bB, bankswitching and the Atari Flashback Portable
23 replies to this topic
#1 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Thu Jun 15, 2017 7:30 AM
Thus far, I have not been able to get any games made with bB that use bankswitching to work on the AFP.  Even the simplest "hello world" using the standard kernel that works when compiled to 4K fails when it is changed to 8K.  The bankswitching example on RT's site also doesn't work on the portable.
I do know that some people have had their bankswitched bB games work on the portable, however, so I am trying to figure out the relevant factor.  Does anyone have any example bB code that uses multiple banks that DOES work on the portable?  If I had a working example, then maybe I could figure out what is different.
Also, it has been suggested to me that perhaps it may be something that changed in more recent builds of bB.  I am using RevEng's latest build.  For those of you who have had success building for the portable, what version of bB were you using?
#2 Mr SQL OFFLINE
Mr SQL
  • 1,879 posts
Posted Thu Jun 15, 2017 9:37 AM
Attached File  PortableTest.bin   4KB   22 downloads
kdgarris,
I was able to compile your game with the older version - this one works on the portable :)
Noticed a couple of strange issues though:
/* block SQL comments in the code have to be removed, these must be new */
Then the compiler complained about a normal variable name near the end, then about the "-" sign...
didn't look like normal errors might be too much padding I just removed the -
so the line became more like "if myvar > thisvar then" instead of "if myvar > thisvar - 8 then"
I used not the original bB release but the version patched for pfcolors.
#3 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Thu Jun 15, 2017 11:16 AM
That's very strange - I did the same thing ... tried compiling with the old 1.0 version, having to make the same kinds of changes to get it to compile.  The newer bB seems to be more forgiving of complex expressions.  I just broke some of these up using temp variables.  It also seems that my stripped down "game" behaves differently in Stella under this version as well.
None of that really matters though - it looks like whatever issue I'm having isn't related to bB version from my own testing.  To get 1.0 to work on my mac, I had to recompile the binaries, and even run the windows version of dasm through wine (since there was no sources for dasm in that bundle.  Still, same result on my end.
On what platform were you compiling?  One would think that wouldn't make a difference, but there must be something different since you got a different result than I did.
#4 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Thu Jun 15, 2017 12:52 PM
Here is an even more simplified example - an 8k "hello world" with filler data.  It fails on the portable when compiled with either version of bB.
#5 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,648 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Thu Jun 15, 2017 1:22 PM
I didn't look at it closely, but it seems like data is trying to be accessed from another bank. Am I seeing that correctly? The bB page says "All data tables, regular or sequential, must be located in the same bank where they are read. If you try to access data in another bank, there will be no errors, but the data you get will certainly be incorrect."
In a program with more than one bank, I continue the main loop from bank to bank and read what needs to be read in each bank.
#6 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Thu Jun 15, 2017 1:43 PM
The data isn't read at all in this case.  It's only there to fill up the banks, since Mr SQL suggested that the portable might not detect banks that are mostly empty.  The only thing the code does is increment the score when fire is pressed.  I wanted to reduce the problem to the simplest case to help rule out issues with the code itself.  Also, to be clear, it only fails on the portable, which doesn't have the best emulator (but is still fun for many games).
#7 Random Terrain OFFLINE
Random Terrain
  • 28,648 posts
    Replay Value
    Nonlinear
Posted Thu Jun 15, 2017 3:14 PM
What happens if you put a dummy loop in the second bank along with the unused data?
#8 iesposta OFFLINE
iesposta
  • 3,664 posts
  • Retro-gaming w/my VCS
Posted Thu Jun 15, 2017 3:51 PM
First thing I think of is Illegal Opcodes.
batari Basic may or may not use illegal opcodes.
The Flashback Portable may or may not handle illegal opcodes.
Maybe a large compiled batari Basic .asm source could be searched for common illegal opcodes?
#9 Mr SQL OFFLINE
Mr SQL
  • 1,879 posts
Posted Fri Jun 16, 2017 5:24 AM
I used a Windows XP system that I keep offline from 2002 to compile it. I haven't tried on Windows 10 or the mac.
You should be able to duplicate my results with the 1.0 download form batari's site plus the pfcolors update using wine or soft windows.
Oh, I edited the file in an editor and used the command line (run COMMAND or CMD to get there) to compile: "compile game.bas"
#10 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Fri Jun 16, 2017 8:32 AM
No dice, but thanks for the suggestion.  For an 8K rom, the bB seems to put the kernel in the second bank, anyway, so both banks are getting used regardless.
#11 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Fri Jun 16, 2017 8:34 AM
I only just noticed that the version you compiled is 4K.  I can make this and others work when I compile to 4K, too (both on the older version and the latest).  My problem is only specifically with bankswitched games compiled with bB not running on the portable.
#12 Mr SQL OFFLINE
Mr SQL
  • 1,879 posts
Posted Fri Jun 16, 2017 7:49 PM
Hmmm... I tried to compile the 8K HelloWorld and it freezes on the "loading..." screen, haven't seen that screen freeze before looks like a new kind of loading error, so far I would always see them load and then glitch but they get past the loading screen. Gives me a theory the portable doesn't like $FF as filler data since bitd that meant "unused" and it wants the RAM area to be unused/$FF but  wants that ROM area filled (Portable logic).
