TI program to dump a diskette image to WDS1.
11 replies to this topic
#1 aftyde OFFLINE
aftyde
    Chopper Commander
  • 231 posts
Posted Mon Apr 17, 2017 9:49 PM
Hi All,
Looking for a program like DSK2PC that can back a diskette image up to a SCSI hard disk.  I am currently using DSK2PC which is awesome - but it would be so much faster if I could archive a diskette image to the hard disk.  Any solutions out there that support something other than a disk number (WDS1.DISKS. or SCS1.DISKS.)
Cheers, Arthur...
#2 arcadeshopper ONLINE
arcadeshopper
  • 2,840 posts
Posted Mon Apr 17, 2017 10:10 PM
Attached File  scn2.jpg   25.7KB   3 downloads
like this?
V9T9 FORMAT ea5
#3 aftyde OFFLINE
aftyde
    Chopper Commander
  • 231 posts
Posted Wed Apr 19, 2017 7:57 AM
Can't seem to figure out what to do with this?  Is it a FR99 image?  Can't seem to figure out what to do with this?!?  :)
#4 Schmitzi ONLINE
Schmitzi
  • 4,084 posts
  • ToXiC
Posted Wed Apr 19, 2017 12:06 PM
hmm, I also tried it in Classic99.  Maybe has to be burned on a cartridge like UberGrom ?
#5 mizapf OFFLINE
mizapf
  • 2,894 posts
Posted Wed Apr 19, 2017 1:40 PM
Easy, just a E/A 5 file.
- Using TIImageTool, I imported the bin file on a disk image (Edit->Import Files, File Type = All files, enter directory, double click on the file name)
- Then I ran it in E/A option 5 in MAME.
TIMT could be used to easily copy files on a SCSI drive, but the drive must first be dumped to an image file.
#6 Schmitzi ONLINE
Schmitzi
  • 4,084 posts
  • ToXiC
Posted Wed Apr 19, 2017 2:52 PM
Hi, what is this, an "E/A 5"-File ?
I only know these files on a floppydisk or inside a .DSK-file, mostly 3 files, with the last letter going up in sequence,
which are started with the Editor/Assembler-Cartrdidge, via Option 5 "Run Program File"
But this here is 1 file only and does end on .BIN
And how to get this one here running on a real TI ? Any idea ?
#7 mizapf OFFLINE
mizapf
  • 2,894 posts
Posted Wed Apr 19, 2017 3:05 PM
The BIN file is a TIFILES-like format (from v9t9), without the "TIFILES" header but with the directory entry for that file. When you import it on a disk image (i.e. a DSK file), it becomes a PRG file on that image that can be loaded in Editor/Assembler option 5. Hence, it is a "E/A5 file" exported from a disk image in that v9t9 format.
#8 mizapf OFFLINE
mizapf
  • 2,894 posts
Posted Thu Apr 20, 2017 7:07 AM
@Arthur: Did I understand you correctly, you have a SCSI drive at your TI (via a Whtech or ASCSI controller)? And you want to copy floppy disk contents to that drive? Is it a mechanical drive or a memory card (via SCSI2SD)?
#9 Schmitzi ONLINE
Schmitzi
  • 4,084 posts
  • ToXiC
Posted Thu Apr 20, 2017 8:22 AM
ah thanks, so we have a .DSK now :)
Attached File  DISK2FILE-EA5-V9T9.dsk   90KB   3 downloads
#10 arcadeshopper ONLINE
arcadeshopper
  • 2,840 posts
Posted Thu Apr 20, 2017 3:02 PM
vi9t9 format = its a binary file for the ti saved in v9t9 header format aka fiad for v9t9, tidir will find it if you put it in a directory, also hdx too which is where i grabbed it from my hdx files directory..
ea5 = EDITOR ASSEMBLER option 5  PROGRAM  so you run it from EA with option 5
Greg
#11 aftyde OFFLINE
aftyde
    Chopper Commander
  • 231 posts
Posted Thu Apr 20, 2017 11:55 PM
I have a Whtech SCSI controller and external 200MB SyQuest cart drive - wanted a way to read from the floppy disk (2880 sector, Myarc DDCC-1 w 80 track - Lotharek Floppy Emulator) and save it as a .DSK image.  Basically, I'd like it to do exactly what Fred Kaals DSK2PC does except allow it to save to another location.
Downloaded and experimenting with DISK2FILE right now...  Need a way to make quick TI-BASE database backups!
#12 Schmitzi ONLINE
Schmitzi
  • 4,084 posts
  • ToXiC
Posted Fri Apr 21, 2017 3:42 AM
Hi, did you ever make a backup of your Eproms (Myarc DDCC-1 w 80 track / 720KB ) ?
I have the same controller/same mod, and it came from Barry Boone.
Maybe we should compare them, just for fun ? ;)
(If so, let´s  make a dedicated thread for that)
