C02 Compiler
c c-like compiler language
26 replies to this topic
#1 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 11:48 AM
This is something that had been bouncing around in my head for at least ten years. I originally started it about five years ago, but then got distracted and finally picked it up again a couple months ago.
The language and compiler are still in the alpha stage of development. The code is currently a bit of a mess, and I'm still wrestling with design decisions.
Here is some explanation from the beginning of the documentation that I have written:
INTRODUCTION
C02 is a simple C-syntax language designed to generate highly optimized
code for the 6502 microprocessor. The C02 specification is a highly
specific subset of the C standard with some modifications and extensions
PURPOSE
Why create a whole new language, particularly one with severe restrictions,
when there are already full-featured C compilers available? It can be
argued that standard C is a poor fit for processors like the 6502. The C
was language designed to translate directly to machine language instructions
whenever possible. This works well on 32-bit processors, but requires either
a byte-code interpreter or the generation of complex code on a typical
8-bit processor. C02, on the other hand, has been designed to translate
directly to 6502 machine language instructions.
The C02 language and compiler were designed with two goals in mind.
The first goal is the ability to target machines with low memory: a few
kilobytes of RAM (assuming the generated object code is to be loaded into
and ran from RAM), or as little as 128 bytes of RAM and 2 kilobytes of ROM
(assuming the object code is to be run from a ROM or PROM).
The compiler is agnostic with regard to system calls and library functions.
Calculations and comparisons are done with 8 bit precision. Intermediate
results, array indexing, and function calls use the 6502 internal registers.
While this results in compiled code with virtually no overhead, it severely
restricts the syntax of the language.
The second goal is to port the compiler to C02 code so that it may be
compiled by itself and run on any 6502 based machine with sufficient memory
and appropriate peripherals. This slightly restricts the implementation of
code structures.
#2 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,699 posts
  • Medieval Mayhem
Posted Sun Jun 25, 2017 12:11 PM
A lot of 2600 coding involves instructions occurring at specific cycles on a scanline.   How does C02 handle that?  If it doesn't, then you can't position a player, missile, or ball accurately.
For instance, this is one of the commonly used routines for positioning objects:
; PosObject
; subroutine for setting the X position of any TIA object
; when called, set the following registers:
;   A - holds the X position of the object
;   X - holds which object to position
;       0 = player0
;       1 = player1
;       2 = missile0
;       3 = missile1
;       4 = ball
; the routine will set the coarse X position of the object, as well as the
; fine-tune register that will be used when HMOVE is used.
; Note: The X position differs based on the object, for player0 and player1
;       0 is the leftmost pixel while for missile0, missile1 and ball 1 is
;       the leftmost pixel:
;           players     - X range is 0-159
;           missiles    - X range is 1-160
;           ball        - X range is 1-160
; Note: Setting players to double or quad size will affect the position of
;       the players.
PosObject:
        sec
        sta WSYNC
DivideLoop
        sbc #15        ; 2  2 - each time thru this loop takes 5 cycles, which is
        bcs DivideLoop ; 2  4 - the same amount of time it takes to draw 15 pixels
        eor #7         ; 2  6 - The EOR & ASL statements convert the remainder
        asl            ; 2  8 - of position/15 to the value needed to fine tune
        asl            ; 2 10 - the X position
        asl            ; 2 12
        asl            ; 2 14
        sta.wx HMP0,X  ; 5 19 - store fine tuning of X
        sta RESP0,X    ; 4 23 - set coarse X position of object
        rts            ; 6 29
The STA RESP0,X must occur at 23, 28, 33, etc (ever 5 cycles).  HMP0 is on zero page, so the STA HMP0,x would normally be compiled as a  4 cycle Zero Page instruction, which would cause the STA RESP0,x to occur at the wrong time.  So we force the compiler to use a word address (16-bit) instead of Zero Page address for that extra cycle of time, which is what makes this routine possible.
#3 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 12:23 PM
The compiler is efficient enough that I can write most VCS code directly in C02.
