Sound Not Playing Properly In Room!
5 replies to this topic
#1 alexishere13 OFFLINE
alexishere13
    Combat Commando
  • 1 posts
Posted Sat May 13, 2017 4:49 PM
Hiya! I've recently been attempting to recreate the game 'Undertale' for the Atari 2600 via Batari Basic, and it's been going well so far. However, I've run into a bit of a problem. After the intro to the game, there are 3 rooms built so far. In the third room, a simple song is supposed to play, the timing of which is controlled by an offscreen missile. However, for some reason, even though I used the same technique here to make music that I did with the intro sequence, the music cracks and sounds nothing like it's supposed to in this room. The code is attached in txt format, and any help is appreciated. Thanks :)
(Oh, and any tips to reduce file size would also be helpful!)
#2 Random Terrain ONLINE
Random Terrain
    Visual batari Basic User
  • 28,595 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sun May 14, 2017 10:41 PM
Why are you using missile0x with the sound? You might need missile0x in your game at some point.
#3 Random Terrain ONLINE
Random Terrain
  • 28,595 posts
    Replay Value
    Nonlinear
Posted Mon May 15, 2017 3:40 AM
See if this is any better:
Attached File  undertaleataricode_2017y_05m_15d_0521t.bas   9.14KB   23 downloads
Attached File  undertaleataricode_2017y_05m_15d_0521t.bin   4KB   24 downloads
You might have noticed that Atari 2600 sound can be pretty hard on the ears if we don't play around with it. For example, fading each note in and out can make it sound similar to a flute. There are various things we can do to the notes to make them sound better. Here is one example:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#ex_sound_with_bg_music
#4 Buckaroo OFFLINE
Buckaroo
    Space Invader
  • 22 posts
Posted Mon May 15, 2017 3:51 AM
I've fixed the file for you, on line number 380 you had
if missile0x > 32 then AUDV1 = 0
As this happens after all of you other music commands in music5 it turns the volume to 0 at the end.
I've commented out this line and the music plays
#5 Buckaroo OFFLINE
Buckaroo
    Space Invader
  • 22 posts
Posted Mon May 15, 2017 3:59 AM
Whoops, sorry RandomTerrain I didn't see that you beat me to it.
P.S. Thanks for all of your help files. There a godsend. I'm totally hooked on programming for the Atari now
#6 Random Terrain ONLINE
Random Terrain
  • 28,595 posts
    Replay Value
    Nonlinear
Posted Mon May 15, 2017 5:10 AM
Thanks. Besides fixing that line you mentioned, I got rid of some redundant code, moved some code around, and added a couple of things. More could be done, but that's all the time I had.
