Output to PC text file or PC printer?
18 replies to this topic
#1 Dropcheck OFFLINE
Dropcheck
  • 1,456 posts
Posted Sat May 27, 2017 5:00 PM
Short of hooking up a real dot matrix printer to a real 800XL/130XE, is there a way to take a basic program and print the listing to either a PC .txt file or printer?
#2 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,721 posts
Posted Sat May 27, 2017 5:04 PM
LIST "D1:filename.lst"
then using an atascii to ascii utility.. there are a ton....
transfer it to the pc anyway you like...
I am sure there are other ways but this is the no frills get it don method
Edited by _The Doctor__, Sat May 27, 2017 5:05 PM.
#3 Dropcheck OFFLINE
Dropcheck
  • 1,456 posts
Posted Sat May 27, 2017 5:12 PM
Thanks,
Worked very well.  I've forgotten more than I thought.  :(
#4 Rybags OFFLINE
Rybags
    Gridrunner
  • 16,083 posts
Posted Sat May 27, 2017 9:06 PM
It can be even easier than that.
Atari800Win+ has the option to direct P: output straight to Notepad.
Altirra allows a "Printer Window" - you first have to use System->Devices to add the P: HLE device then View->Printer Output to open another window that'll contain captured output.
Once you have whatever listings and printer output you need you can select blocks of text with the mouse and Ctrl-C to copy it, then paste it to whatever PC based application you're using.
#5 DrVenkman OFFLINE
DrVenkman
  • 3,956 posts
  • Back off, man! I'm a scientist.
Posted Sat May 27, 2017 9:31 PM
And if you're using real hardware, most SIO peripheral emulators allow at least basic text capture from the P: device to a window on the host device. You can then do whatever you want with that text file on your PC/Mac/Linux box.
#6 _The Doctor__ OFFLINE
_The Doctor__
  • 6,721 posts
Posted Sat May 27, 2017 10:00 PM
Cool, the method outlined will work for everything including modem/terminal transfers etc...
it seems respeqt does a nice output using an Atascii like output....
LIST "P:"
Giving it a whirl
Edited by _The Doctor__, Sat May 27, 2017 10:01 PM.
#7 Dropcheck OFFLINE
Dropcheck
  • 1,456 posts
Posted Sun May 28, 2017 5:51 AM
Works very nice for Altirra. :)
#8 gargoyle OFFLINE
gargoyle
    Chopper Commander
  • 185 posts
Posted Sun May 28, 2017 12:36 PM
I use SIO2PC with Aspeqt for doing that. Just print the file to the P: device and you can get both ASCII and ATASCII output on the screen. But i guess you need to print the ASCII version on your PC printer if I remember it correctly. You can also save it to a file on PC, again if i remember correctly it converts the EOL characters automatically.
#9 manterola OFFLINE
manterola
    Moonsweeper
  • 342 posts
Posted Thu Dec 6, 2018 3:43 PM
Hi I am trying to get Raw printing data in a PC or linux file from the Atari, yesterday I tried Altirra64.exe running in linux using wine (as I usually do), however the printer output window was always empty (lprint and list "d: gave me error 138, I guess). But, anyway my intentions are to capture the raw data from a real Atari (running something like newsroom) using sio2pc homemade cable, and use the file created  with the info in dosprinter to see if it works with graphics programs like the already mentioned newsroom or printshop using the Epson FX output.
I don't have atarimax software, just a compiled latest version of RespeQt running in ubuntu and sio2linux command line utility.
Thanks!
Edit: I am also interested in capturing any (not just P:) SIO raw data to understand the functioning of the SIO bus and how Atari 1030 sends booting info to the Computer.  Can that be done? maybe something like ser or other linux tool?
Edited by manterola, Thu Dec 6, 2018 3:46 PM.
#10 manterola OFFLINE
manterola
    Moonsweeper
  • 342 posts
Posted Tue Dec 11, 2018 12:37 AM
YAY!  I modified sio2linux.c to add a rudimentary capture to printer data to file. Then I used DOSPrinter to convert to pdf. It worked!!!!!!!!
I cannot believe it, yet.  There is a EOL convertion probably to be done when dealing with text, but it worked almost perfectly for graphics data in Epson format. I used Atari Planetarium Control-P to print and capture the data.
This is the result:
#11 Brentarian OFFLINE
Brentarian
    Moonsweeper
  • 478 posts
Posted Tue Dec 11, 2018 10:37 AM
This is the result:
Very cool! Any chance you could write up directions on how to set this up?
I've also been looking at the Retroprinter.com that is supposed to be released soon. It takes parallel output from a computer, converts from Epson, and saves to PDF or prints to any PCL/GDI printer.
#12 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 708 posts
  • Lost in the Robot Factory
Posted Tue Dec 11, 2018 11:45 AM
The guys at retroprinter.com have put the esc/p software on github here.  https://github.com/RWAP/PrinterToPDF
A cool project would be to integrate that with RespecQT so every SIO2PC could also be used as a printer interface
#13 manterola OFFLINE
manterola
    Moonsweeper
  • 342 posts
Posted Wed Dec 12, 2018 12:00 AM
I'll improve the printer data dumper and put it here. RespeQt already had the printer emulation functionality, so it shouldn't be hard to add writing to a file.
Later, the retroprinter can be done,but for now the close source commercial DosPrinter gets the job done.
#14 Mr Robot OFFLINE
Mr Robot
    Dragonstomper
  • 708 posts
Posted Wed Dec 12, 2018 9:58 AM
Respecqt's printer emulation is simple text, the retroprinter code is esc/p
#15 manterola OFFLINE
manterola
    Moonsweeper
  • 342 posts
Posted Wed Dec 12, 2018 10:19 AM
Right but it is not really a difference: Atari just sent 40 bytes at the time,  RespeQt can be modified to just dump those bytes to a raw prn file (in a first phase). Once the retroprinter open source conversion to pdf is sorted out, the DosPrinter part is not needed anymore and the retroprinter code can be added to RespeQt. I did the dump to a file in sio2linux code just because is was simple straight forward code to understand. With a little more effort similar functionality can be implemented in RespeQt.
