First Spear Posted May 22, 2017 Share Posted May 22, 2017 A question for the Inty dev veterans: what tooling /process do you use (*nix, Mac OS, Windows) or would you use to turn an image that has square pixels 16h-x-8w into something with rectangular pixels 16h-x-8w so simulate the "half sized Y" mode on Intellivision? My Image Magick skills are lacking and I am making myself crazy not being able to prototype game graphics properly. I am using Win10 but am open to trying anything at this point. Thanks. Quote Link to comment Share on other sites More sharing options...
intvnut Posted May 22, 2017 Share Posted May 22, 2017 Believe it or not, I drew a lot of my sprites directly in vim as ASCII art. In places where I wanted to see what the pixels looked like, I just used GIMP, and operated at a resolution of 320x192. It takes some discipline to ensure you set pixels in pairs or groups of 4, to simulate the half-height/full-height pixels. 1 Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted May 22, 2017 Share Posted May 22, 2017 For mocks, I normally do the following :- Draw the BACKTAB graphics and any sprites that match BACKTAB's pixel size (e.g. anything with ZOOMY2 set in IntyBASIC) in an image that is 160x96 (w x h) using the STIC "rules" for colour stack mode or foreground/background mode (as appropriate). Scale that BACKTAB and sprite image to 200% in both X and Y, thus making an image that is 320x192 (w x h). Draw the half height sprites separately, and then scale them by 200% x 100% (w x h). Copy the"half height" graphics into place, accounting for sprite priority etc. Apply suitable scaling to any sprites that use ZOOMY4, ZOOMY8 and then add them to the composition. Any sprites that are to be displayed using ZOOMX2 must be scaled in X by 400% before being placed into the BACKTAB composition. 1 Quote Link to comment Share on other sites More sharing options...
+DZ-Jay Posted May 24, 2017 Share Posted May 24, 2017 Believe it or not, I drew a lot of my sprites directly in vim as ASCII art. In places where I wanted to see what the pixels looked like, I just used GIMP, and operated at a resolution of 320x192. It takes some discipline to ensure you set pixels in pairs or groups of 4, to simulate the half-height/full-height pixels. Ah! A fellow old-schooler... I do the same, except instead of vim, I use a source code editor. On a pinch, I use vim as well, depending on the terminal I find myself in. I typically arrange my sprite animations as a sequence of frames horizontally, which each row representing a complete animation sequence. @@Horiz: :0 :1 :2 :3 :4 :5 :6 :7 :8 :9 ..####.. .####... ........ ........ .####... ..####.. ...####. ........ ........ ...####. .######. ######.. .####... .####... ######.. .######. ..###### ...####. ...####. ..###### .#.#.##. #.#.##.. ######.. ######.. #.#.##.. .#.#.##. ..#.#.## ..###### ..###### ..#.#.## .######. ######.. #.#.##.. #.#.##.. ######.. .######. ..###### ..#.#.## ..#.#.## ..###### .##..##. ##..##.. ######.. ######.. ##..##.. .##..##. ..##..## ..###### ..###### ..##..## ..##.#.. .##.#... ##..##.. ##..##.. .##.#... ..##.#.. ...##.#. ..##..## ..##..## ...##.#. .######. .#####.. .####... .####... .#####.. .######. ..#####. ...####. ...####. ..#####. .##.###. .#.####. .######. .######. .#.####. .##.###. .###.##. .######. .######. .###.##. ######## ######## ##.##### ##.##### ######## ######## ######## #####.## #####.## ######## ###.#### ##.##### ######## ######## ##.##### ###.#### ####.### ######## ######## ####.### ######## ######## ##.##### ##.##### ######## ######## ######## ####.### ####.### ######## ###.#### ###.#### ######## ######## ###.#### ###.#### ###.#### ######## ######## ###.#### ######## ######## ###.#### ###.#### ######## ######## ######## ###.#### ###.#### ######## .######. .######. ######## ######## .######. .######. .######. ######## ######## .######. .######. .######. .######. .######. .######. .######. .######. .######. .######. .######. ..####.. ..####.. ...####. ...####. ..####.. ..####.. ..####.. .####... .####... ..####.. I have a set scripts I've created that shred the animation text files and generates sprite data usable to load into GRAM. I use a similar technique for full screens scenes, although it only supports Color Stack right now. @@TITLE_SCENE: GRAM_BLOCK: TitleScene ORIGIN: (0, 0) COLOR_STK: C_GRN, C_WHT, C_CYN, C_RED FG_COLOR_0: X_CYN FG_COLOR_1: X_GRN FG_COLOR_2: X_WHT FG_COLOR_3: X_RED FG_COLOR_4: X_DGR FG_COLOR_5: X_ORG FG_COLOR_6: X_YEL FG_COLOR_7: X_BLU FG_COLOR_8: X_LBL FG_COLOR_9: X_PNK FG_COLOR_A: X_YGR ; ----------------------------------------------------- ; NOTE: ; - Small bauble tiles marked with "x" are from set 1 ; - Small bauble tiles marked with "o" are from set 2 ; - Large stars are from set 3 ; - Large baubles are static ; ----------------------------------------------------- ; 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 :COL=4,0 :COL=4,0 :COL=2,0 :COL=4,0 :COL=4,1 :COL=4,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=2,1 :COL=2,1 ; 00 ......#. ........ .......x ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ......#. ........ ..##.... ...##### #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ......## ........ .####... .......# #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ......## ........ ..##.... .......# ##...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ......## ........ ........ ........ ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## .....### ........ ........ ........ #######. .#...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## .....### #....... ........ ........ ######## ####.... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## .....### #....... ........ .......# ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## :COL=4,1 :COL=4,0 :COL=8,0 :COL=0,0 :COL=4,0 :COL=4,1 :COL=4,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=2,1 :COL=2,1 ; 01 ....##.# #....... ........ .......o ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ....##.. #....... ...#.... ..##.... ...##### #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ...###.. ##...... ...#.... .####... .......# #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ...##... .#...... ..###... ..##.... .......# ##...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ..###... ........ #######. ........ ........ ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ..##.... ......#. ..#.#... ........ ........ #######. .#...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## .##..... ......## ...#.... ........ ........ ######## ####.... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ##...... .......# ...#.... ........ .......# ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## :COL=1,1 :COL=6,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,1 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 ; 02 ........ ........ ##...... ........ ........ ......## ##...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ; We need this extra tile ........ ..####.. ###..... ........ ........ .......# ##...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ; for the "OF" letters. ........ .######. .####... ........ ........ ........ ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ...####. ........ ........ ........ ####.... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## .....### ####.... ........ ........ #####... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ #.###### ........ ######## ##...... .......# #######. ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ .#..###. ........ ...##### ######.. ...##### .....#.. ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ..####.. ........ ........ ..###### ######## ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ :COL=1,1 :COL=1,1 :COL=2,1 :COL=1,0 :COL=4,0 :COL=4,1 :COL=4,0 :COL=4,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=2,1 :COL=2,1 ; 03 ######## ######## ........ ........ ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ######## ######## ........ ........ ...##### #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ######## ######## ........ ........ .......# #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ######## ######## ........ ........ .......# ##...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ######## ######## ........ ........ ........ ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ######## ######## ........ ........ ........ #######. ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ######## ######## ........ ........ ........ ######## #....#.. ...#.... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ######## ######## ........ ........ .......# ######## ######## #####... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## :COL=1,1 :COL=0,0 :COL=1,0 :COL=2,0 :COL=8,0 :COL=4,0 :COL=4,0 :COL=4,1 :COL=4,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=2,1 :COL=2,1 ; 04 ........ .......x ........ .......o ........ ......## ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ..##.... ........ ..##.... ...#.... ........ ######## #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ .####... ........ .####... ...#.... ........ ......## #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ..##.... ........ ..##.... ..###... ........ .......# ##...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ........ ........ ........ #######. ........ ........ ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ........ ........ ........ ..#.#... ........ ........ #######. .#...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ........ ........ ........ ...#.... ........ ........ ######## ####.... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ........ ........ ........ ...#.... ........ ......## ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## :COL=7,1 :COL=4,0 :COL=4,0 :COL=9,0 :COL=1,0 :COL=5,0 :COL=1,0 :COL=4,0 :COL=4,1 :COL=4,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=2,1 :COL=2,1 ; 05 .......o ......#. ........ ..##...x ........ ........ ........ ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ..##.... ......#. ........ .####... ........ ..####.. ........ ...##### #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## .####... ......## ........ ..##.... ........ .######. ........ .......# #....... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ..##.... ......## ........ ........ ........ ######## ........ .......# ##...... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ......## ........ ........ ........ ######## ........ ........ ###..... ........ ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ .....### ........ .....##. ........ #.###### ........ ........ #######. .#...... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ .....### #....... ....#### ........ .#..###. ........ ........ ######## ####.... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ .....### #....... .....##. ........ ..####.. ........ .......# ######## ###..... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## :COL=0,1 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=2,0 :COL=5,0 :COL=4,0 :COL=4,1 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=7,0 :COL=7,0 :COL=1,0 :COL=2,1 :COL=2,1 ; 06 ........ ....##.# ##...... ........ ........ ........ ..##...o .......x ......## ##...... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## .....#.. ....##.. ###..... ........ ........ ........ .####... ..##.... .......# ##...... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ...###.. .####... ........ ........ ........ ..##.... .####... ........ ###..... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ...#.... ...##... ...####. ........ ........ ........ ........ ..##.... ........ ####.... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## .......# ..###... .....### ####.... ........ ........ ........ ........ ........ #####... ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ ..##.... ........ ######## ##...... ........ .....##. ........ .......# #######. ........ ........ ........ ........ ........ ........ ........ ........ ######## ######## ........ .##..... ........ ...##### ######.. ........ ....#### ........ ...##### .....#.. ........ ........ ........ ........ ........ .....### #####... ........ ######## ######## ........ ##...... ........ ........ ..###### ######## .....##. ........ ######## ........ ........ ........ ........ ........ ........ ....#### ##..##.. ........ ######## ######## :COL=1,1 :COL=1,0 :COL=1,0 :COL=1,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,1 :COL=4,0 :COL=4,0 :COL=1,0 :COL=1,0 :COL=7,0 :COL=7,0 :COL=7,0 :COL=7,0 :COL=2,0 :COL=2,1 :COL=2,1 ; 07 ........ ........ ........ ........ ......## ######## ######## ######## ###..... ........ ........ ........ ........ .....### #######. ...##### #.###.#. ######## ######## ######## ........ ........ ........ ........ ........ ....#### ######## ######## #....... ........ ........ ........ ........ ...##### ....#### #..##### .######. ######## ######## ######## ........ ........ ........ ........ ........ ........ ........ ......## #....... ........ ........ ........ ........ ...####. #######. ##.##### ...####. ######## ######## ######## ........ ........ ........ ........ ........ ........ ........ .......# ##...... ........ ........ ........ ........ ...##### ...##### .#..###. ...####. ######## ######## ######## ........ ........ ........ ........ ........ ........ ........ ........ ###..... ........ ........ ........ ........ ...##### .....### ####.##. ..#####. ######## ######## ######## ........ ........ ........ ........ ........ ........ ........ ........ #######. ........ ........ ........ ........ ...##### #....### #.#####. .#####.. ######## ######## ######## ........ ........ ........ ........ ........ ........ ........ ........ ######## #....#.. ...#.... ........ ........ ....#### #######. ######## ####.... ######## ######## ######## ........ ........ ........ ........ ........ ........ ........ ......## ######## ######## #####... ........ ........ .......# #####..# ####.### ##...... ######## ######## ######## :COL=1,1 :COL=9,0 :COL=8,0 :COL=1,0 :COL=7,0 :COL=1,0 :COL=1,0 :COL=6,0 :COL=4,0 :COL=4,0 :COL=4,1 :COL=4,0 :COL=1,0 :COL=7,1 :COL=7,0 :COL=7,0 :COL=7,0 :COL=2,0 :COL=2,1 :COL=2,0 ; 08 ........ ..##...o ........ ........ .......x ........ ........ ........ ......## ######## ###..... ........ ........ ........ ..###### .###..#. ####.... ......## ######## ######## ........ .####... ...#.... ........ ..##.... ........ ........ ..####.. ........ ######## #....... ........ ........ .......# #######. ####.#.. .####... ......## ######## ######## ........ ..##.... ...#.... ........ .####... ........ ........ .######. ........ ......## #....... ........ ........ .....### ###..... ####.#.. ..####.. ......## ######## ######## ........ ........ ..###... ........ ..##.... ........ ........ ######## ........ .......# ##...... ........ ........ ....#### ........ ####.#.. ..####.. ......## ####...# ######## ........ ........ #######. ........ ........ ........ ........ ######## ........ ........ ###..... ........ ........ ....###. ........ ####.#.. ...####. ......## ###..... #...#### ........ .....##. ..#.#... ........ ........ ........ ........ #.###### ........ ........ #######. ........ ........ ....###. ........ ####.#.. ....###. ......## #....##. ..#..### ........ ....#### ...#.... ........ ........ ........ ........ .#..###. ........ ........ ######## #....#.. ........ ....#... ........ ####.#.. ....###. ......## ..##..#. .##....# ........ .....##. ...