CollectorVision Game System
1216 replies to this topic
#26 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Fri May 26, 2017 2:52 PM
I get why SGM is not supported internally but how about an expansion port so one could attach a SGM?
These are not the final specs, so it's still possible that we put the Expansion Port
Edited by retroillucid, Fri May 26, 2017 2:53 PM.
  • Rey likes this
#27 SignGuy81 OFFLINE
SignGuy81
  • 1,685 posts
Posted Fri May 26, 2017 4:19 PM
Confirmed specs are now in the 1st post
Can you also add the board dimensions, I'm curious if it will fit in a flashback?
Edited by SignGuy81, Fri May 26, 2017 4:19 PM.
#28 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Fri May 26, 2017 4:22 PM
It's going to fit an original CV system shell
We'll offer it as a replacement board and as a full unit (including the system shell)
#29 ApolloBoy OFFLINE
ApolloBoy
  • 5,742 posts
Posted Fri May 26, 2017 5:04 PM
Yeah being able to play SGM games would be nice.
#30 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Fri May 26, 2017 5:07 PM
You'll have this with Opcode Prometheus console! :)
Both consoles offer something completely different
#31 SignGuy81 OFFLINE
SignGuy81
  • 1,685 posts
Posted Fri May 26, 2017 5:10 PM
I figured but I was still curious as to whether it would fit in a flashback shell.  I looked all over just trying to find dimensions for a Coleco Flashback shell and found nothing other than the box dimensions that it comes in.  I don't have one.  So luckily I found a picture of one online sitting in a box with the top removed and was able to use a little algebra to determine that he Colecovision Flashback is approximately 8.5" long.  I then had to look up the specs on a standard 15 position card edge connector used on the board and got the dimensions off that and was able to do the same to come up with approximate lenght of that board and came up with 6.7" long.  Both pics I went by were angled looking at it so I didn't try to get the width of either(front to backside) but from looking I believe I can tell with just the measurements I have I can tell it will probably work, I just don't know how hot the board gets and if it would be good idea to put it in a smaller case.  Also the buttons and board for them on the flashback may be in the way not sure if the board would fit under it, or if some other modification would be necessary there.
EDIT:
Also too the controller ports would have to either be cut out on the case or ports put in the case where originally were and then wired to the board and a few other modifications for power input and video, so it might would get kinda tight in the end but was just curious if it would fit.
Edited by SignGuy81, Fri May 26, 2017 5:17 PM.
#32 phoenixdownita OFFLINE
phoenixdownita
  • 3,471 posts
Posted Fri May 26, 2017 5:12 PM
Why not going for the XC6SLX45 instead, it's 18US$ of the LX9 vs 55US$ of the LX45, those extra 36US$ would be well worthy (5x the LEs for just 3x the price)
LX9
https://www.digikey....1744-ND/2339913
LX45
https://www.digikey....1673-ND/2408283
#33 imstarryeyed OFFLINE
imstarryeyed
    Dragonstomper
  • 596 posts
Posted Sat May 27, 2017 10:26 AM
Would it be a problem to add a Composite or SVideo or Component jacks to the unit?  I use my classic consoles on a CRT because it has excellent color, is NOT widescreen and creates no lag whatsoever. If it is not possible that is acceptable but I thought I would ask for those of us who prefer to use the classic CRT over an HD TV.
I am also a +1 for the expansion port as I would love to hook up my SGM module, as the Promethus board will not need one and I would like to retire of my old Colecovision that is very unstable.
I would also wonder if the Atari 2600 module could be used if there was a port?  That would be really cool if it was possible.
The board looks so small that it looks like it would fit into the Atari Expansion module itself.. haha..
Thank you very much for even asking the board.
#34 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Mon May 29, 2017 11:10 PM
Current specs
#35 artrag OFFLINE
artrag
  • 1,213 posts
Posted Mon May 29, 2017 11:58 PM
Humm, why not supporting sgm? Once you have msx and colecovision, sgm implementation goes almost free
#36 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Tue May 30, 2017 1:11 PM
We're not supporting it in respect of Eduardo's works
Opcode doesn't want our system to support the SGM
And we're okay with this
#37 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Tue May 30, 2017 1:13 PM
CollectorVision System with enhanced arcade fonts!