#16 manterola OFFLINE
manterola
    Moonsweeper
  • 342 posts
Posted Fri Dec 14, 2018 11:56 PM
Here is the code: compile with:
gcc -W -Wall -o sio2linuxp sio2linux-3.1.0MM.c
use like this:
./sio2linuxp -s /dev/ttyUSB0 -p ~/Downloads/dosprinter/newr.prn "Atari Planetarium (1985)(Atari)(Side A).atr"
then use Dosprint like this:
wine DOSPrinter.exe /S /9PIN /PDF newr.prn
 * Copyrights are held by the respective authors listed below.
 * Licensed for distribution under the GNU Public License version 2.0 or later.
 * You need to use a sio2pc cable to run this.
 * Compilation:
 * gcc -W -Wall -o sio2linux sio2linux-3.1.0.c
 * Currently, this does not support the 'format' or 'verify' SIO
 * commands.
 * TO-DO:
 * * Add support for missing drive commands.
 * * Add a watch/copy mode where it watches I/O to a real drive and
 *   uses that to create a copy.  Hence, all you need to do to copy
 *   a disk is read every sector from the Atari.
 *   This might not be possible.  It seems that the read responses from
 *   my 1050 aren't visible on the Linux serial port.  This may be
 *   a limitation in my sio2pc cable.
 * * Add a keyboard user interface to add/remove/swap disks during
 *   run time.
 * * Enhance support for dynamic disk images that are live access to the
 *   Linux file system.  It could use My-DOS style subdirectories.
 *        Support for creating new files could be added.
 *        Support for more than one file open at a time could be added.
 * * Add support for cassette transfers, allowing BASIC programming with
 *   fast I/O, but without the memory cost of DOS, as well as support for
 *   the few programs that required a cassette drive, or for loading cassette
 *        images.  The 410 recorded at 600 baud, and apparently worked in a raw
 *   streaming mode instead of the normal SIO command-frame mode.  My SIO2PC
 *   cable does not forward the signal from pin 8 (cassette motor control), so
 *   it would be difficult at best to get it to work correctly.  In any
 *   case, emulating the raw 600 baud signal would require a significant
 *   programming effort, which is not something I'm likely to do anytime
 *   soon.
 * * Add support for printers
 * * Add 850 R: emulation
 *   Loading of the R: handler by the 850 worked by having the 850
 *        act as D1: if it first saw ignored status requests for D1:.  The 850
 *        then sends a 3-sector boot program that sends 3 comands to the R1:
 *        device.  Apparently the boot program loads and installs the R: handler
 *        and then goes away.
 * * Add 1030 T: emulation
 *        The boot process is probably quite similar to the 850 mechanism.
 * Version History:
 * Version 3.1.0 13 Oct 2010    Preston Crow
 * Add support for ignoring the ring line, as some USB-to-serial converters
 *      don't handle this correctly.  Timings for Ack/Completion were adjusted to
 *      account for buffered writes.
 * Version 3.0.1 22 Nov 2008    Preston Crow
 *      Clear RTS before listening for a command.  This has no effect with an
 *      original SIO2PC cable, but it enables compatibility mode in some other
 *      cables so that they will behave as expected.
 * Version 2.0.1 5 Sep 2005 Preston Crow
 *      Fix bug in -s option for selecting serial port
 * Version 2.0  19 Aug 2005 Preston Crow
 *      Renamed to sio2linux.
 *      Clean up to read the commands properly.
 * Add features: Create blank images, quiet mode, skip image, specify serial device
 * Version 1.4 22 Mar 1998 Preston Crow
 * Added support for read-only images.  Any image that can't
 * be opened for read/write will instead be opened read-only.
 * Also, if a '-r' option appears before the image, it will
 * be opened read-only.
 * Cleaned up a few things.  The system speed is now determined
 * dynamically, though it still uses the Pentium cycle counter.
 * A status request will now send write-protect information.
 * Added a short usage blurb for when no options are specified.
 * It should be slightly more tollerant of other devices active
 * on the SIO bus, but it could still confuse it.
 * Version 1.3 20 Mar 1998 Preston Crow
 * The status command responds correctly for DD and ED images.
 * This version is fully functional.  Improvements beyond this
 * release will focus on adding a nice user interface, and
 * making it better at recognizing commands, so as to interact
 * safely with real SIO devices.  A possible copy-protection
 * mode may be nice, where the program watches all the activity
 * on D1: while the program loads off of a real device, recording
 * all data, timing, and status information.  Whether yet another
 * file format should be used, or some existing format, is an open
 * matter.
 * Version 1.2 17 Mar 1998 Preston Crow
 * I've added in support for checking the ring status after reading
 * a byte to determine if it is part of a command.  However, as this
 * requires a separate system call, it may be too slow.  If that proves
 * to be the case, it may be necessary to resort to direct assembly-
 * language access to the port (though this would eliminate compatibility
 * with non-Intel Linux systems).  That seems to not work well; many
 * commands aren't recognized, at least when using the system call to
 * check the ring status, so I've implemented a rolling buffer that will
 * assume it has a command when the last five bytes have a valid checksum.
 * That may cause problems if a non-SIO2PC drive is used.
 * It seems to work great for reading SD disk images right now.
 * I haven't tested writing, but I suspect it will also work.
 * It has problems when doing DD disk images.  I suspect the
 * problem has to do with the status command returning hard-coded
 * information.
 * The debugging output should be easier to read now, and should always
 * be printed in the same order as the data is transmitted or received.
 * Version 1.1 Preston Crow
 * Lots of disk management added.
 * In theory, it should handle almost any ATR or XFD disk image
 * file now, both reading and writing.
 * Unfortunately, it is quite broken right now.  I suspect timing
 * problems, though it may be problems with incorrect ACK/COMPLETE
 * signals or some sort of control signal separate from the data.
 * Version 1.0 Pavel Machek <pavel@atrey.karlin.mff.cuni.cz>
 * This is Floppy EMULator - it will turn your linux machine into
 * atari 800's floppy drive. Copyright 1997 Pavel Machek
 * <pavel@atrey.karlin.mff.cuni.cz> distribute under GPL.
