w1k Posted April 29, 2017 Share Posted April 29, 2017 when i trying delete empty dir, sdx write - 167 directory not empty, but its empty https://www.youtube.com/watch?v=DU1z0Qfncfo Quote Link to comment Share on other sites More sharing options...
Marius Posted April 29, 2017 Share Posted April 29, 2017 (edited) In the manual I read this: When error '167 Directory not empty' occurs and the directory seems to be empty, please check the directory to be deleted for hidden files or hidden subdirectories using the DIR command . And one more thing... if you already did that, perhaps you could try running CLX... Which is also a suggestion in manual: If 'Can't delete directory' or 'system error' persists, an invalid directory entry has been found – a file, which was opened for writing, but never closed again (e.g. because of a system crash). Such an entry is invisible in directory listings and cannot be deleted otherwise. The presence of such an invalid entry causes SpartaDOS X to consider an empty directory as not empty and therefore it cannot be deleted. This error condition indicates a file system structure, which is not completely valid. In this case it is strongly recommended to run the program 'CleanUp X' from the SpartaDOS X Toolkit to verify the structure of the file system and fix it. See more in Appendix E, "Using CleanUp with SpartaDOS X". Edited April 29, 2017 by ProWizard 3 Quote Link to comment Share on other sites More sharing options...
w1k Posted April 30, 2017 Author Share Posted April 30, 2017 thanks.. solved with CLX Quote Link to comment Share on other sites More sharing options...
