New keyboard membranes
keyboard membrane key
71 replies to this topic
#1 Duddie OFFLINE
Duddie
    Chopper Commander
  • 124 posts
  • Visit www.facebook.com/retronics.eu
Posted Mon Jun 12, 2017 12:19 AM
I am going to manufacture new keyboard membranes for 800XL and XE series (for keyboard with springs). Maybe also for 1200XL. Would be here any interest? Price $25 for XL and XE. 1200XL would be slightly more expensive.
#2 rdea6 OFFLINE
rdea6
  • 2,657 posts
Posted Mon Jun 12, 2017 12:58 AM
Yes I would be interested in one each.. 800XL/XE series.
#3 Nezgar OFFLINE
Nezgar
    Dragonstomper
  • 562 posts
Posted Mon Jun 12, 2017 2:22 AM
Is there any advantage to this than the $22 XE one listed at Best Electronics? I haven't actually ordered anything yet from Best myself before, maybe minimum orders/shipping are a factor there. I may be in the market for a few of these if my attempts to repair fail.
#4 Duddie OFFLINE
Duddie
    Chopper Commander
  • 124 posts
Posted Mon Jun 12, 2017 2:29 AM
Hello Nezgar, I don't know quality of their membranes. Best Electronics sells usually NOS things, therefore their membranes, although new, may be 30+ years old. Mine will be freshly manufactured.  I haven't decided that I make them for sure. If demand is too low, I cannot make it, because production preparation is very expensive.
#5 KlasO OFFLINE
KlasO
    Space Invader
  • 40 posts
Posted Mon Jun 12, 2017 4:12 AM
Hello,
I am interested in two - one for an 800XL and one for a 130XE. I must check what type my 130 keyboard is before deciding, so it might be only one.
Kind regards,
Klas
Edited by KlasO, Mon Jun 12, 2017 4:13 AM.
#6 tf_hh OFFLINE
tf_hh
    Dragonstomper
  • 564 posts
Posted Mon Jun 12, 2017 5:04 AM
Hi,
you wrote "800XL"... new membrane for the Stackpole keyboard with metal back plate?
BR JUrgen
#7 darwinmac OFFLINE
darwinmac
    Chopper Commander
  • 114 posts
Posted Mon Jun 12, 2017 5:31 AM
While Best does sell mostly NOS stock, he does create some new replacement parts. The Mylar is one of those parts. However, if they have them in stock, the $22 might not be a great deal when you take into account the shipping to Europe. However, for the one American person in the thread, I would contact Best first if you need a new keyboard membrane. His website is hard to search because it is so antiquated but the part number appears to be CB101049 (Best upgraded Atari New XE Keyboard replacement internal Mylar).
I haven't needed to purchase a replacement Mylar, but I've been very happy with his upgraded CX-40 joystick. I am not saying not to do this, but I would check with Brad first to see if he already has a modern replacement before you recreate the wheel.
Bob C
#8 timofonic OFFLINE
timofonic
    Star Raider
  • 92 posts
Posted Mon Jun 12, 2017 5:59 AM
What about putting Real Mechanical Key-switches? This could make the A8 compies to suck even less possible, despite something like that would seem impossible
#9 MEtalGuy66 OFFLINE
MEtalGuy66
  • 2,763 posts
  • If it aint broke, fix it anyway!
Posted Mon Jun 12, 2017 7:30 AM
1200XL: good idea!
There are at least three different  "spring design" 800XL keyboards. Some are MUCH BETTER than others.
The "spring design" xe keyboard sucks only marginally less than the "cup design"..  The XE just needs a new keyboard altogether, or its always gonna feel like cheap trash compared to the XLs..
Edited by MEtalGuy66, Mon Jun 12, 2017 7:32 AM.
#10 ACML OFFLINE
ACML
    Dragonstomper
  • 797 posts
Posted Mon Jun 12, 2017 8:10 AM
I have yet to find a 1200XL keyboard that couldn't be restored.  The problem with the 1200XL is that little 1/4" x 2" tape sandwiched between the Mylar and PCB traces.  I guess it's purpose was to raise the PCB contact pads to insure they made good contact on the Mylar.  It apparently oxidizes and it loses continuity.  In hindsight, if Mitsumi left that out of the design, a lot of these keyboard would still be Code 1 (USAF slang for no write ups) today.  The Retrobits fix is not for everyone, but if you have patience and take your time, it's not a difficult fix.  A replacement Mylar is a welcome option!
Not sure, but my guess is that Mitsumi used a graphite based conductive trace.
Edited by ACML, Mon Jun 12, 2017 8:12 AM.
#11 GlowingGhoul OFFLINE
GlowingGhoul
    Moonsweeper
  • 251 posts
Posted Mon Jun 12, 2017 8:58 AM
Do all 800XL keyboards use the same mylar?
I'd definitely be interested in as many as 20 depending on price. (ie, $10-$15)
#12 Bill Lange OFFLINE
Bill Lange
    Dragonstomper
  • 882 posts
Posted Mon Jun 12, 2017 10:10 AM
For reference ...