 * Standard include files
#include <stdio.h>
#include <termio.h>
#include <errno.h>
#include <fcntl.h>
#include <stdlib.h>
#include <unistd.h>
#include <ctype.h>
#include <string.h>
#include <sys/types.h>
#include <sys/timeb.h>
#include <sys/stat.h>
#include <sys/ioctl.h>
#include <dirent.h>
#include <errno.h>
#include <sys/time.h>
#ifndef MAXPATHLEN
#define MAXPATHLEN 1024
#endif
 * Data structures
struct atr_head {
unsigned char h0; /* 0x96 */
unsigned char h1; /* 0x02 */
unsigned char seccountlo;
unsigned char seccounthi;
unsigned char secsizelo;
unsigned char secsizehi;
unsigned char hiseccountlo;
unsigned char hiseccounthi;
unsigned char unused[8];
enum seekcodes {
xfd, /* This is a xfd (raw sd) image */
atr, /* This is a regular ATR image */
atrdd3, /* This is a dd ATR image, including the first 3 sectors */
direct  /* This is a directory pretending to be a disk image */
struct atari_dirent {
unsigned char flag; /* set bits:
       7->deleted
       6->normal file
       5->locked
       4->MyDOS subdirectory
       3->???
       2->??? \ one for >720, one for >1024 ?
       1->??? /  all for MyDOS?
       0->write open */
unsigned char countlo; /* Number of sectors in file */
unsigned char counthi;
unsigned char startlo; /* First sector in file */
unsigned char starthi;
char namelo[8];
char namehi[3];
struct trackformat {
int offset[18]; /* sector offset from start: offset[i]==i*100 if no skew */
int bad[18]; /* Only set with special SIO2Linux command */
struct image {
int secsize; /* 128 or 256 */
int seccount; /* 720, 1040, or whatever */
enum seekcodes seekcode;/* Image type */
int diskfd; /* file descriptor */
int ro; /* non-zero if read-only */
int active; /* non-zero if Linux is responding for this disk */
int fakewrite; /* non-zero if writes are accepted but dropped */
int blank; /* non-zero if disk can grow as needed */
* Stuff for directories as virtual disk images
DIR *dir; /* NULL if not a directory */
int filefd; /* fd of open file in directory */
int afileno; /* afileno (0-63) of open file */
int secoff; /* sector offset of open file */
char *dirname; /* directory name, used to append filenames */
* Stuff for real disks, so that we can analyze the format
int lastsec; /* last sector read for real disks */
int prevsec; /* sector before last for real disks */
struct timeval lasttime;/* time that lastsec[] was read */
struct trackformat track[40]; /* format information derived from observations */
 * Prototypes
static void err(const char *s);
static void raw(int fd);
static void ack(unsigned char c);
static void senddata(int disk,int sec);
static void sendrawdata(unsigned char *buf,int size);
static void recvdata(int disk,int sec);
static void recprintdat(unsigned char numch);
static int get_atari(void);
void getcmd(unsigned char *buf);
static void loaddisk(char *path,int disk);
int firstgood(int disk,int sec);
void addtiming(int disk,int sec);
static void decode(unsigned char *buf);
void write_atr_head(int disk);
void snoopread(int disk,int sec);
int afnamecpy(char *an,const char *n);
 * Macros
#define SEEK(n,i) (disks[disk].seekcode==xfd)?SEEK0(n,i):((disks[i].seekcode=atr)?SEEK1(n,i):SEEK2(n,i))
#define SEEK0(n,i) ((n-1)*disks[i].secsize)
#define SEEK1(n,i) (ATRHEAD + ((n<4)?((n-1)*128):(3*128+(n-4)*disks[i].secsize)))
#define SEEK2(n,i) (ATRHEAD + ((n-1)*disks[i].secsize))
#define ATRHEAD 16
#define MAXDISKS 8
#define TRACK18(n) (((n)-1)/18) /* track of sector 'n' if 18 sectors per track (0-39) */
#define OFF18(n) (((n)-1)%18) /* offset of sector 'n' in track (0-17) */
#define TRACKSTART(n) ((((n)-1)/18)*18+1)
#define RPM(_uspr) (60*1000*1000/_uspr) /* microseconds for one revolution -> RPMs */
#define RPM3(_uspr) ((int)((60*1000ull*1000ull*1000ull/_uspr)%1000ull)) /* Fractional RPMS to 3 decimal points */
 * Default Timings from SIO2PC:
 * Time before first ACK:    85us
 * Time before second ACK:  1020us
 * Time before COMPLETE:   255us
 * Time after COMPLETE:   425us
#define ACK1 2000 /* Atari may wait 650-950us to raise the command line; device permitted 0-16ms */
#define ACK2 1020 /* 850ms min */
#define COMPLETE1 500 /* 250 is the min, but add more for transmission delays */
#define COMPLETE2 425
 * Global variables
struct image disks[MAXDISKS];
int atari; /* fd of the serial port hooked up to the SIO2PC cable */
/* Config options */
int snoop; /* If true, display detailed data on unmapped drives */
int quiet; /* If true, don't display per-I/O data */
int noring; /* If true, the serial port ring detect doesn't work */
char *serial;
int uspr=208333; /* microseconds per revolution, default for 288 RPM */
int speed=19200; /* Baud rate */
int fprn; /* For printer output */
char *fnamep;
int printemu=0;
 * main()
 * Read the command line, open the disk images, connect to the Atari,
 * and listen for commands.
