assembly development
11 replies to this topic
#1 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,879 posts
Posted Fri May 19, 2017 6:10 PM
I didn't want to clutter the development tools thread with my questions.
Most of the time I write my assembly code on real hardware or MESS, depending on my mood.  Recently I have been playing around with some of the development tools, like xdt99, to see if I can simplify a few of my larger projects.  There are a few frustrations I've run into, mostly on the editing side.
I downloaded Notepad++ and the language xml file.  I figured out how to add and select the XB/assembly language file.
1. I am used to using TAB to get to the next operand/tab location.  Notepad++ uses tab to perform an autocomplete.  This drives me bonkers. Similar things happen when pressing enter and I find myself having to go back and edit (correct) everything.
2. Can notepad++ mimic how the TI editors handle tabs, i.e., move the cursor to the next tab instead of indenting the code to the right?  When I type assembly, it is second nature to tab from column 1, to column 7, to 11, etc.  Between #1 and #2, my code is a wreck.
3. Notepad++ seems to be set up to use the semicolon for comments. Is there a way to reconfigure this to the asterisk?
4. I think I understand how to assemble and create images with xdt99.  I need to experiment a bit more.  I didn't see a MAKE utility, does something like that exist?  I use a fair number of separate object code 'modules' linked with REF/DEF versus lumping things into one assembled file.
Yea, I know, I'm set in my ways.  Alternative options and suggestions welcome ;)
thanks
Edited by InsaneMultitasker, Fri May 19, 2017 6:11 PM.
#2 adamantyr OFFLINE
adamantyr
  • 1,269 posts
Posted Fri May 19, 2017 6:30 PM
I use Textpad myself with my own syntax file. I also set up the tabs to match E/A. It's worked pretty well for me.
#3 matthew180 OFFLINE
matthew180
  • 2,450 posts
Posted Fri May 19, 2017 8:17 PM
I have used Textpad since 1997, but recently I have switched to other editors due to wanting more of a "code editor" rather than a "text editor".  Textpad is staying true to its roots, but I like a little more from an editor.
Notepad++ has some nice options, and yes you can turn off all the extra auto-complete, auto-indent, etc.  You can also reassign the key mappings to hotkeys that work for you.
You should be able to set up tabs stops to match the original E/A, but I find with the new assemblers, I don't care very much for the old assembly column format.  The first time you use a long label you will blow the left column, so just forgo the original tabs and embrace more space. :-)
As for comments, anything after the opcode field is ignored, so for the editor's sake you can use a semicolon to designate a comment.  You can also reassign the single-line comment delimiter, however, I am not aware of an editor that will consider a column position to indicate a comment, so you will need to choose a character (or combination) that does not exist in the normal language.
Another editor that I have been using lately is Sublime Text.  It has some really powerful editing features.
Most editors can automate the build of programs by running the command line tools via a hotkey, etc.
#4 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,879 posts
Posted Fri May 19, 2017 10:13 PM
I've been using long labels for 20+ years - Paul Charlton's one-pass assembler for the Geneve allows for them.   I often place the longer label on the preceding line, by itself, so the tab stops aren't much trouble there ;)   I suppose this would only be a problem for me if the PC-based assemblers dislike labels on their own lines.
So far I haven't found an editor that allows the tab (or some other keypress) to jump to predefined tab stops without moving the existing text.  Guess I need to play around a bit more.
I'll give textpad and sublime text a try and watch for any other ideas on how people are writing and assembling code.
#5 atrax27407 ONLINE
atrax27407
    Dragonstomper
  • 866 posts
Posted Sat May 20, 2017 6:19 AM
I'll see what I can do with the F'WEB program editor.
#6 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Sat May 20, 2017 7:31 AM
It may seem overkill to install a 350 MB IDE for writing small assembly files, but you should really do yourself a favor and try the community (free) edition of IntelliJ IDEA with RalphB's plugin.
#7 mizapf OFFLINE
mizapf
  • 2,894 posts
Posted Sat May 20, 2017 12:58 PM
My favorite editor for the last 15 years is jEdit. I've been doing all work for TIImageTool and MAME with it.
#8 Gip-Gip OFFLINE
Gip-Gip
    Chopper Commander
  • 210 posts
Posted Sat May 20, 2017 3:47 PM
As a UNIX user I prefer Geany. It's pretty solid in my opinion and has all the features I need(then again, I mostly program in C and Assembly)
#9 jedimatt42 OFFLINE
jedimatt42
  • 1,404 posts
Posted Sat May 20, 2017 6:02 PM
I spent years using jEdit, with no complaints, but I also dropped it like a ton of bricks when my employer forced Intellij on me. No regrets there.
I still fall back on vim when in an unstructured project / shell environment... which is most of the time.
I took Ralph's Intellij syntax highlighting code, and applied what I could figure out to vim:
Attached File  a99vim.zip   1.38KB   3 downloads
If you use vim, unzip this in ~/.vim
It contains a simple syntax file for .a99 files, and a file type detector for .a99 files... :) where .a99 is the source extension I use for Ralph's assembler.
( I used jEdit for so long that I still mistype Jedimatt42 often...  )
-M@
#10 mizapf OFFLINE
mizapf
  • 2,894 posts
Posted Sun May 21, 2017 5:31 AM
One of the major strengths of jEdit is its expandability with plugins. I use the Project Management and various syntax highlighting features. You can easily add custom highlighting for other languages. Also, the visual diff is pretty helpful.
Of course, I'm frequently using vim, but not for bigger files; mainly to write simple script files, to modify them, or to do other minor changes. What I like most about vim is its simplicity and small size: While other editors have not got past their splash screen, I'm already done with my editing work in vim, saved the file, and exited it again.
Still in my mind is a port of vim for the Geneve.
#11 TheBF OFFLINE
TheBF
    Moonsweeper
  • 484 posts
Posted Sun May 21, 2017 6:29 AM
For those running on Windows, Context is a nice editor written in Delphi. (I don't believe source code is available)
It has a simple way to create highlighter files for any language, with the common languages already provided which you can use as examples.
I use it for Forth on Windows 10 64 and it's pretty nice.
http://www.contexteditor.org/index.php
Oh and it's freeware
Edited by TheBF, Sun May 21, 2017 6:30 AM.
#12 Asmusr OFFLINE
Asmusr
  • 2,581 posts
Posted Sun May 21, 2017 6:35 AM
The strength of IntelliJ IDEA specific to TMS9900 assembly is that you can jump from a label reference to the place where it's declared. This means that when the cursor is on BL @MYSUB you can press Ctrl+B to go to MYSUB. When you are on MYSUB you can press Shift+F6 to rename the label and all references. You can also use code completion: type BL @MY and press Ctrl+Space and all labels starting my MY will be suggested. There is also automatic code reformatting, but I don't use that much since it's changing the instructions to lower case.
