jhd Posted April 21, 2017 Share Posted April 21, 2017 I recent underwent some medical tests. This included being attached to a pulse oximeter. I noticed that the device connected to the data logger with a standard DE9 connector (though not all of the pins were used). This is the first time that I have seen this connector used outside of video game consoles and PC serial ports. Quote Link to comment Share on other sites More sharing options...
Shawn Posted May 1, 2017 Share Posted May 1, 2017 DB9 not DE9 right? Quote Link to comment Share on other sites More sharing options...
BigO Posted May 1, 2017 Share Posted May 1, 2017 (edited) I believe it's technically DE9. I'm guessing the DB may have been improperly carried over from DB25 when 9 and 25 were options on modems and such.. But, DB9 managed to stick. Or something like that. EDIT: https://en.wikipedia.org/wiki/D-subminiature#/media/File:DSubminiatures.svg https://en.wikipedia.org/wiki/D-subminiature Edited May 1, 2017 by BigO 2 Quote Link to comment Share on other sites More sharing options...
mr_me Posted May 1, 2017 Share Posted May 1, 2017 A DB9 is actually the same size (B) and shape (D) as a DB25 but only has 9 pins rather than 25. So DE9 is correct but everyone knows what is meant when the term DB9 is incorrectly used. Quote Link to comment Share on other sites More sharing options...
7800fan Posted May 2, 2017 Share Posted May 2, 2017 It should be DE9 but too many use it as DB9 (and all other D-shell connectors as DB instead. DA-15, DB-25, DC-37, DD-50, and DE-9. VGA port is technically DE-15 and not something like HD-15 or HDB-15 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted May 3, 2017 Share Posted May 3, 2017 yes dsub connectors are used all over the place, especially in industrial applications, makes me cringe when people plug random crap into them 1 Quote Link to comment Share on other sites More sharing options...
carlsson Posted May 4, 2017 Share Posted May 4, 2017 @jhd: Quite possibly this is the pinout, if you need to fix it on your next doctor's appointment: http://pinouts.ru/PortableDevices/nellcore_pulse_pinout.shtml The Pinouts.ru site has a whole bunch of pinouts for the 9-pin Dsub: http://connector.pinouts.ru/9_pin_D-SUB_male/ As for interesting uses of the 9-pin Dsub, I remember some 68K development board using one for power. I don't know if the connector has been specified for that use, but it appeared to work. 1 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted May 4, 2017 Share Posted May 4, 2017 I just grabbed a random datasheet Current Rating 3amp Voltage Rating 250VAC There is no rule saying a 9 pin dsub has to be xyz, its not attached to a standard like USB orADB, its just a connector, and it could be connected to anything in any way Quote Link to comment Share on other sites More sharing options...
tschak909 Posted May 4, 2017 Share Posted May 4, 2017 The correct terminology is DE-9, because the E represents the outer shell size. the B size supports connectors of 16 to 37 pins nominally. There is no progression difference between A, B, C, D, or E shell sizes, they are all arbitrary, and specify a rough lateral size. -Thom Quote Link to comment Share on other sites More sharing options...
jhd Posted May 5, 2017 Author Share Posted May 5, 2017 @jhd: Quite possibly this is the pinout, if you need to fix it on your next doctor's appointment: http://pinouts.ru/PortableDevices/nellcore_pulse_pinout.shtml Thank-you. It looked like some of the pins were not connected, but I did not spend too much time examining the hardware -- there were more important matters to attend to that day. Quote Link to comment Share on other sites More sharing options...