 * This never terminates.
int main(int argc,char *argv[])
int i;
int numdisks=0;
* Parse command-line options
#define USAGE \
        "Options:\n" \
"  -r     next parameter is read-only image\n"\
"  -f     next parameter is image, fake accepting writes (no change to image)\n"\
"  -s     next parameter is serial device to use (default: /dev/ttyS0)\n"\
"  -b     next parameter is blank single-density image to create\n" \
"  -B     next parameter is blank double-density image to create\n" \
"  -p     next parameter is an printer raw output file (printer emulation)\n" \
"  -x     skip next drive image\n" \
"  -n     no ring detect on serial port (some USB converters)\n" \
"  <file> disk image to mount as next disk (D1 through D8 in order)\n" \
        "  <dir>  directory to mount as next disk\n"
if (argc==1) {
fprintf(stderr,"SIO2Linux:  The Atari floppy drive emulator\n");
fprintf(stderr,USAGE);
fprintf(stderr,"Example:\n  %s boot.atr -x -b d3.atr\n(D1: is boot.atr, D2: is ignored, D3: is a new blank image)\n",argv[0]);
exit(1);
setvbuf(stdout,NULL,_IONBF,0);
setvbuf(stderr,NULL,_IONBF,0);
memset(disks,0,sizeof(disks));
for(i=0;i<MAXDISKS;++i) {
disks[i].diskfd= -1;
serial="/dev/ttyS0";
for(i=1;i<argc;i++) {
if (*(argv[i]) == '-') {
switch( (argv[i])[1] ) {
    case 'q':
++quiet;
break;
    case 'x':
++numdisks;
break;
                case 'n':
                noring=1;
                break;
    case 'B': /* double-density blank disk */
disks[numdisks].secsize=128;
/* fall through */
    case 'b': /* single-density blank disk */
disks[numdisks].secsize+=128;
disks[numdisks].seccount=3; /* Will grow */
disks[numdisks].blank=1;
if ( i+1==argc ) {
fprintf(stderr, "Must have a parameter for '-b'\n" );
exit(1);
break;
    case 'r':
disks[numdisks].ro=1;
if ( i+1==argc ) {
fprintf(stderr, "Must have a parameter for '-f'\n" );
exit(1);
break;
    case 'f': /* Fake writes (no change to disk) */
disks[numdisks].fakewrite=1;
if ( i+1==argc ) {
exit(1);
break;
    case 'p':
    ++i;
if ( i==argc ) {
fprintf(stderr, "Must have a parameter for '-p'\n" );
exit(1);
printemu=1;
fnamep = argv[i];
break;
    case 's':
++i;
if ( i==argc ) {
fprintf(stderr, "Must have a parameter for '-s'\n" );
exit(1);
serial=argv[i];
break;
    default:
err( "Bad command line argument." );
else {
loaddisk(argv[i],numdisks);
numdisks++;
atari=get_atari();
/*open file for printer dump*/
/* fprn=open(fnamep, O_WRONLY | O_CREAT | O_TRUNC, 0666);*/
fprn=open(fnamep, O_WRONLY | O_APPEND | O_CREAT | O_TRUNC, 0666);
if (fprn<0) {
fprintf(stderr,"Can't open %s\n",fnamep);
exit(1);
* Main control loop
* Read a command and deal with it
* The command frame is 5 bytes.
while( 1 ) {
unsigned char buf[5];
getcmd(buf);
decode(buf);
fprintf(stderr,"%d:", errno );
fprintf(stderr,"%s\n", s );
exit(1);
struct termios it;
if (tcgetattr(fd,&it)<0) {
perror("tcgetattr failed");
err( "get attr" );
it.c_lflag &= 0; /* ~(ICANON|ISIG|ECHO); */
it.c_iflag &= 0; /* ~(INPCK|ISTRIP|IXON); */
/* it.c_iflag |= IGNPAR; */
it.c_oflag &=0; /* ~(OPOST); */
it.c_cc[VMIN] = 1;
it.c_cc[VTIME] = 0;
if (cfsetospeed( &it, B19200 )<0) err( "set o speed" );
if (cfsetispeed( &it, B19200 )<0) err( "set i speed" );
if (tcsetattr(fd,TCSANOW,&it)<0) err( "set attr" );
if ( !quiet) printf("[");
if (write( atari, &c, 1 )<=0) err( "ack failed\n" );
if ( !quiet) printf("%c]",c);
 * senddirdata()
 * The directory is simulated by having the starting sector number of each
 * file be 4+afileno*5.
 * The file is then mapped to 5 sectors, such that the first sector is always
 * the start of the file, and the 5th sector links to the 2nd sector, with the
 * actual file offset being determined based on the assumption of a sequential
 * read.
void senddirdata(int disk,int sec)
int size;
unsigned char buf[256];
int total;
int free;
int i;
int byte;
int bit;
struct dirent *de;
int r;
char path[MAXPATHLEN];
memset(buf,0,sizeof(buf));
size=disks[disk].secsize;
total=disks[disk].seccount-3-1-8-1;
if ( sec <= 3 ) {
sendrawdata(buf,size);
return;
if ( sec==360 ) { /* Create sector map */
buf[2]=total/256;
buf[1]=total%256;
free = total - 5*64;
buf[4]=free/256;
buf[3]=free%256;
buf[0]=2; /* ??? */
for(i=0;i<720;++i) {
byte=10+i/8;
bit=i%8;
bit=7-bit;
bit=1<<bit;
if(i>=4+64*5 && i!=720 && (i<360 || i>368)) {
buf[byte]|=bit;
return;
if ( sec>=361 && sec<=368 ) { /* Create directory */
rewinddir(disks[disk].dir);
readdir(disks[disk].dir);
for(i=0;i<8*(sec-361);++i) {
if (!readdir(disks[disk].dir)) {
return;
for(i=0;i<8;++i) {
int start;
int count;
int fn;
struct stat sb;