From BEST Website:
http://www.best-elec...om/130xe.htm#TT
"65XE / 130XE Mitsumi(56-3217, part number on Mylar) made XE Keyboard, single layer Mylar. This Best Electronics Manufactured replacement Keyboard Mylar is an Improved version over the stock Atari keyboard Mylar! Each Best replacement Mylar has a thin dielectric Protective coating over the complete Mylar except the conductive key contact pads. This conductive coating gives your replacement Best Mylar the Best Resistance to flexure cracks on Silk screened traces and prevents internal keyboard Mylar supports from wearing or rubbing away traces. Its also prevents tiny objects that drop thru the Keyboard from wearing or shorting out keyboard traces. This replacement Mylar also has 1/4 inch longer extended Traces on the connector side of the Mylar so they can be trimmed back if required. One way you can tell if you have a Mitsumi version XE keyboard is to pull off one key cap. It is best to pry off a key cap using two small straight blade screw drivers, one a 12 and 6 O’ clock positions. The Mitsumi XE keyboard will have a spring under each key cap." $22.00
http://www.best-elec...board Mylar.htm
"The New Best Upgraded Lifetime Atari 1200XL Keyboard Mylar  CB103156 $39.95"
#13 Kyle22 OFFLINE
Kyle22
  • 3,277 posts
  • Call my BBS! telnet://23.25.83.98
Posted Mon Jun 12, 2017 3:05 PM
The one that no one has in stock is the mylar for the Mitsumi keyboard in the original 800.  It would be great to have a source for them.
#14 KLund1 OFFLINE
KLund1
    Dragonstomper
  • 533 posts
Posted Mon Jun 12, 2017 3:15 PM
I have purchased and installed the 1200XL and 800XL Best Mylars and they work great. The 1200XL especially so!! I would recommend it. But the shipping costs maybe an issue for many. (not for me as Best 1/2 mile from my office)
But for the 65/800/130XE's, well, I agree with all above in that a mylar will help for a units that as been in barn for years. A new keyboard would be a major benefit, and what is really need for these.
#15 Stormbringer OFFLINE
Stormbringer
    Chopper Commander
  • 193 posts
Posted Tue Jun 13, 2017 7:05 AM
That would be a godsend!
#16 Duddie OFFLINE
Duddie
    Chopper Commander
  • 124 posts
Posted Wed Jun 14, 2017 1:34 AM
Hi,
BR JUrgen
Yes Jurgen. AFAIK, there are 5 different XL keyboards, four of them have membranes. But it is the same membrane.
#17 Mathy OFFLINE
Mathy
  • 2,518 posts
Posted Wed Jun 14, 2017 5:29 PM
Hello guys
And there are two different types of XE keyboard mylars.  Single layer and dual layer.  These are NOT interchangeable.
Sincerely
Mathy
#18 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 610 posts
Posted Wed Jun 14, 2017 6:47 PM
i would probably take one each of the 800xl and 130xe to have as spares.
#19 Duddie OFFLINE
Duddie
    Chopper Commander
  • 124 posts
Posted Thu Jun 15, 2017 1:44 AM
All of you can send your pre-orders to jurek (at) retronics (dot) eu - mylars will be available around August (limited number). For now, I will have 800XL mylar and spring version of XE mylar. Others to be considered, you can declare your interest too.
#20 orpheuswaking OFFLINE
orpheuswaking
  • 5,673 posts
  • Lone Raider Time!
Posted Thu Jun 15, 2017 6:53 AM
What are we looking at for cost?
#21 Kyle22 OFFLINE
Kyle22
  • 3,277 posts
Posted Thu Jun 15, 2017 2:08 PM
I would be very interested to know if Original 800 ones will be available.
Others with this same question should speak up NOW.
#22 _The Doctor__ OFFLINE
_The Doctor__
  • 3,958 posts
Posted Thu Jun 15, 2017 2:35 PM
I would be interested as well, the mylars used to cost 10.00 retail... then suddenly jumped sky high.... and of course cost much much less to manufacture at quantity
Edited by _The Doctor__, Thu Jun 15, 2017 2:45 PM.
#23 orpheuswaking OFFLINE
orpheuswaking
  • 5,673 posts
  • Lone Raider Time!
Posted Thu Jun 15, 2017 2:58 PM
Ignore me, I just realized it's in the first post DOH!
#24 Duddie OFFLINE
Duddie
    Chopper Commander
  • 124 posts
Posted Fri Jun 16, 2017 7:57 AM
$25 is only estimated cost. Can be less, if I collect more orders.
Mylar for 800 is possible, even keyboard for 400.
#25 orpheuswaking OFFLINE
orpheuswaking
  • 5,673 posts
  • Lone Raider Time!
Posted Fri Jun 16, 2017 12:36 PM
400 Keyboard? a full stroke board or a replacement membrane keyboard?
Also tagged with one or more of these keywords: keyboard, membrane, key
