7800fan Posted June 1, 2017 Share Posted June 1, 2017 One has both 75 and 300 ohms input from antenna, and other has only 75 ohms input. The front plate was designed a bit different to remove the opening for the absent screws terminals, and different colored label. As far as I can tell, internally a 75-300 ohms baulin and 2 screws posts are the only thing missing. Any reason for 2 different designs? Maybe to save 10 cents per switch box when Atari removed the 300 ohms input? Quote Link to comment Share on other sites More sharing options...
MIKE5200 Posted June 2, 2017 Share Posted June 2, 2017 One has both 75 and 300 ohms input from antenna, and other has only 75 ohms input. The front plate was designed a bit different to remove the opening for the absent screws terminals, and different colored label. As far as I can tell, internally a 75-300 ohms baulin and 2 screws posts are the only thing missing. Any reason for 2 different designs? Maybe to save 10 cents per switch box when Atari removed the 300 ohms input? Probably cheaper...I also have both Quote Link to comment Share on other sites More sharing options...