struct atari_dirent ad;
de=readdir(disks[disk].dir);
fn=(sec-361)*8+i;
start=4+fn*5;
if ( de ) {
memset(&ad,0,sizeof(ad));
strcpy(path,disks[disk].dirname);
strcat(path,"/");
strcat(path,de->d_name);
r=stat(path,&sb);
count=(sb.st_size+125)/125;
ad.countlo=count%256;
ad.counthi=count/256;
ad.startlo=start%256;
ad.starthi=start/256;
ad.flag=0x80; /* If unable to convert name, deleted file */
if ( !r && afnamecpy(ad.namelo,de->d_name) ) {
ad.flag=0x42;
memcpy(buf+16*i,&ad,sizeof(ad));
else break;
return;
if ( sec>=4 && sec<4+64*5 ) { /* send file data */
int fn;
int off;
off_t seekto;
fn=(sec-4)/5;
off=sec-4-fn*5;
if ( off ) {
/* This file had better be open already */
if ( fn != disks[disk].afileno ) {
if ( !quiet ) printf("-no data-");
memset(buf,0,size);
return;
seekto=(disks[disk].secoff+off)*125;
else {
if ( disks[disk].afileno ) close(disks[disk].afileno);
disks[disk].secoff=0;
disks[disk].afileno=fn;
for(i=0;i<=fn;++i) de=readdir(disks[disk].dir);
strcat(path,"/");
disks[disk].filefd=open(path,O_RDONLY);
seekto=0;
r=lseek(disks[disk].filefd,seekto,SEEK_SET);
if ( r<0 ) {
if ( !quiet ) printf("-lseek errno %d-",errno);
memset(buf,0,size);
return;
r=read(disks[disk].filefd,buf,125);
buf[125]=fn<<2;
buf[126]=sec+1;
if ( off==4 ) {
buf[126] -= 4;
disks[disk].secoff+=4;
buf[127]=r;
if ( r<125 ) {
buf[126]=0;
return;
memset(buf,0,size);
return;
int size;
off_t check,to;
int i;
if ( disks[disk].dir ) {
senddirdata(disk,sec);
return;
if (sec<=3) size=128;
if ( sec > disks[disk].seccount ) {
memset(buf,0,size);
else {
to=SEEK(sec,disk);
check=lseek(disks[disk].diskfd,to,SEEK_SET);
if (check!=to) {
if (errno) perror("lseek");
fprintf(stderr,"lseek failed, went to %ld instead of %ld\n",check,to);
exit(1);
/* printf("-%d-",check); */
i=read(disks[disk].diskfd,buf,size);
if (i!=size) {
if (i<0) perror("read");
fprintf(stderr,"Incomplete read\n");
exit(1);
int i, sum = 0;
int c=0;
        struct timeval t1,t2;
        int usecs,expected;
         * Compute checksum
for( i=0; i<size; i++ ) {
sum+=buf[i];
sum = (sum&0xff) + (sum>>8);
        gettimeofday(&t1,NULL);
         * Send buffer; let the port queue as much as it can handle
for( i=0; i<size; ) {
c=write(atari,&buf[i],size-i);
if (c<0) {
if (errno) perror("write");
fprintf(stderr,"write failed after %d bytes\n",i);
exit(1);
                i+=c;
        gettimeofday(&t2,NULL);
        usecs=(t2.tv_sec-t1.tv_sec)*1000*1000;
        usecs += t2.tv_usec;
        usecs -= t1.tv_usec;
        expected=(1000 * 1000 * 10 * size ) / speed; // 8 bits per byte, plus start/stop bits
        if ( usecs < expected )
                usleep(expected - usecs); // Don't write faster than the port can send
c=write( atari, &sum, 1 );
if (c!=1) {
fprintf(stderr,"write failed\n");
exit(1);
if ( !quiet ) printf("-%d bytes+sum-",size);
int i, sum = 0;
unsigned char mybuf[ 40 ];
int size = (int)numch;
read( atari, &mybuf[i], 1 );
sum = sum + mybuf[i];
sum = (sum & 0xff) + (sum >> 8);
read(atari,&i,1);
if ((i & 0xff) != (sum & 0xff) && !quiet) printf( "[BAD SUM]" );
else {
if ( !quiet) printf("-Sending print raw data to file-");
  //lseek(disks[disk].diskfd,SEEK(sec,disk),SEEK_SET);
i=write(fprn,mybuf,size);
if (i!=size) if ( !quiet) printf("[write failed: %d]",i);
// printf("%s\n", mybuf);
if ( !quiet) printf("-%d bytes+sum recvd-",size);
int i, sum = 0;
unsigned char mybuf[ 2048 ];
int size;
read(atari,&i,1);
else if (disks[disk].fakewrite) {
if ( !quiet) printf("[write discarded]");
else {
i=write(disks[disk].diskfd,mybuf,size);
if ( disks[disk].blank && sec>disks[disk].seccount ) {
disks[disk].seccount=sec;
write_atr_head(disk);
int i, sum = 0;
int size;
int r;
if (sec<=3 || size<128 ) size=128;
r=read(atari,&i,1);
if ( r!=1 ) {
fprintf(stderr,"snoop read failed\n");
return;
if ( !quiet ) printf("[%c]",i);
if ( i!='A' ) {
return;
r=read(atari,&i,1);
if ( r!=1 ) {
return;
if ( i!='C' ) {
return;
read(atari,&i,1);
if ((i & 0xff) != (sum & 0xff)) {
if (!quiet) printf( "[BAD SUM]" );
return;
struct atr_head buf;
int paragraphs;
lseek(disks[disk].diskfd,0,SEEK_SET);
memset(&buf,0,sizeof(buf));
buf.h0=0x96;
buf.h1=0x02;
paragraphs=disks[disk].seccount*(disks[disk].secsize/16) - (disks[disk].secsize-128)/16;
buf.seccountlo=(paragraphs&0xff);
buf.seccounthi=((paragraphs>>8)&0xff);
buf.hiseccountlo=((paragraphs>>16)&0xff);
buf.hiseccounthi=((paragraphs>>24)&0xff);
buf.secsizelo=(disks[disk].secsize&0xff);
buf.secsizehi=((disks[disk].secsize>>8)&0xff);
write(disks[disk].diskfd,&buf,16);
 * get_atari()
 * Open the serial device and return the file descriptor.
