Bought 5200 Prototype cart. Looking for info
Atari 5200 prototype cart
13 replies to this topic
#1 supermth2 OFFLINE
supermth2
    Combat Commando
  • 8 posts
  • SuperMasonTheHacker2 (^_^)
Posted Sat May 6, 2017 9:02 PM
Just looking for some info on it... maybe a value? https://goo.gl/photo...vknpEzG3rq5mAK6
Edited by supermth2, Sat May 6, 2017 9:05 PM.
#2 CZroe OFFLINE
CZroe
    Dragonstomper
  • 620 posts
Posted Sat May 6, 2017 9:16 PM
Don't know, but that is pretty cool! Got pics of the inside?
#3 supermth2 OFFLINE
supermth2
    Combat Commando
  • 8 posts
Posted Sat May 6, 2017 9:19 PM
No, its on its way now. :/ any idea how i would open it?
Edited by supermth2, Sat May 6, 2017 9:19 PM.
#4 CZroe OFFLINE
CZroe
    Dragonstomper
  • 620 posts
Posted Sat May 6, 2017 9:59 PM
It probably uses a standard shell. If so then there is one screw on the back but a few clips on either side. I broke a clip recently before I figured out that I just needed to press my metal spudger in from between the shells and free the clips from the bottom up.
If you want to do it I'd practice on a normal game first if I were you. :) I'll try to make a video soon.
#5 supermth2 OFFLINE
supermth2
    Combat Commando
  • 8 posts
Posted Sat May 6, 2017 10:00 PM
It seems there Isnt a screw on the back of this one. Guy says it works though, Not that I can test it. I don't have the adapter for my 5200.
Edited by supermth2, Sat May 6, 2017 10:26 PM.
#6 CZroe OFFLINE
CZroe
    Dragonstomper
  • 620 posts
Posted Sun May 14, 2017 3:07 PM
Well, in case it helps I can at least show how you open a standard 5200 Cartridge:
https://youtu.be/JXsr_exlmXM
#7 0078265317 OFFLINE
0078265317
  • 6,191 posts
Posted Sun May 14, 2017 7:50 PM
That is a standard 5200 cartridge.  No adapter needed.
#8 CZroe OFFLINE
CZroe
    Dragonstomper
  • 620 posts
Posted Mon May 15, 2017 7:13 AM
I think he means his AC adapter. ;)
#9 ruthsarian OFFLINE
ruthsarian
    Space Invader
  • 19 posts
Posted Mon May 15, 2017 3:55 PM
Although perhaps not for the proto cart, but I've had a lot of luck opening 5200 carts by just banging on the top of it with a rubber mallet or the rubberized handle of some other tool. Haven't cracked a case or broken any clips yet.
#10 CZroe OFFLINE
CZroe
    Dragonstomper
  • 620 posts
Posted Wed May 17, 2017 5:13 PM
Cool. I also used a trapezoidal-shaped razor blade and it can work too but it can mar the plastic. I slipped it in the space between halves then turned sideways to the thicker part for leverage+spread.
It's actually easier to reassemble the RF/EMI shield with one because it's almost as wide as the entire edge and the alignment slot is easily spanned. I just overlap the shields on one end and put the blade between the two halves on the other end, levering it slightly so that the sides don't have to expand any more than necessary (slips right over).
#11 TheTIGuy OFFLINE
TheTIGuy
    Dragonstomper
  • 556 posts
  • keki wa usodesu!
  • Location:At the bus-stop, waiting for a bus that will likely not come...
Posted Sun Jul 30, 2017 5:47 PM
Well you could test it...
http://www.eskimo.co....switchbox.html
#12 video61atarisales OFFLINE
video61atarisales
    Chopper Commander
  • 123 posts
Posted Mon Jul 31, 2017 11:03 PM
 that is a standard loaner cart. its rare, but most likely it has a soldered rom chip on the circuit board. a prototype would most likely have e-proms, sometimes in sockets, sometimes soldered to the circuit board. on most prototype 5200 boards i have seen, have four sockets, for up to 32k, using up to four 8k e-proms.
 atari like others, would not want e-proms circulated on a loaner cart, those could be copied quite easy. the loaner carts were for game reviewers and beta testers, dealers, etc.
 i have posted four of my own prototypes so far here,
http://forums.atari....ypes-vaporware/
just click on each title, millipede, asteroids, super pacman, and stargate. that will give you a idea what prototypes on the 5200 look like.
thanks,
lance
www.atarisales.com
#13 Lynxpro OFFLINE
Lynxpro
  • 3,602 posts
Posted Sat Aug 5, 2017 1:31 PM
thanks,
lance
www.atarisales.com
Do you know which versions they are?
AtariProtos includes the various versions, such as with Stargate:
http://www.atariprot...te/stargate.htm
#14 video61atarisales OFFLINE
video61atarisales
    Chopper Commander
  • 123 posts
Posted Sat Aug 26, 2017 5:58 PM
 put up my atari 5200 star raiders prototype. plus others.
DELTA SPACE ARENA 5200:
PUTT 18 5200 - GAMEPLAY:
PUTT 18 5200 - INTRO:
STAR RAIDERS 5200:
Secretum Labyrinth Xenogenesis 5200:https://www.youtube....9h15WYa3k&t=72s
http://forums.atari....ders-prototype/
http://forums.atari....rena-game-play/
http://forums.atari....5200-game-play/
http://forums.atari....-protype-board/
http://forums.atari....th-xenogenesis/
thanks,
lance
www.atarisales.com
Also tagged with one or more of these keywords: Atari 5200, prototype, cart
