Are there Any Old Fashion Dial Up BBS's Left?
31 replies to this topic
#26 arcadeshopper OFFLINE
arcadeshopper
  • 2,712 posts
Posted Mon Jun 26, 2017 9:26 AM
The odd thing is my fax machine works just fine with Magicjack.  I'll have to look into this ooma.  Anyone else have success using modems with voip?
Fax is a totally different protocol and their codec is designed to support it.
I ended up getting a line with fios that works perfect at any baud rate.
Greg
Sent from my LG-H830 using Tapatalk
#27 ricortes OFFLINE
ricortes
    Dragonstomper
  • 609 posts
Posted Mon Jun 26, 2017 12:05 PM
I bought a USB modem several years ago, this model I think http://www.frys.com/...CH:MAIN_RSLT_PGIt ran OK for a couple of years but then went south on me. I'll probably be dropping my land line this year as I get 10 crank calls a day from telemarketers and only 4 calls a month from real humans.<sic>
IMHO: Lots of USB modems for sale at lower price points then the Hiro. Considering the fate of mine, I would give them a try as the expensive Hiro ended up just as dead.
Edited by ricortes, Mon Jun 26, 2017 12:07 PM.
#28 Kyle22 OFFLINE
Kyle22
  • 3,184 posts
Posted Mon Jun 26, 2017 6:37 PM
Well, if the above is all correct, I'd get a nice Hayes compatible fast modem and use it on fios.
The proof is in the results :)
#29 tep392 OFFLINE
tep392
  • 2,883 posts
Posted Tue Jun 27, 2017 9:07 AM
I cant get fios in my complex. I would need a sevice that works with my current ISP.
#30 dafivehole OFFLINE
dafivehole
    Dragonstomper
  • 701 posts
Posted Wed Jun 28, 2017 11:57 AM
So, just to be clear here, I have Ooma in my house and if I get an Atari 1030 modem, I should be able to get online that way?  If so, this is great  :D
Thank you,
Roger
#31 BillC OFFLINE
BillC
  • 1,722 posts
Posted Thu Jun 29, 2017 7:49 PM
I would recommend something faster than 300 BAUD, the SX212(1200 BAUD) is a better modem and can be used on either SIO or RS232 port.
It does this by integrating an R-Verter interface inside the modem, to use it via SIO the R-Verter handler needs to be loaded.
#32 dafivehole OFFLINE
dafivehole
    Dragonstomper
  • 701 posts
Posted Fri Jun 30, 2017 6:45 AM
Thank you for the info... just gotta find a modem now  ;)
Roger
