That's the CV compatible console we're working on with Bmack36
Psss.... No, that's not a video capture card
Posted Wed May 24, 2017 1:04 PM
Posted Wed May 24, 2017 1:08 PM
Psss.... No, that's not a video capture card![]()
I bet Coleco would like to get their hands on that. To them it'd be a turnkey system ready to roll.
Posted Wed May 24, 2017 2:45 PM
Posted Wed May 24, 2017 3:07 PM
I'm in touch with Eduardo
We both want to work together for our systems
Posted Wed May 24, 2017 8:46 PM
Both would be backwards compatible but different going forwards?
Yes, correct
Unless they share similar capabilities in the enhancement department, two competing standards will result in marketplace fragmentation. Then someone will have to build a system that supports both potentially incompatible enhancement standards. Do re really need a VHS/Betamax style format war in the homebrew community? This is why you guys need to compare notes and create compatible designs.
Posted Wed May 24, 2017 8:58 PM
Posted Wed May 24, 2017 9:11 PM
That makes a ton of sense too me as part of the target audience. It seems shared costs would be desirable on the business side also.
Although both systems will be colecovision compatible systems, they are focused on 2 different ideas. Opcode is focused on building up their SGM brand and New 16bit capabilities in a closed environment. My board is focused more on giving the community a better more reliable way to play primarily colecovision games as well as other systems like MSX, NES, and many more in an open source environment where more functionality can be added by anyone who wants and is able to contribute.
Posted Wed May 24, 2017 9:32 PM
So it's an FPGA based board isn't it?
The NES CPU/PPU have been reversed eng but there are no off-the-shelf parts available to build them afaik
OpCode seems to be using real 80s tech, chipset and CPU included (maybe at much higher clock rate, switchable for backcompat).
Posted Wed May 24, 2017 9:42 PM
The NES CPU/PPU have been reversed eng but there are no off the shelf part available to build one afaik.
OpCode seems to be using real 80s tech, chipset and CPU included (maybe at much higher clock rate)
Yes, My board is FPGA based.
Posted Wed May 24, 2017 11:56 PM
Is it FPGA based?
Note to self: read the full thread before asking questions that have already been answered.
Posted Thu May 25, 2017 2:47 AM
Posted Thu May 25, 2017 5:53 AM
I don't think we are really competing here because we are focusing on different concepts. One is FPGA based. The other uses 80s tech with dedicated chips.
Prometheus offers CV and SGM compatibility in a single solution, and extends that with 16 bit quality graphic and sound. Those projects are all personal, and in the end Prometheus implements my take on how I believe the CV would have evolved.
I see both consoles coexisting nicely. The SGM and 16 bit part are exclusive to Prometheus (although Brian's console could eventually offer their own 16 bit feature set), while Brian's board offers the flexibility of FPGA and can run more platforms than just CV.
Posted Thu May 25, 2017 3:39 PM
This is nice. I never owned a Colecovision, and was hesitant to get one due to the hardware related issues. The Promethius would make a nice first Coleco and if I didn't have to buy an SGM and would have full homebrew support, that would be nice. One concern is if you use vintage 5V logic chips to build your console, existing stock may become depleted in the future resulting in discontinuation and high prices on the secondhand market. This would also negatively impact the market for homebrew games available for it if supply of decades old NOS chips became an issue.
I am curious if the 16-bit component would run game off an existing Coleco Max flashcart, or if it requires additional bus pins or other hardware, etc making it incompatible. I enjoy testing WIP ROMs of homebrew games to determine if I like the game enough to buy a cart (if I like a game enough, I usually make an effort to get it on cart). Also will the 16-bit portion be comparible performance wise to 4th gen consoles such as Sega Genesis, SNES, Turbografx (and possibly Neo-Geo though that might be pushing it)? It will be important for a 16-bit console to have good 4th-gen like performance (actual 16-bit era performance and not just 16-bit in technical terms only like Intellivision) and simultaneously be easy to program for. I have heard specifically SNES 65C816 assembly as well as the custom audio chip is a pain to work with.
There will be lots of FPGA projects coming out of the woodworks. I own one which is the excellent AVS, albeit a one trick pony in light of Kevtris jailbreak NT Mini which is currently the most ambitious of the FPGA projects available. So I may pick up an NT Mini or Colectorvision FPGA board in the future if it gets lots of support and the price is right, or wait for the Zimba3000. I think the Promethius may also potentially be clonable on an FPGA board if it uses standard components which all have been mapped out.
Posted Thu May 25, 2017 7:46 PM
My only concerns (and the same applies to Opcode's thingie) are as follows:
1. Is it reliable?
2. Is it fully ColecoVision compatible, or at least as CV compatible as reasonably possible?
3. Will it look nice in an entertainment center?
4. Is it reasonably priced?
It's hard to tell from the prototype, but what I'm seeing here already looks like an improvement from the stock ColecoVision PCB. It doesn't look like it'll support many of the CV's optional peripherals, but that's an acceptable loss if it keeps the price down. HDMI out is a very welcome touch.
Posted Thu May 25, 2017 7:53 PM
Posted Thu May 25, 2017 7:56 PM
What are the dimensions of the board? I know you are making a whole console but I'm just curious if the board would fit inside a Colecovision Flashback.
Posted Thu May 25, 2017 10:52 PM
I plan to buy this when it comes out as well.. I plan to buy both this board and the Opcode board. I intend to fully support both of the developers trying to get us stable hardware.
Posted Fri May 26, 2017 2:49 AM
Edited by artrag, Fri May 26, 2017 2:52 AM.
Posted Fri May 26, 2017 2:40 PM
Confirmed specs are now in the 1st post
Posted Fri May 26, 2017 2:44 PM
Posted Fri May 26, 2017 2:49 PM
