Connect 1050 to Altirra
24 replies to this topic
#1 toddtmw OFFLINE
toddtmw
    Moonsweeper
  • 470 posts
Posted Sat May 6, 2017 7:17 PM
Okay. I bought a 1050 and I want to use it as a disk drive for Altirra. There are all kinds of posts on the forums and otherwhere talking about how to do this, but many of them are several years old and point to sites thaat are no longer there or that are out of stock or that are fairly expensive.
Can someone please tell me the May 2017 options I have here?
It sounds like SIO2PC ( work because it goes the wrong way? Is that right?
The 10502PC from that same site is out of stock.
Where can I get a reasonbly priced solution that is in stock that will do what I am trying to do?
Thanks all!
-Todd
#2 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Sat May 6, 2017 10:14 PM
AFAIK, you can't.
#3 Kyle22 OFFLINE
Kyle22
  • 3,532 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sat May 6, 2017 11:49 PM
I wish it were possible.
#4 _The Doctor__ OFFLINE
_The Doctor__
  • 4,888 posts
wait does altirra have a provision to do it?
Edited by _The Doctor__, Sat May 6, 2017 11:50 PM.
#5 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Sun May 7, 2017 12:34 AM
No, I don't believe it does.
#6 _The Doctor__ OFFLINE
_The Doctor__
  • 4,888 posts
Posted Sun May 7, 2017 12:46 AM
maybe creative use of the usb as a networked drive or pseudo drive could automate things, some script writing pro could make it happen yeah that's the ticket, but it won't be me....
the only way to fly is real hardware and ape respeqt..... and the original sio2pc flavors
Edited by _The Doctor__, Sun May 7, 2017 12:46 AM.
#7 toddtmw OFFLINE
toddtmw
    Moonsweeper
  • 470 posts
Posted Sun May 7, 2017 7:22 AM
Wait. What is the 1050 2 PC, then?
http://lotharek.pl/product.php?pid=198
I guess this is just to copy disks to ATX files or copy ATX file to disk?
#8 UNIXcoffee928 OFFLINE
UNIXcoffee928
  • 1,177 posts
Posted Sun May 7, 2017 7:25 AM
There used to be a product line named "Catweasel ". They were PCI cards that provided plug in connectivity to both Atari & Amiga disk drives & other peripherals, directly to a PC. I would say that a Catweasel board would likely do the trick.
I remember that Catweasels were kind of expensive, and they had limited availability, but they looked pretty awesome, spec-wise. The few times that I looked for them, a few years ago, they had become collectible, and were more pricey, & more scarce.
Maybe some hardware people here could create a new, similar device, for less money, via FPGA technology.
#9 Mclaneinc OFFLINE
Mclaneinc
  • 5,882 posts
Posted Sun May 7, 2017 7:45 AM
I know nothing technical about the hardware but wouldn't it be really hard to have the emulation running in conjunction with the hardware and meet timing requirements?
#10 toddtmw OFFLINE
toddtmw
    Moonsweeper
  • 470 posts
Posted Sun May 7, 2017 7:49 AM
It's weird, I've been reading threads here for a while and with all the talk about Altirra emulating different drives, it sounded to me like it was actually working with the hardware.
Just looking at the changes for the latest release of Altirra it has this line:
  • Added a power-on delay setting to deal with slow disk drives. This gives the disk drives more time to init before the computer powers on. "Auto" automatically applies a delay for the 1050 Duplicator, ATR8000, and Percom drives.
This really makes it sound like it is waiting for a physical drive, not a virtual one.
#11 Mclaneinc OFFLINE
Mclaneinc
  • 5,882 posts
Posted Sun May 7, 2017 8:05 AM
I think it more shows the problem with drive emulation, the delay is to give the emulated drive time to sync properly where in a real drive it I presume have ran as expected. Just imagine how much having an emulated Atari trying to communicate and sync with another piece of software connecting the real drive...
