Windows TELNET.EXE Echo Issue
Windows telnet xp
7 replies to this topic
#1 Kyle22 ONLINE
Kyle22
  • 4,033 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Tue Apr 25, 2017 6:54 PM
Here is the Telnet client from Win 2K Pro.  It behaves properly when connecting to BBSs.  The one that ships with XP has a problem because it echoes locally typed characters. Win 7 and later seem to have no telnet installed by default.  This one should work for you.
Extract these files to c:\windows\system32.
Attached File  TELNET.ZIP   40.66KB   76 downloads
Edit: Make sure to cancel any and all Windows File Protection dialogs when you replace the files.
Edited by Kyle22, Tue Apr 25, 2017 6:56 PM.
#2 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,759 posts
Posted Tue Apr 25, 2017 7:47 PM
maybe I already did this long ago... my xp doesn't have that problem.. I remember doing something... and moving the terminal to vista or something also....
#3 phaeron OFFLINE
phaeron
  • 2,738 posts
Posted Tue Apr 25, 2017 9:28 PM
I don't remember this behavior either. Local echo is a runtime negotiable option in the Telnet protocol, so it's possible XP added new support that's tripping on the specific connection you're making.
Rather than stuffing in the Win2K telnet.exe, though, I'd just switch to putty.exe -telnet. Much nicer Telnet client.
#4 Kyle22 ONLINE
Kyle22
  • 4,033 posts
Posted Tue Apr 25, 2017 9:39 PM
localecho off does not work with the normal telnet.exe, this one defaults to echo off.
#5 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Tue Apr 25, 2017 10:50 PM
I'm working on a 850 / telnet modem emulation feature for RespeQt (actually I just started and I'm collect required knowledge).
I checked that Altirra refuses the "WILL ECHO" request from the telnet server running a BBS and uses local echoing, while a PUTTY telnet client (and APE telnet client) does the opposite:
http://atariage.com/...n/#entry3748914
I would really appreciate if you could comment on that (and on other questions I asked so far in the above thread).
#6 Kyle22 ONLINE
Kyle22
  • 4,033 posts
Posted Wed Apr 26, 2017 1:07 AM
I'll check it out. Provide a link for the proper version, and I will test it.  I can have one Win machine running RespeQt, and another telnet into it.
Is there any reason why I can't telnet to myself at 127.0.0.1?  I would think it should work.
#7 phaeron OFFLINE
phaeron
  • 2,738 posts
Posted Wed Apr 26, 2017 1:16 AM
I'd have to double-check to be sure, but I think this was part of fixes needed to work with the Microsoft Telnet Server, which has some unusual requirements (TRANSMIT-BINARY, in particular). It wasn't to save bandwidth, as Telnet bandwidth is inconsequential at Atari scale.
#8 TheMontezuma OFFLINE
TheMontezuma
    Dragonstomper
  • 676 posts
Posted Wed Apr 26, 2017 1:33 AM
Not that fast - here is nothing to test yet ;)
And in the first step RespeQt will get only the telnet client.
You need a telnet server running on your machine (to be able to connect to it).
Generally you can establish a telnet connection to any port on your machine if there is an application listening on it (for example a web server).
This article will give you more info on TCP/IP ports:
https://www.howtogee...ort-in-windows/
Also tagged with one or more of these keywords: Windows, telnet, xp
