need it.