 * It assumes that it is /dev/ttyS0 unless there's a symlink
 * from /dev/mouse to that, in which case /dev/ttyS1 is used.
int fd;
struct stat stat_mouse,stat_tty;
if (stat("/dev/mouse",&stat_mouse)==0) {
stat(serial,&stat_tty);
if (stat_mouse.st_rdev==stat_tty.st_rdev) {
printf("/dev/ttyS0 is the mouse, using ttyS1\n");
serial="/dev/ttyS1";
fd = open(serial,O_RDWR);
if (fd<0) {
fprintf(stderr,"Can't open %s\n",serial);
exit(1);
raw(fd); /* Set up port parameters */
return(fd);
 * getcmd()
 * Read one 5-byte command
 * The Atari will activate the command line while sending
 * the 5-byte command.
int i,r;
* Clear RTS (override hw flow control)
* [Necessary to get some of the cables to work.]
i = TIOCM_RTS;
if ( ioctl(atari, TIOCMBIC, &i) < 0 )
                perror("ioctl(TIOCMBIC) failed");
         * Wait for a command
        if ( !noring && ioctl(atari,TIOCMIWAIT,TIOCM_RNG) < 0 ) /* Wait for a command */
                perror("ioctl(TIOCMIWIAT,TIOCM_RNG) failed");
        if ( tcflush(atari,TCIFLUSH) < 0 ) /* Clear out pre-command garbage */
                perror("tcflush(TCIFLUSH) failed");
         * Read 5 bytes
         * This should take 2.6ms.  *** FIXME *** set an alarm
         * Use setitimer(ITIMER_REAL,(struct itimerval),NULL)
        i=0;
        while (1) {
                for ( ; i<5; ++i )
                        r=read(atari,buf+i,1);
                        if ( r <=0 )
                                perror("read from serial port failed");
                                fprintf(stderr,"read returned %d\n",r);
                                exit(1);
* Compute the checksum
int sum=0;
for(i=0;i<4;++i) {
sum+=buf[i];
if (buf[4]==sum) {
return; /* Match; normal return */
* Error -- bad checksum
                if ( !quiet ) printf("%02x garbage\n",buf[0]);
                buf[0]=buf[1];
                buf[1]=buf[2];
                buf[2]=buf[3];
                buf[3]=buf[4];
                i=4; // Read one more byte and recompute checksum
 * loaddisk()
 * Ready a disk image.
 * The type of file (xfd/atr) is determined by the file size.
int exists=0;
if (disk>=MAXDISKS) {
fprintf(stderr,"Attempt to load invalid disk number %d\n",disk+1);
exit(1);
if ( disks[disk].blank ) {
disks[disk].diskfd=open(path,O_RDWR,0644);
if ( disks[disk].diskfd>=0 ) {
exists=1;
else {
disks[disk].diskfd=open(path,O_RDWR|O_CREAT,0644);
disks[disk].seekcode=atr;
else {
disks[disk].diskfd=open(path,(disks[disk].ro||disks[disk].fakewrite)?O_RDONLY:O_RDWR);
if (disks[disk].diskfd<0 && !disks[disk].ro && !disks[disk].fakewrite) {
if ( errno == EACCES ) {
disks[disk].ro=1;
disks[disk].diskfd=open(path,O_RDONLY);
else if ( errno == EISDIR ) {
disks[disk].filefd = -1;
disks[disk].afileno = -1;
disks[disk].dir=opendir(path);
if ( !disks[disk].dir ) {
fprintf(stderr,"Unable to open directory %s; drive %d disabled\n",path,disk);
return;
disks[disk].active=1;
disks[disk].secsize=128;
disks[disk].seccount=720;
disks[disk].seekcode=direct;
disks[disk].dirname=path;
printf( "D%d: %s simulated disk (%d %d-byte sectors)\n",disk+1,path,disks[disk].seccount,disks[disk].secsize);
return;
if (disks[disk].diskfd<0) {
fprintf(stderr,"Unable to open disk image %s; drive %d disabled\n",path,disk);
return;
if ( !disks[disk].blank || exists ) {
* Determine the file type based on the size
struct stat buf;
fstat(disks[disk].diskfd,&buf);
disks[disk].seekcode=atrdd3;
if (((buf.st_size-ATRHEAD)%256)==128) disks[disk].seekcode=atr;
if (((buf.st_size)%128)==0) disks[disk].seekcode=xfd;
disks[disk].seccount=buf.st_size/disks[disk].secsize;
* Read disk geometry
if (disks[disk].seekcode!=xfd) {
struct atr_head atr;
long paragraphs;
read(disks[disk].diskfd,&atr,sizeof(atr));
disks[disk].secsize=atr.secsizelo+256*atr.secsizehi;
paragraphs=atr.seccountlo+atr.seccounthi*256+
atr.hiseccountlo*256*256+atr.hiseccounthi*256*256*256;
if (disks[disk].secsize==128) {
disks[disk].seccount=paragraphs/8;
else {
paragraphs+=(3*128/16);
disks[disk].seccount=paragraphs/16;
else {
printf( "D%d: %s opened%s (%d %d-byte sectors)\n",disk+1,path,disks[disk].ro?" read-only":"",disks[disk].seccount,disks[disk].secsize);
 * firstgood()
 * Return the first non-bad sector in the same track.
int i;
for(i=TRACKSTART(sec);i<sec;++i) {
if ( !disks[disk].track[TRACK18(i)].bad[OFF18(i)] ) return(i);
return(sec);
 * addtiming()
 * We've just seen a read issued to a non-managed disk, so compute the location
 * of the last sector relative to the one previous to it from the time elapsed
 * between the reads, assuming that the Atari is reading as fast as it can.
