AtariX - Simple IDE
IuriNery
AtariX
Hello everyone, my name is Iuri Nery, and a few days ago I started reading some tutorials at RandomTerrain to learn more about Atari programming, and so far I’m finding everything fascinating. I’m right now at number #16 of Andrew Davie’s tutorial (Atari 2600 Programming for Newbies). I’m learning a lot from it, and to learn faster, I needed to built something to help me testing the sample projects, that’s why I made this IDE.
AtariX is a very simple IDE, but has a couple of features that can help novice users to get into Assembly programming:
· Save/Load assembly files (.asm/.s);
· Build binary files by pressing the “Export” button;
· Test your games with 1 click;
· Colored syntax for comments, assembly instructions, numbers, binary numbers and also for the labels from “vcs.h” (like COLUPF);
Files included:
· “vcs.h” and “macro.h” (unmodified);
· DASM Assembler;
· z26 Emulator;
· AtariX executable;
How to use:
1. Open the assembly file you want to test;
2. Put all the included files in the “include” folder;
3. Click on the “Play” button (you can also press F5);
Credits:
; AtariX
; Copyright © 2017 by Iuri Nery
; DASM Assembler
; Copyright © 1988-2002 by Matthew Dillon
; Copyright © 1995 by Olaf "Rhialto" Seibert
; Copyright © 2003-2008 by Andrew Davie
; Copyright © 2008 by Peter H. Froehlich
; z26 Emulator
; Copyright © 1997-2004 by John Saeger
This is not an advanced IDE or anything like that, just wanted to share it with you guys, I hope it can help someone.
ps: I’m not an experienced programmer, so any tips are apreciated, also I don’t know if this is the correct session to post this kind of stuff.
Thanks!
AtariX_v01.zip
  • Like 5
Looks good!
How are you displaying your binary numbers? I'm using jEdit and have it configured so binary numbers display in such a way that the graphic data is very obvious (see below).
I've written a tutorial that takes you through writing a 2K game. You may find it useful as well.
Looks good!
Thanks!
I haven't heard about jEdit before, seems like a very good program with lots of features, I will definitely check it out!
The binary numbers on AtariX are displayed in a very simple way:
I haven't though too much deep about it (because I'm still learning and I don't know what ".byte" means haha). But the idea of highlighting the 1's is something I will definitely add, as you said, it helps a lot visualizing the data.
I also fav your tutorials, I will read it after I finish Andrew's tutorials.
Thanks for the suggestion =)