Left: Original Colecovision bios
Right: CollectorVision custom bios
#38 phoenixdownita OFFLINE
phoenixdownita
  • 3,471 posts
Posted Tue May 30, 2017 1:43 PM
Wrt to the specs it's 2Mb as in Mbits, not a typo right?
(2Mbits aka 256KBytes)
Also given the cart slot seems to be for CV carts the other systems will be SD card driven only right [meaning load "teh romz" into RAM and run it form there)?
the SMS can give you issues in that regard because 4Mbits and 8Mbits carts do exists
http://www.smspower....TidesOfTime-SMS
http://www.smspower....erAnimation-SMS
#39 ApolloBoy OFFLINE
ApolloBoy
  • 5,742 posts
Posted Tue May 30, 2017 5:33 PM
You sure you two can't work something out? I'm sure there's an interest for people who don't necessarily want the extra functionality of the Prometheus but still want some kind of SGM compatibility. It just seems short-sighted considering there's a lot of SGM-only homebrews floating around.
Edited by ApolloBoy, Tue May 30, 2017 5:34 PM.
#40 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Tue May 30, 2017 5:38 PM
...It just seems short-sighted considering there's a lot of SGM-only homebrews floating around.
Wich 90% of them are MSX ports
Our system is MSX compatible
#41 LoTonah OFFLINE
LoTonah
    Dragonstomper
  • 544 posts
Posted Wed May 31, 2017 1:14 AM
Well, maybe in the future Opcode could potentially offer a software "upgrade", for say $50, that would allow SGM games to play on it.
But even if it is never offered, this looks tasty.  Potentially could run LOTS of things, like maybe a cartridge that would allow a keyboard to hook up to it (and other various hardware).  Would die to have a new ADAM kit, for instance!
#42 Bmack36 ONLINE
Bmack36
    Dragonstomper
  • 638 posts
Posted Wed May 31, 2017 5:03 AM
The system will already support a PS/2 keyboard directly on the board.
#43 Kiwi ONLINE
Kiwi
  • 1,658 posts
Posted Wed May 31, 2017 7:42 AM
That makes sense.  It'll have the soundchip and enough SRAM to run the MSX games as is.
#44 Bmack36 ONLINE
Bmack36
    Dragonstomper
  • 638 posts
Posted Wed May 31, 2017 4:54 PM
I love when stuff comes in early. I'll be busy for a while.
#45 killersquirel OFFLINE
killersquirel
    Dragonstomper
  • 770 posts
Posted Wed May 31, 2017 4:58 PM
I will be supporting both yours and opcode's system. I think it would be great if you can add the expansion port so that people that own an SGM can use it on your unit. That could also help sales of the SGM as well.
In regards to MSX compatibility, is it MSX1 only or will it also support MSX2 and Turbo R systems?
#46 Pixelboy OFFLINE
Pixelboy
  • 8,162 posts
Posted Wed May 31, 2017 5:24 PM
MSX support is certainly interesting. Too bad MSX carts and ColecoVision carts don't have the same pinout, although I have to wonder if MSX carts use all 50 pins... If only 30 pins were actually used, perhaps some 30-pin PCBs could be devised onto which one could put MSX ROMs. :)
#47 Special Teams OFFLINE
Special Teams
    Dragonstomper
  • 927 posts
Posted Wed May 31, 2017 6:20 PM
Will the MSX, SMS etc "support" be in the form of accepting SD cards with ROMs or cartridge slots (or both)?
#48 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Wed May 31, 2017 6:55 PM
ColecoVision have a cartridge port (you can still load games from the SD card)
The other systems will load games from the SD card only (no cartridge port)
Edited by retroillucid, Wed May 31, 2017 7:05 PM.
#49 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Wed May 31, 2017 6:58 PM
As you can see, the concept is really simple!
A brand new CV system shell with a FPGA board inside of it
Nothing too fancy here, simply just reliable!   :twisted:
RGB, HDMI, VGA and Composite output
Edited by retroillucid, Wed May 31, 2017 6:59 PM.
#50 retroillucid ONLINE
retroillucid
  • 8,094 posts
Posted Wed May 31, 2017 7:06 PM
I hope so!
Both systems are going to be great systems, just different :)
