Pac-Man Patterns and Gameplay
29 replies to this topic
#26 Inky OFFLINE
Inky
    Just a regular dude.
  • 25,128 posts
  • Meh
Posted Mon Jun 19, 2017 4:30 PM
Oh no, someone whose avatar is "Breast Breakout" has me blocked. Truly I am shamed.
As you should be.
#27 Dauber OFFLINE
Dauber
  • 5,498 posts
  • What's for tea, luv?
  • Location:Right by where The Lone Ranger went to high school
Posted Mon Jun 19, 2017 4:34 PM
You can actually have some little patterns in Ms. Pac.. like this famous one where you can pass through a ghost on the strawberry level:
Doesn't work if you use the rack test. :/
#28 negative1 OFFLINE
negative1
    Chopper Commander
  • 153 posts
Posted Mon Jun 19, 2017 4:35 PM
i've gotten to the killscreen in the arcade pacman, (and home emulators), and on non fixed killscreens gotten to 7.1 million on the xbox 360 using patterns.
so yeah, the 9th key pattern can work indefinitely, if you don't mess up, and if you do, and know how to recover, you can keep going.
on ms pac-man, there are pseudo patterns. basically, you go to the hiding spots, and let the ghosts group together.
from that point on (boards below 21 where they blink), you can do the same routine, and get all the ghosts on the energizers.
for the boards past 21, where they don't blink, you put the ghosts into a holding pattern, and then can lead them around and
clear the 2 boards that alternate (junior and chase board).
there are many killscreen games, and games showing these on youtube, look up aart van vliet, or  velvet rolo to see them.
no one's gotten to 1 million on the arcade, because of the random fruits. however, on some home versions emulated there
is no kill screen, and a screen 256, it starts over, so it is possible to get that far (still working on it). i put up a video on
youtube showing the restart.
i've played the 2600 versions of pac-man, and ms pac-man, and yes, because of the lack of patterns, they are much harder.
would have liked to see more video of the AI that played the 2600 ms pac man, maybe that would have had some ideas about it.
later
-1
#29 NE146 OFFLINE
NE146
    Dumbass Atari Fan
  • 15,027 posts
Posted Mon Jun 19, 2017 4:45 PM
Sure it does. You probably got a variant where one of the 2 "random" ghosts disrupts it.. that may sometimes happen (albeit very rarely).
Just try again. :)
<edit> see?
Edited by NE146, Mon Jun 19, 2017 4:50 PM.
#30 Dauber OFFLINE
Dauber
  • 5,498 posts
Posted Tue Jun 20, 2017 11:42 AM
I see what happened -- if you actually use the rack cheat before the play starts, you won't get the go-thru-Inky trick. You actually have to play some of the cherries level for it to work.
