RCL 139 Error
12 replies to this topic
#1 gargoyle OFFLINE
gargoyle
    Chopper Commander
  • 185 posts
Posted Thu Apr 20, 2017 3:19 PM
I have some personal disks from way back in Spartados 1.1 format and i wanted to try Respeqt (normally use Aspeqt).  When i tried to load RCL.COM (client software for the Atari), it stops with error 139 and does not load. I've also tried ASPECL.COM (from atari8warez) and this one loads and displays something like: "only spartdos 2.x and above supported".  So i can't use the client with older spartados but I don't know what the issue is with RCL.COM.
Edited by gargoyle, Thu Apr 20, 2017 3:21 PM.
#2 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 20, 2017 4:16 PM
Did RespeQt log anything meaningful in the log window? I suspect rcl doesn't work on Spartados 1.1 either, but isn't displaying a convenient error message for whatever reason. I think the 139 is probably coming from RCL itself rather than DOS, so it's running, it's just not working.
	.byte 'SpartaDOS v.2.5 or higher required!',155,0
I'll ping FJC, but keep in mind RCL is in beta, so these kind of issues are to be expected.
The other possibility is that something is wrong with folder images, if you're using them. Are you trying RCL from an ATR or a folder image? If it's from a folder image, can you try copying to an ATR and then try?
Edited by Joey Z, Thu Apr 20, 2017 4:18 PM.
#3 gargoyle OFFLINE
gargoyle
    Chopper Commander
  • 185 posts
Posted Thu Apr 20, 2017 4:34 PM
I didn't check Respeqt log, but I am loading the client from an .ATR formatted in Spartados disk format, not from a folder image
EDIT: Tested again, and this is what i get from the log window (Seems like it's looking for a strange sector number on a 90K .atr)
Serial port speed set to 19200.
[Disk 2] Speed poll.
Serial port speed set to 57600.
[Disk 2] Read sector 1 (128 bytes).
[Disk 2] Read sector 5 (128 bytes).
[Disk 2] Read sector 6 (128 bytes).
[Disk 2] Read sector 51 (128 bytes).
[Disk 2] Read sector 52 (128 bytes).
[Disk 2] Read sector 53 (128 bytes).
[Disk 2] Read sector 54 (128 bytes).
[Disk 2] Read sector 1712 NAKed. [x52]
Edited by gargoyle, Thu Apr 20, 2017 4:44 PM.
#4 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 20, 2017 4:49 PM
that is indeed strange, so it's (so far) not an issue with RCL.
Edited by Joey Z, Thu Apr 20, 2017 4:51 PM.
#5 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 20, 2017 5:08 PM
can you post the problem-ATR as well as (for my convenience) a copy of SD1.1?
#6 gargoyle OFFLINE
gargoyle
    Chopper Commander
  • 185 posts
Posted Thu Apr 20, 2017 5:24 PM
Well, the problem does not happen with ASPECL, so it does look like a problem with RCL, however i couldn't bet my life on it.
#7 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Apr 20, 2017 6:38 PM
MEMLO of spartaDOS 1.1 is $2300, RCL loads at $2000. So that's not going to work. AspeCL loads at $3000. Given that SpartDOS 1.1 isn't supported by RCL, I'm going to stick with calling this not a bug.
#8 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,708 posts
Posted Fri Apr 21, 2017 12:07 PM
but it would be nice to make the client relocatable, as more and more things are today...
#9 flashjazzcat OFFLINE
flashjazzcat
  • 14,493 posts
Posted Fri Apr 21, 2017 4:51 PM
A relocatable version for SDX would take about twenty minutes to produce, although it seems unnecessary. One may simply change the origin to $4000 if the objective is to use the tool with peculiar configurations where MEMLO is high enough to prevent most applications from running (the lowest safe recommended load address being $2000).
#10 JoSch OFFLINE
JoSch
    Moonsweeper
  • 490 posts
Posted Sat Apr 22, 2017 2:31 AM
To change the origin, which assembler should one use?
#11 flashjazzcat OFFLINE
flashjazzcat
  • 14,493 posts
Posted Sat Apr 22, 2017 3:52 AM
MADS. I thought I had put this in the comments at the top of the source code, but who knows. ;)
#12 JoSch OFFLINE
JoSch
    Moonsweeper
  • 490 posts
Posted Sat Apr 22, 2017 4:22 AM
No, you didn't. That's why, I asked ;)
#13 flashjazzcat OFFLINE
flashjazzcat
  • 14,493 posts
Posted Sat Apr 22, 2017 4:43 AM
Sorry: I thought I had. Not everyone is observant enough to check before asking. ;)
Reply to this topic
