-Atari 800XL "U" key error
atari800xl keyboard atari8bit atari 800xl atari 8bit atari 800 atari800
8 replies to this topic
#1 Drummerboy OFFLINE
Drummerboy
    Star Raider
  • 76 posts
  • Musician (Drummer) - Announcer
  • Location:America - Behind Microphone or Drums Set Close to any Amiga
Posted Mon Apr 17, 2017 6:01 PM
Hello,
I just was using this Atari 800XL, and without reason, the "U"  key seems as pressed but nobody is pressing the key. (see video, sorry for quality and few background sounds.  :ponder: ).  https://youtu.be/msnZSZTz8a0
Dirty?, maylar issues?, key system broke?
Any suggest, comments, are welcome.
Best Regards.  :waving:
Edited by Drummerboy, Mon Apr 17, 2017 6:03 PM.
#2 kheller2 OFFLINE
kheller2
  • 1,348 posts
Posted Mon Apr 17, 2017 6:50 PM
Have you tried taking the U keycap off and seeing if anything is stuck and what type of keyboard you have?
#3 _The Doctor__ ONLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,540 posts
Posted Mon Apr 17, 2017 7:12 PM
Pull straight up, supported on opposite side evenly. I have seen one too many 800's and XL's damaged when keys are pried up on just one side...
#4 Kyle22 OFFLINE
Kyle22
  • 3,884 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Mon Apr 17, 2017 7:25 PM
Unplug the keyboard. If the U key stops, your keyboard is stuck.  If it Does Not stop, remove the key decoder chips.  If it Still doesn't stop, you have a bad POKEY.
Of course, look for simple things first. A staple could have fallen in one of the vent slots and be sitting in just a certain spot... You never know.
Hope this helps.
#5 Drummerboy OFFLINE
Drummerboy
    Star Raider
  • 76 posts
Posted Mon Apr 17, 2017 7:44 PM
Yeah, i pull straight up on opposite side evely and fixed.
I tried before post this, but evidently not do enough steady.
Thanks!
#6 Drummerboy OFFLINE
Drummerboy
    Star Raider
  • 76 posts
Posted Mon Apr 17, 2017 7:46 PM
Hope this helps.
Thanks for the tip I'll keep it in mind for next eventual issues.
#7 Drummerboy OFFLINE
Drummerboy
    Star Raider
  • 76 posts
Posted Mon Apr 17, 2017 7:51 PM
You know, i am not sure what kind of keyboard model is but is different to the keyboard on other Atari 800XL for sure. This is more tight than the other, and keys surface you can feel little texturized.
#8 squonk OFFLINE
squonk
    Space Invader
  • 24 posts
Posted Mon Apr 17, 2017 10:28 PM
I had something similar with my 800XL, with my '.' key.  On the underside of the keyboard assembly there's an array of tiny screws holding the mylar in place.  I backed the screw that was near the . key out just a little bit, maybe half a turn, and it relieved the pressure that was forcing the contacts together.  My keyboard has worked perfectly since.
Give it a try.
#9 Ely OFFLINE
Ely
    Chopper Commander
  • 129 posts
Posted Tue Apr 18, 2017 4:07 AM
Give it a try.
Ah that's very interesting I have exactly this issue on my 800XL although it comes and goes. I'll have to have a look to see if this fixes it for good.
Also tagged with one or more of these keywords: atari800xl, keyboard, atari8bit, atari 800xl, atari 8bit, atari 800, atari800