But, like I say I don't have a clue about the hardware but timing always seems to be a critical piece of emulation.
#12 ACML OFFLINE
ACML
    Dragonstomper
  • 855 posts
Posted Sun May 7, 2017 8:34 AM
The old MSDOS based Xformer emulator had the ability to read and write to 810s and 1050s.  I used it back in the late 80s to create XFD images from my floppies.  You could actually boot off the 810 on Xformer. It worked on an intel 486.  I remember timings on the motherboard were critical and when motherboards left the base 60/66Mhz frequency, I could no longer get it to work.  It worked well.  Maybe Avery could incorporate that into Altirra?
Edited by ACML, Sun May 7, 2017 8:35 AM.
#13 Rybags OFFLINE
Rybags
  • 15,759 posts
Posted Sun May 7, 2017 8:35 AM
Emulation of video and sound is generally done as fast as the PC allows.  The video is constructed and displayed as a single frame and the sound goes to a buffer.  Turbo mode demonstrates how fast it actually is happening as the emulation doesn't pause to wait for the next frame worth, it just goes continuously.
Potentially you could communicate to a drive either by running the emulation such that it's near to realtime cycle exactness which would be a real tedious process.
Or cut corners a bit and just run the emulation to the timing of a landmark event, such as the bitrate of the drive.
Or, probably the best way, just have a seperate task deal with talking to the real drive at the command/block level which would present no greater timing challenge than you'd already get by running an instance of Altirra and APE or other SIO2PC type program, which most of us have probably already done.
But really, it's just a novelty.  For me a big part of the point of emulation is convenience.  Convenience of not having all the old hardware sprawled across the desk and convenience of not having to do media changes every couple of minutes.
#14 UNIXcoffee928 OFFLINE
UNIXcoffee928
  • 1,177 posts
Posted Sun May 7, 2017 8:51 AM
AFAIK, you can't.
Here's some information about the Catweasel device. Maybe a similar device can be created?
Individual Computers Catweasel
#15 ACML OFFLINE
ACML
    Dragonstomper
  • 855 posts
Posted Sun May 7, 2017 9:40 AM
Xformer used a delay constant you typed in before it ran which was I guess the speed calibration for realtime floppy operation.  It was trial and error.  You kept trying a different constant until you could achieve reliable 810 operation.
#16 ijor OFFLINE
ijor
  • 2,092 posts
Posted Sun May 7, 2017 11:46 AM
Not exactly. The Catweasel can be considered a predecessor of the Kryoflux and the Super Card Pro. It is designed for accessing foreign disks (not drives), such as Atari, Apple, C64 or Amiga directly with a standard PC disk drive. Some models, I believe, let you connect an Amiga drive directly, but this is mostly because Amiga and PC drives are basically equivalent. You can't connect an Atari 8-bit disk drive directly to any Catweasel. Btw, the latest model was FPGA based.
#17 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Sun May 7, 2017 12:11 PM
Sure, but this was in MSDOS where you could take over the hardware at the lowest level, and achieve the timing you needed. It was also using a real serial port, where you had genuine hardware interrupts working to help you, and the timing didn't suck (as it is totally unreliable with USB to serial converters). It's a miracle any 10502PC-USB work at all in my opinion :).
AFAIK, you can't.
Just to be clear, I meant that the software doesn't support it, not that it's impossible. You also don't need a Catweasel to read and write A8 disks on the PC, just a floppy controller that supports FM mode (which are a bit rare, unfortunately).
Does that catweasel write disks? I always thought of it as an archival tool.
Yep.