Trying with the $FF changed to different filler data ... got it :)
I relaced $FF with 55 no $ just 55 decimal and boom it works:
Attached File  Helloworld3.bin   8KB   30 downloads
#13 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Sat Jun 17, 2017 6:55 AM
attachicon.gifHelloworld3.bin
Yes!  Success!  It also worked with the latest RevEng build on my larger WIP that I haven't posted yet (16K romsize).  Thanks so much for figuring this out!
I wish there were an automated way to generate this filler data as part of the build, but I'll definitely settle for filling it in myself (and it may not be necissary once my bankes become more filled with my own code and data.
#14 Mr SQL OFFLINE
Mr SQL
  • 1,879 posts
Posted Sat Jun 17, 2017 9:28 AM
You're welcome! :)  Very cool it's working on the other build as well.
Looking forward to playing your game on the portable!
#15 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Fri Jun 23, 2017 2:28 PM
I was wondering if anyone had any clever ideas on how a game might be able to detect whether or not it is running on the portable?  This would be handy to work around some its limitations without having to give up on features when not running on the portable, and not have to produce two different version of the game.
#16 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,729 posts
Posted Fri Jun 23, 2017 9:45 PM
7800 detection works by checking for specific values in user RAM when cold start begins. VCS (the actual console) detection *could* work by checking for value $FD in the stack pointer (don't know if anybody has taken advantage of that yet). The portable has a definite playfield issue where updating the registers too soon (but still within the range allowed by actual hardware) can cause screen garble on the portable. So a short routine where a sprite collision with playfield could feasibly be used for AFP detection. However, this probably won't work once emulation gets better on newer versions of the portable.
#17 Mr SQL OFFLINE
Mr SQL
  • 1,879 posts
Posted Sat Jun 24, 2017 4:40 AM
Location 24 (decimal) holds a different value on the Portable.
#18 DirtyHairy OFFLINE
DirtyHairy
    Moonsweeper
  • 370 posts
Posted Sat Jun 24, 2017 6:17 AM
Checking SP does not work if starting from harmony as the BIOS modifies it. There's a very useful test ROM by Omegamatrix that displays the initial state here: http://atariage.com/...0/#entry3081055
Edited by DirtyHairy, Sat Jun 24, 2017 6:18 AM.
#19 kdgarris ONLINE
kdgarris
    Moonsweeper
  • 296 posts
Posted Fri Jun 30, 2017 10:38 AM
It looks like you are correct!  It holds 152 on the Portable, and 100 on Stella.  I'm not sure what it shows on real hardware.  So, for now at least, here's my kludgy AFP detection, in case anyone else finds it useful:
   temp1 = [24]
   if temp1 = 152 then PortableBit3{3} = 1
#20 Mr SQL OFFLINE
Mr SQL
  • 1,879 posts
Posted Sun Jul 2, 2017 9:03 PM
   temp1 = [24]
Excellent! :) Very cool you went with the Portables value to set the bit.
That location is different on the real hardware too, It may start out the same as in Stella but if you plug a Sega Pad in (or paddles) it changes - I've used it to make sure players used a Joystick for KC Munchkin and not a sega pad because KC bounces off the walls and you really need joystick precision to play.
Interesting thing I noticed on my Vader and Jr models is that over time, that value can change on it's own with the temperature.
Change time can vary between 20 minutes to a few hours with variable temp and a day or more in a climate controlled environment.
#21 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,729 posts
Posted Mon Jul 3, 2017 3:51 AM
Actually, results would vary on actual hardware (since you're reading from a write-only register). Unreliable!
#22 DirtyHairy OFFLINE
DirtyHairy
    Moonsweeper
  • 370 posts
Posted Mon Jul 3, 2017 3:53 AM
Nothing drives the bus, and, therefore, the result of the read is not well defined and may change over time.
To be more precise, a TIA read depends only on the lowest four bits of the address, so reading from 0x18 is the same as reading from 0x08, and that's INPT0. The TIA will only drive the highest three bit of the bus, and in the case of INPT0, that's either 0x00 or 0x80, depending on the charge of the capacitor in paddle readout circuit. The remainder of the bus is floating and will usually reflect its last driven state, but this can change and differ on real hardware. If the read is done via a "LDA $18", I would expect the result to either be 0x18 or 0x98 (=152). I am not sure why Stella gives you 100, but it is impossible to tell what is really going on without looking at the generated assembly. Do you perchance have "tiadriven" enabled?
Edited by DirtyHairy, Mon Jul 3, 2017 4:43 AM.
#23 Nukey Shay OFFLINE
Nukey Shay
    Sheik Yerbouti
  • 21,729 posts
Posted Mon Jul 3, 2017 4:18 AM
It does...wasting 3 cycles translates as a triple-NOP (WHY?? I dunno).
Triple-NOP is supported by AFP.  Ought to have supported Vblank better, but I digress.
#24 Mr SQL OFFLINE
Mr SQL
  • 1,879 posts
Posted Mon Jul 3, 2017 5:26 AM
I think DirtyHairy is correct, it's the cap that's changing state over time with the temperature on real hardware and why the value changes when you plug in a sega pad or paddles. kdgarris used the AFP value which should be reliable on the AFP (no cap to change state).