 * This is only useful for copy-protected disks, so we can assume 18-sectors per
 * track.
struct timeval newtime;
int diff;
int revs;
int secs;
int secpct; /* percentage to next sector */
int usps;
int fgs;
if ( sec > 720 ) return;
gettimeofday(&newtime,NULL);
if ( !disks[disk].prevsec || TRACK18(disks[disk].prevsec)!=TRACK18(disks[disk].lastsec) ) {
goto done;
diff=newtime.tv_sec-disks[disk].lasttime.tv_sec;
if ( diff > 1 ) goto done; /* more than a second */
diff *= 1000000;
diff += newtime.tv_usec;
diff -= disks[disk].lasttime.tv_usec;
if ( disks[disk].prevsec==disks[disk].lastsec ) {
uspr = diff; /* Observed microsceonds for one revolution */
if ( !quiet ) printf(" %d.%03d RPMs ",RPM(uspr),RPM3(uspr));
goto done;
usps = uspr/18;
revs=diff/uspr;
secs=(diff-revs*uspr)/usps;
secpct = (diff - revs*uspr - secs*usps) * 100 / usps;
if ( revs>1 ) {
if ( !quiet ) printf(" %d revolutions (%d us) [delayed read]",revs,diff);
goto done;
fgs = firstgood(disk,disks[disk].lastsec);
if ( disks[disk].lastsec != fgs ) {
/* Not the first good sector on the track */
if ( disks[disk].prevsec==fgs ||
     disks[disk].track[TRACK18(disks[disk].prevsec)].offset[OFF18(disks[disk].prevsec)]) {
/* We can measure directly or indirectly from the first good sector */
disks[disk].track[TRACK18(disks[disk].lastsec)].offset[OFF18(disks[disk].lastsec)] =
( disks[disk].track[TRACK18(disks[disk].prevsec)].offset[OFF18(disks[disk].prevsec)] + secs*100 + secpct ) % 1800;
if ( !quiet ) printf(" sec %d is %d.%02d sectors after sec %d [RECORDED]",
     disks[disk].lastsec,
     disks[disk].track[TRACK18(disks[disk].lastsec)].offset[OFF18(disks[disk].lastsec)]/100,
     disks[disk].track[TRACK18(disks[disk].lastsec)].offset[OFF18(disks[disk].lastsec)]%100,
     fgs
goto done;
if ( !quiet ) {
printf(" sec %d is %d.%02d sectors after sec %d", disks[disk].lastsec, secs, secpct, disks[disk].prevsec );
printf(" fgs:%d",fgs);
 done:
disks[disk].prevsec = disks[disk].lastsec;
disks[disk].lastsec = sec;
disks[disk].lasttime = newtime;
 * decode()
 * Given a command frame (5-bytes), decode it and
 * do whatever needs to be done.
int disk = -1, rs = -1, printer = -1;
int sec;
if ( !quiet) printf( "%02x %02x %02x %02x %02x ",buf[0],buf[1],buf[2],buf[3],buf[4]);
switch( buf[0] ) {
    case 0x31: if ( !quiet) printf( "D1: " ); disk = 0; break;
    case 0x32: if ( !quiet) printf( "D2: " ); disk = 1; break;
    case 0x33: if ( !quiet) printf( "D3: " ); disk = 2; break;
    case 0x34: if ( !quiet) printf( "D4: " ); disk = 3; break;
    case 0x35: if ( !quiet) printf( "D5: " ); disk = 4; break;
    case 0x36: if ( !quiet) printf( "D6: " ); disk = 5; break;
    case 0x37: if ( !quiet) printf( "D7: " ); disk = 6; break;
    case 0x38: if ( !quiet) printf( "D8: " ); disk = 7; break;
    case 0x40: if ( !quiet) printf( "P: " ); printer = 0; break;
    case 0x41: if ( !quiet) printf( "P1: " ); printer = 0; break;
    case 0x42: if ( !quiet) printf( "P2: " ); printer = 1; break;
    case 0x43: if ( !quiet) printf( "P3: " ); printer = 2; break;
    case 0x44: if ( !quiet) printf( "P4: " ); printer = 3; break;
    case 0x45: if ( !quiet) printf( "P5: " ); printer = 4; break;
    case 0x46: if ( !quiet) printf( "P6: " ); printer = 5; break;
    case 0x47: if ( !quiet) printf( "P7: " ); printer = 6; break;
    case 0x48: if ( !quiet) printf( "P8: " ); printer = 7; break;
    case 0x50: if ( !quiet) printf( "R1: " ); rs = 0; break;
    case 0x51: if ( !quiet) printf( "R2: " ); rs = 1; break;
    case 0x52: if ( !quiet) printf( "R3: " ); rs = 2; break;
    case 0x53: if ( !quiet) printf( "R4: " ); rs = 3; break;
    default: if ( !quiet) printf( "???: ignored\n");return;
if (disk>=0&&!disks[disk].active) { if ( !quiet) printf( "[no image] " ); }
if (printer>=0 && printemu==1) {
unsigned char numchars;
switch( buf[1] ) {
case 'S':
if ( !quiet) printf( "status printer:" );
//if ( !disks[disk].active ) break;
usleep(ACK1);
ack('A');
static unsigned char status[] = { 0x00, 0x00, 0x03, 0x00 };
status[1] = buf[3];
usleep(COMPLETE1);
ack('C');
usleep(COMPLETE2);
sendrawdata(status,sizeof(status));
break;
case 'W':
if ( !quiet) printf( "write printer:" );
    usleep(ACK1);
    if ( buf[2] == 0x4e )  numchars=40;
    if ( buf[2] == 0x53 )  numchars=29;
    if ( buf[2] == 0x44 )  numchars=21;
    if ( !quiet) printf("[Receiving %d characters]", numchars);
// if (disks[disk].ro) {
// ack('N');
// if ( !quiet) printf("[Read-only image]");
// break;
ack('A');
recprintdat(numchars);
usleep(ACK2);
ack('A');
usleep(COMPLETE1);
ack('C');
break;
default:
if ( !quiet) printf( "??? " );
break;
if ( !quiet) printf( "\n" );
return;
if (rs>=0) {if ( !quiet) printf("[Serial ports not supported]\n"); return; }
sec = buf[2] + 256*buf[3];
switch( buf[1] ) {
    case 'B':
if ( !disks[disk].active ) {
disks[disk].track[TRACK18(sec)].bad[OFF18(sec)]=1;
if ( !quiet ) printf("announce bad sector %d: ",sec);
    case 'R':
if ( !quiet) printf("read sector %d: ",sec);
addtiming(disk,sec);
if ( snoop ) snoopread(disk,sec);
break;
usleep(ACK1);
ack('A');
usleep(COMPLETE1);
ack('C');
usleep(COMPLETE2);
senddata(disk,sec);
break;
    case 'W':
if ( !quiet) printf("write sector %d: ",sec);
usleep(ACK1);
ack('N');
break;
ack('A');
recvdata(disk,sec);
usleep(ACK2);
ack('A');
usleep(COMPLETE1);
ack('C');
break;
    case 'P':
if ( !quiet) printf("put sector %d: ",sec);
usleep(ACK1);
ack('N');
break;
ack('A');
recvdata(disk, sec);
usleep(ACK2);
ack('A');
usleep(COMPLETE1);
ack('C');
break;
    case 'S':
if ( !quiet) printf( "status:" );
usleep(ACK1);
ack('A');
* Bob Woolley wrote on comp.sys.atari.8bit:
* at your end of the process, the bytes are
* CMD status, H/W status, Timeout and unused.