#18 waryl OFFLINE
waryl
    Combat Commando
  • 7 posts
Posted Sun May 7, 2017 12:15 PM
Lotharek is now working on
1050-2-PC/Sio2PC-USB
Device combines two functions, selected with switch:
  • Sio2pc-USB ( You can connect 8bit ATARI to PC)
  • 10502PC  ( You can connect real atari disk drive to PC)
 More details
  • Device in transparent SIO PLUG V2,
  • Micro-usb plug
  • designed by Candle`o`Sin
  • ROHS
#19 toddtmw OFFLINE
toddtmw
    Moonsweeper
  • 470 posts
Posted Sun May 7, 2017 2:51 PM
It looks like most of the SIO2PC devices only support one SIO connection, so how do you go from physical disk to physical drive to atari to SIO2PC adapter to PC to ATR (or vice versa) when you cannot have both the disk drive and the PC plugged in at the same time?
Thanks,
#20 lemiel OFFLINE
lemiel
    Moonsweeper
  • 273 posts
Posted Sun May 7, 2017 2:54 PM
Computer <-> port1 disc drive port2 <-> PC.
Sth like that.
But drive to PC only when not connected to Atari.
Edited by lemiel, Sun May 7, 2017 2:55 PM.
#21 _The Doctor__ OFFLINE
_The Doctor__
  • 4,888 posts
Posted Mon May 8, 2017 12:15 AM
Atarimax has sio2pc with two sio connectors put it wherever you like.... for the rest put sio to pc at end of daisy chain
#22 1050 OFFLINE
1050
  • 1,018 posts
Posted Mon May 8, 2017 1:35 AM
One trick you may be able to employ is have one or more physical drives
connected to the Atari via SIO in various drive number settings and
have power shut off to those you don't want active as in the case
of an active SIO2PC emulated drive #1 on a PC. Copy files to your ramdisk,
disable PC program, turn on physical drive, press RESET on Atari and
have the physical #1 drive working. I have a four drive stack, two #1
and two #2, sometimes only one is powered up, only two can be powered
else there are issues with too many devices operating under the same
drive number.
1050 drive has two SIO ports, one goes to computer and the other goes
to SIO2PC if you are not fluent in the way the SIO daisy chain works.
If you need more SIO connections you can have that with two SIO cables
wired and soldered together, but it's a grand project all it's own. You
also need more (up to 3 in total) double SIO socket drives/devices to
gain empty and useful SIO sockets with.
Other methods exist but are getting very rare to obtain such as
CSS Quintopus.
http://nleaudio.com/...s/quintopus.htm
I don't recall any other alternatives since I built my own 'quad' SIO
cable (the above grand project) when I was first starting out and was
suffering the SIO jack pinch where you just don't have enough of them.
It's important you hear this at least once. NEVER hot plug any SIO
device EVER, powered down or up is not the issue -- DON'T is the
issue. You can get away with it 100 times and then you'll have a
defective drive/device to try and find a replacement for. Thems the
breaks, take that road and suffer. Only system wide power down entirely can
changes be done safely in the SIO daisy chain.
Not sure if very much of this applies to your Altirra mode set up
anyway but there it is for what's it's worth.
#23 _The Doctor__ OFFLINE
_The Doctor__
  • 4,888 posts
Posted Mon May 8, 2017 11:05 PM
The Deluxe quintopus was the step in the correct direction, there was another solution out there that shared devices that went one step further...
Edited by _The Doctor__, Mon May 8, 2017 11:06 PM.
#24 BillC OFFLINE
BillC
  • 1,835 posts
Posted Tue May 9, 2017 1:33 AM
The only such device I am aware of that is currently available is the Apelink from Best Electronics.
IMO the PCB is poorly designed though, there is no provision for attaching the SIO sockets other than the pins/solder.
http://best-electron...ink PCB's 3.JPG
#25 marcokitt2000 OFFLINE
marcokitt2000
    Chopper Commander
  • 229 posts
Posted Tue Feb 13, 2018 6:07 AM
Altirra greatest emulator i hope 1050 2 pc(altirra) will come than i can use my 1050 with megaspeedy.
I like to use altirra
Or are there settings in altirra 3.10 beta 10 to use the 1050 wit sio 10502pc (ftdi usb)?
Gr.
Marco