#.... ........ ........ ........ ........ ..####.. ........ ......## ######## ######## ........ ........ ........ ####.#.. .....#.. ......## ..###.#. #...##.. :COL=2,1 :COL=5,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=1,0 :COL=0,0 :COL=0,0 :COL=8,0 :COL=1,0 :COL=9,0 :COL=4,0 :COL=4,1 :COL=7,1 :COL=7,0 :COL=7,0 :COL=7,0 :COL=1,1 :COL=6,0 :COL=6,0 ; 09 .......x ........ ........ ........ ........ ........ ..##...o .......x ........ ........ .......x ######## ###..... ........ ........ ####.#.. ........ ........ #....... ........ ..##.... ..####.. ........ ........ ........ ........ .####... ..##.... ...#.... ........ ..##.... ...##### #....... ........ ........ ####.#.. ........ ........ .##.#... #.....#. .####... .######. ........ ........ ........ ........ ..##.... .####... ...#.... ........ .####... .......# #....... ........ ........ ####.#.. ........ ........ ....###. ##..##.. ..##.... ######## ........ ........ ........ ........ ........ ..##.... ..###... ........ ..##.... .......# ##...... ........ ........ #####... ........ ........ ....#### ........ ........ ######## ........ ........ ........ ........ ........ ........ #######. ........ ........ ........ ###..... ######## ######## .####### ######## ........ ....#### ........ ........ #.###### ........ ........ ........ ........ .....##. ........ ..#.#... ........ ........ ........ #######. ######## ######## ######## ######## ........ ....#### ........ ........ .#..###. ........ ........ ........ ........ ....#### ........ ...#.... ........ ........ ........ ######## ######## ######## ######## ######## ........ ....#### ........ ........ ..####.. ........ ........ ........ ........ .....##. ........ ...#.... ........ ........ .......# ######## ######## ######## ####.### ######## ........ ....###. ........ :COL=8,1 :COL=1,0 :COL=2,0 :COL=4,0 :COL=1,0 :COL=8,0 :COL=1,0 :COL=1,0 :COL=4,0 :COL=6,0 :COL=3,0 :COL=0,0 :COL=4,0 :COL=4,1 :COL=4,1 :COL=7,0 :COL=1,0 :COL=6,1 :COL=6,0 :COL=6,0 ; 0A ........ ........ .......x ......#. ........ .......o ........ ........ ........ .......x ..##...o ........ ......## #....... ........ ####.#.. ........ ######## ###.#### ######## ...#.... ........ ..##.... ......#. ........ ..##.... ........ ........ ........ ..##.... .####... .....#.. .......# ##...... ........ ####.#.. ........ ######## ######## ######## ...#.... ........ .####... ......## ........ .####... ........ ........ ........ .####... ..##.... ........ ........ ##...... ........ ####.#.. ........ ........ ....###. ........ ..###... ........ ..##.... ......## ........ ..##.... ........ ........ ........ ..##.... ........ ...#.... ........ ####.... ..#..... ####.#.. ........ ######## ###.#### ######## #######. ........ ........ ......## ........ ........ ........ ........ ........ ........ ........ .......# ........ #######. ..##.... ####.#.. ........ ........ ....#### ........ ..#.#... ........ ........ .....### ........ ........ ........ ........ ......#. ........ .....##. ........ .......# ######## ###..... ####.#.. ........ ........ ....#### ........ ...#.... ........ ........ .....### ........ ........ ........ ........ ......## ........ ....#### ........ ...##### ######## ####.... ####.#.. ........ ........ ....#### ........ ...#.... ........ ........ .....### ........ ........ ........ ........ .......# ........ .....##. ........ ######## ######## ####.... ####.#.. ........ ........ ....#### ........ :COL=1,1 :COL=1,0 :COL=0,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=5,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,0 :COL=4,1 :COL=7,1 :COL=2,0 :COL=A,1 :COL=6,0 :COL=6,0 ; 0B ........ ........ ........ ....##.# ##...... ........ ........ ........ ........ ##...... ........ ........ ........ ......## ##...... ####.#.. ..####.. ..####.. ....#### ........ ........ ........ .....#.. ....##.. ###..... ........ ........ ........ ..####.. ###..... ........ ........ ........ ........ ##...... ####.#.. .######. .######. ....#### ........ ........ ........ ........ ...###.. .####... ........ ........ ........ .######. .####... ........ ........ ........ ........ ###..... ####.#.. .##.#.#. .#.#.##. ....#### ........ ........ ........ ...#.... ...##... ...####. ........ ........ ........ ######## ...####. ........ ........ ........ .......# ####.... ####.#.. .######. .######. ....#### ........ ........ ........ .......# ..###... .....### ####.... ........ ........ ######## .....### ####.... ........ ........ ......## #####... ####.#.. .######. .######. ....#### ........ ........ ........ ........ ..##.... ........ ######## ##...... ........ #.###### ........ ######## ##...... ........ ...##### #######. ####.#.. .######. .######. ....#### ........ ........ ........ ........ .##..... ........ ...##### ######.. ........ .#..###. ........ ...##### ######.. ........ ######## .....#.. ####.#.. .#.#..#. .#..#.#. ....#### ........ ........ ........ ........ ##...... ........ ........ ..###### ######## ..####.. ........ ........ ..###### ######## ######## ........ ####.#.. ........ ........ ....#### ........ ; 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 1 Quote Link to comment Share on other sites More sharing options...