* CMD is the $2EA value previously
* memtioned. Bit 7 indicates an ED disk.  Bits
* 6 and 5 ($6x) indicate DD. Bit 3 indicates
* write protected. Bits 0-2 indicate different
* error conditions.  H/W is the FDD controller
* chip status.  Timeout is the device timeout
* value for CIO to use if it wants.
* So, I expect you want to send a $60 as the
* first byte if you want the OS to think you
* are in DD. OK?
static unsigned char status[] = { 0x10, 0x00, 1, 0 };
status[0]=(disks[disk].secsize==128?0x10:0x60);
if (disks[disk].secsize==128 && disks[disk].seccount>720) status[0]=0x80;
status[0] |= 8;
else {
status[0] &= ~8;
usleep(COMPLETE1);
ack('C');
usleep(COMPLETE2);
break;
    case 'N':
if ( !quiet) printf("815 configuration block read");
/* We get 19 of these from DOS 2.0 when you hit reset */
usleep(ACK1);
ack('A');
usleep(COMPLETE1);
ack('C');
unsigned char status[12];
memset(status,0,sizeof(status));
status[0]=1; /* 1 big track */
status[1]=1; /* Why not? */
status[2]=disks[disk].seccount>>8;
status[3]=disks[disk].seccount&0xff;
status[5]=((disks[disk].secsize==256)?4:0);
status[6]=disks[disk].secsize>>8;
status[7]=disks[disk].secsize&0xff;
break;
    case 'O':
if ( !quiet) printf("815 configuration block write (ignored)");
usleep(ACK1);
ack('A');
int i;
char s;
int sum=0;
for( i=0; i<12; i++ ) {
read( atari, &s, 1 );
if ( !quiet) printf(" %02x",s);
sum = sum + s;
read(atari,&s,1);
if ((s & 0xff) != (sum & 0xff)) if ( !quiet) printf( "[BAD SUM %02x]",sum );
if ( !quiet) printf(" ");
usleep(ACK2);
ack('A');
usleep(COMPLETE1);
ack('C');
break;
    case '"':
if ( !quiet) printf( "format enhanced " );
/*** FIXME *** Acknowledge and zero disk image ***/
usleep(ACK1);
ack('A');
usleep(COMPLETE1);
ack('C');
usleep(COMPLETE2);
senddata(disk,99999);
break;
    case '!':
if ( !quiet) printf( "format " );
usleep(ACK1);
ack('A');
usleep(ACK1);
ack('C');
break;
    case 0x20:
if ( !quiet) printf( "download " );
break;
    case 0x54:
if ( !quiet) printf( "readaddr " );
break;
    case 0x51:
if ( !quiet) printf( "readspin " );
break;
    case 0x55:
if ( !quiet) printf( "motoron " );
break;
    case 0x56:
if ( !quiet) printf( "verify " );
break;
    default:
break;
 * wait_for_cmd()
 * Wait for the ring indicator to specify that a command block is being sent
void wait_for_cmd(int fd)
  int r;
  r=ioctl(fd,TIOCMIWAIT,TIOCM_RNG);
/* afnamecpy() */
/* Convert a Unix filename to an Atari filename. */
/* Return 0 on failure. */
int i;
for(i=0;i<11;++i) an[i]=' '; /* Space fill the Atari name */
an[11]=0;
for(i=0;i<8;++i) {
if (!*n) return(1); /* Ok */
if (*n=='.') break; /* Extension */
if (*n==':') return(0); /* Illegal name */
if (1) an[i]=toupper(*n);
else an[i]= *n;
++n;
if (*n=='.') ++n;
for(i=8;i<11;++i) {
if (*n=='.') return(0); /* Illegal name */
else an[i]= *n;
++n;
if (*n) return(0); /* Extension too long or more than 11 characters */
return(1);
#17 manterola OFFLINE
manterola
    Moonsweeper
  • 342 posts
Posted Sat Dec 15, 2018 9:22 AM
Sorry for previous post. I could not delete it,
So here how I compiled the code:
use like this, (depending on you conf you might need to sudo.
or
wine DOSPrinter.exe /S /PAGEA4 /PDF newr.prn
ps: somebody knows if Preston Crow comes to this forum?
Edited by manterola, Sat Dec 15, 2018 9:23 AM.
#18 manterola OFFLINE
manterola
    Moonsweeper
  • 342 posts
Posted Tue Dec 25, 2018 11:20 AM
Update... I have compiled PrinterToPdf recommended by Mr Robot. It worked! It is very slow and produced heavier PDFs but the output is more accurate, at least I can produce nice printouts using The Print Shop.
I hope to put some hours to modify it to take the filename as argument, and see if I can strip some parts and make it easier to interact with sio2linux (I just compiled the code I donwloaded from GitHub). But I can confirm it works
Edited by manterola, Tue Dec 25, 2018 11:21 AM.
#19 leech OFFLINE
leech
  • 1,414 posts
Posted Fri Mar 15, 2019 7:01 PM
I've been looking around for a way to use Printshop again, but would rather not have to buy another printer and the Retroprinter interface had some issues so they're working on those and then they'll start selling them again, but if the code is open source, and someone could add it to RespecQT so that we could use the SIO2PC (which I already have) than that would be fantastic!  Would love to be able to print from Printshop to my networked Laserjet.
