Atari 410 Program Recorder Guide
410 program recorder tape tape drive 1010 xc cassette repair
6 replies to this topic
#1 Blake OFFLINE
Blake
    Space Invader
  • 22 posts
Posted Sat Jun 10, 2017 9:58 AM
A long, LONG, time ago, on a computer, now dead, and another, and another, and 2 laptops, and finally on a USB drive, also now dead, I put together an instructional guide to taking apart a 410 drive, with emphasis on simplicity, and allowing for a couple improvements and repairs.
It has been months since then, but the effort to put the guide out never died, and now today, I can release the guide in a photographic step-by-step format, in numerical order, with sudo-progressive sections, featuring a new solution to drive mechanism stuttering, a comparison of an old, used model, and a new-in-box, old-stock model drive, an electronics repair and problem-analysis section with documentation, and a more condensed, re-assembly guide.  :D
I would like to do a complete analysis of the head alignment procedure, and electronics replacement\upgrade\repair with my new oscilloscope, as described in the official documentation, which is included in this guide, and I had intended on making a version of this guide as a video, so I will combine them, but free-time is short right now, so it will have to wait. :ponder:
IT SHOULD BE NOTED THAT NEW BELTS WORK BETTER THAN OLD ONES, SO IF YOU CAN AFFORD IT, YOU SHOULD GET THEM HERE:
http://atariage.com/...-1010-410-xc12/
You will also note that the older model drive in this guide is using a few elastics in place of belts, this is not a permanent solution, and should only be used in a pinch, or in a testing situation where the belts would be subject to considerable use, for the sake of your precious belts!
I hope it helps at least 1 person, then my effort is worth it.
You will need 7-Zip, or another archiving program to extract the files. There are no programs or viruses in these archives, only pictures, text, and pdf.
I take no responsibility for what you do, or fail to do, with this guide. USE AT YOUR OWN RISK! And enjoy! :waving:
http://www.4shared.c.../Final_Cut.html
http://www.4shared.c...e-assembly.html
http://www.mediafire...oe/Final_Cut.7z
http://www.mediafire.../re-assembly.7z
#2 Blake OFFLINE
Blake
    Space Invader
  • 22 posts
Posted Sat Jun 10, 2017 9:59 AM
Any questions just ask. :-D
#3 xdslx OFFLINE
xdslx
    Star Raider
  • 61 posts
Posted Sun Jun 11, 2017 12:15 AM
that really is a valuable piece of work. Thank you very much for your efforts. I needed this bad when I tried to repair my 410. Now I can try to repair it myself with confidence.  :thumbsup:
#4 Blake OFFLINE
Blake
    Space Invader
  • 22 posts
Posted Tue Jun 13, 2017 11:07 AM
It seems that in my haste, I forgot to add:
> Items that a circled are to be removed during that step, or that step and the following step.
> The connections that electronically engage the motor, were bent further apart in a few photos, so as to display every angle, and detail. They were bent back after.
> The resistor and capacitor replacement solution from Atari, and online archives, is designed to narrow the bandwidth of the signal coming from the cassette, to filter out noise, that became a lot louder, when Atari decided to do a last-minute upgrade to the internal signal amplifier, to one that was more powerful. I'll show you the difference between the two wave patterns on a oscilloscope when I make the video.
#5 Blake OFFLINE
Blake
    Space Invader
  • 22 posts
Posted Sun Jun 18, 2017 1:51 PM
I have found a few extra pieces from the dead USB drive mentioned above, which appear to be later revisions\additions to the guide's repair section! :)
Specifically the article I found online from Antic Magazine, which may, or may not have been the inspiration for Atari's last minute change of components. :ponder:
And a few photos that are helpful in repairing-upgrading-modifying the 410's electronics, and a replacement for the components comparison photo #264, with more information regarding Antic's part's list, for their version of the mod which is SLIGHTLY different than Atari's mod.
https://www.mediafir...vyil77tdj5w72ca  729.98KB
https://www.4shared....ing_Pieces.html  729.98KB
Edited by Blake, Sun Jun 18, 2017 2:34 PM.
#6 xdslx OFFLINE
xdslx
    Star Raider
  • 61 posts
Posted Tue Jun 20, 2017 10:25 AM
I will mod my 410 because some 30 years tapes struggle to load .  Antics mod or atari's mod , which one do you advice ?
Edited by xdslx, Tue Jun 20, 2017 10:27 AM.
#7 Blake OFFLINE
Blake
    Space Invader
  • 22 posts
Posted Tue Jun 20, 2017 12:54 PM
What is it loading like now? Does it load and save new stuff ok, but just not old stuff? Or does it not load or save(if you are able to check with a known-working unit) anything at all? The difference is important.
Since the Antic Magazine's solution involves different components from the Atari solution, and since they are both designed to "clean-up" the signal, you can confidently do both if you want, but the Atari mod is the most likely to provide a substantial increase in functionality, or in some cases, provide functionality at all, where as Antic's is more of a fine-tuning, for a unit that already works, but not every single time.
Also tagged with one or more of these keywords: 410, program recorder, tape, tape drive, 1010, xc, cassette, repair
