DrWoo Posted May 22, 2017 Share Posted May 22, 2017 I just received an Atari SC1224 monitor without the video cable. Any ideas on where I can get one from? Preferable somewhere in the US. Dr.Woo! Quote Link to comment Share on other sites More sharing options...
mattsoft Posted May 22, 2017 Share Posted May 22, 2017 Best Electronics (http://best-electronics-ca.com) or Bravo Sierra Computers (http://www.aracnet.com/~atari/) has them. Quote Link to comment Share on other sites More sharing options...
+rdemming Posted May 23, 2017 Share Posted May 23, 2017 All my SC1224 and SM124 monitor have video cables fixed at the monitor. Not always the best solution but you can never loose the cable I believe there are at least 3 variants of the SC1224 monitor and one had the round Atari 13 pin connector on it instead of a fixed cable. Atari should have used a standard DB-9 connector so you can easier connect other systems to it. Quote Link to comment Share on other sites More sharing options...
DrWoo Posted May 23, 2017 Author Share Posted May 23, 2017 All my SC1224 and SM124 monitor have video cables fixed at the monitor. Not always the best solution but you can never loose the cable I believe there are at least 3 variants of the SC1224 monitor and one had the round Atari 13 pin connector on it instead of a fixed cable. Atari should have used a standard DB-9 connector so you can easier connect other systems to it. I just learned of the differences in the monitors. Apparently the JVC model is the one that had the detachable cable. I agree it would have been nice if they had used a more standard connector. Unfortunately the one I order from eBay didn't have the cable, ugh!! But I did order one from BEST. Quote Link to comment Share on other sites More sharing options...