Here is an example:
//Atari VCS Color Bars Program
#pragma origin $F800    //2k Cartridge
#include <vcshead.h02>  //TIA and RIOT Registers
/* Generate Vertical Sync Signal */
void vtsync() {
  A=2;     //Set Bit 2 (D1)
  WSYNC=A; //Wait for end of Scanline
  VSYNC=A; //Turn On Vertical Sync
  WSYNC=A; //Wait 2 More Scanlines
  WSYNC=A;
  A=0;     //Clear Bit 2 (D1)
  WSYNC=A; //Wait for End of 3rd Scanline
  return;
/* Execute Vertical Blank Code */
void vtblnk() {
  X=37; //Delay 37 Scanlines
  do {
    X--;
  } while (X);
  return;
/* Execute Kernel Code */
void kernel() {
  A=0; //Clear All Bits
  VBLANK=A; //Turn Off Vertical Blank
  X=0; //Draw 192 Scanlines (256-64)
  do {
    if (X & 3) {
      WSYNC = A;  //Wait for end of Scanline
      COLUBK = X; //Set Background Color
    X--;
  } while (X);
  return;
/* Execute Overscan Code */
void ovrscn() {
  VBLANK=A; //Turn On Vertical Blank
  X=27; //Delay 27 Scanlines
  do {
    WSYNC=X;  //Wait for end of Scanline
    X--;
  } while(X);
  return;
start:
  asm("","SEI","");
  asm("","CLD","");
  A = 0;
  X = A;
  Y = A;
  do {
    X--;
    asm("","TXS","");
    push 0;
  } while (X);
irqbrk: //Code to Execute when BRK Instruction is Encountered
main:  //Start of Program Code
  vtsync(); //Generate Vertical Sync Signal
  vtblnk(); //Generate Vertical Blank Signal
  kernel(); //Execute Kernal Code
  ovrscn(); //Execute Overscan Code
  goto main;
#include <vcsfoot.h02>  //Finalization Code
And here is the Assembly Language that's created:
        PROCESSOR 6502
        ORG $F800
; ======== Assembler File  include/vcshead.a02  =======
VSYNC   EQU $00  ;0000 00x0   Vertical Sync Set-Clear
VBLANK  EQU $01  ;xx00 00x0   Vertical Blank Set-Clear
WSYNC   EQU $02  ;---- ----   Wait for Horizontal Blank
COLUBK  EQU $09  ;xxxx xxx0   Color-Luminance Background
VTSYNC:                  ;VOID VTSYNC() {
        LDA #2           ;  A = 2
        STA WSYNC        ;  WSYNC = A;
        STA VSYNC        ;  VSYNC = A;
        LDA #0           ;  A = 0;
        RTS              ;  RETURN; }
VTBLNK:                  ;VOID VTBLNK() {
        LDA #37          ;  X = 37;
        TAX              ;
L_0001:                  ;  DO {
        DEX              ;    X--;
        TXA              ;  } WHILE(X);
        BEQ L_0000
        JMP L_0001       ;
L_0000: RTS              ;  RETURN; }
KERNEL:                  ;VOID KERNEL() {
        LDA #0           ;  A = 0;
        STA VBLANK       ;  VBLANK = A;
        LDA #0           ;  X = 0 ;
        TAX              ;
L_0003: TXA              ;  DO {
        AND #3           ;    IF ( X & 3 ) {
        BEQ L_0004       ;
        STA WSYNC        ;      WSYNC= A
        TXA              ;      COLUBK = X;
        STA COLUBK       ;    }
L_0004: DEX              ;    X--;
        TXA              ;  } WHILE (X);
        BEQ L_0002       ;
        JMP L_0003       ;
L_0002: RTS              ;  RETURN; }
OVRSCN:                  ;VOID OVRSCN() {
        STA WSYNC        ;  WSYNC= A;
        LDA #2           ;  A = 2;
        STA VBLANK       ;  VBLANK= A;
        LDA #27          ;  X = 27;
        TAX              ;
L_0006: TXA              ;  DO {
        STA WSYNC        ;  WSYNC= X;
        DEX              ;  X--;
        TXA              ;  } WHILE (X);
        BEQ L_0005       ;
        JMP L_0006       ;
L_0005: RTS              ;  RETURN; }
START:                   ;START:
        SEI              ;  ASM("","SEI","");
        CLD              ;  ASM("","CLD","");
        LDA #0           ;  A = 0;
        TAX              ;  X = A;
        TAY              ;  Y = A;
L_0008:                  ;  DO {
        DEX              ;    X--;
        TXS              ;  ASM("","TXS","");
        LDA #0           ;  PUSH 0;
        PHA              ;
        TXA              ;  } WHILE (X);
        BEQ L_0007       ;
        JMP L_0008       ;
L_0007:                  ;
IRQBRK:                  ;IRQBRK:
MAIN:                    ;MAIN:
        JSR VTSYNC       ;  VTSYNC();
        JSR VTBLNK       ;  VTBLNK();
        JSR KERNEL       ;  KERNEL(;)
        JSR OVRSCN       ;  OVRSCN(;)
        JMP MAIN         ;  GOTO MAIN;
; ======== Assembler File  include/vcsfoot.a02  =======
        ORG  $FFF8   ;Control and Interrupt Registers
SCCTL   DC.B $00     ;$FFF8 Supercharger Control Register
SCAUD   DC.B $00     ;$FFF9 Supercharger Audio Data
        DC.W $0000   ;$FFFA Non-Maskable Interrupt Vector (Unused)
        DC.W START   ;$FFFC Reset Vector
        DC.W IRQBRK  ;$FFFE Interrupt Vector
#4 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 12:36 PM
This is handled through function calls that are coded in pure assembly language.
I started to type in an example, then hit backspace at the wrong time and lost it. I'll post it shortly.
#5 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,699 posts
  • Medieval Mayhem
Posted Sun Jun 25, 2017 12:50 PM
Neat!  I'd suggest a minor change to the strobe registers(WSYNC, RESP0, HMOVE, etc):
void vtsync() {
  WSYNC;   //Wait for end of Scanline
  WSYNC;   //Wait 2 More Scanlines
  WSYNC;
  WSYNC;   //Wait for End of 3rd Scanline
  return;
Makes it cleaner, less typing, and thus less chance of a mistake.
Even better would be to abstract the register usage when feasible:
void vtsync() {
  VSYNC=2; //Turn On Vertical Sync, Set Bit 2 (D1)
  WSYNC;
  VSYNC=0; //Turn On Vertical Sync, Clear Bit 2 (D1)
  return;
#6 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 2:41 PM
void vtsync() {
  WSYNC;
  return;
A variable by itself as statement doesn't have any meaning in C-like languages. If I implemented C-like macros then I could possibly do something like this.
#define WSYNC = WSYNC = A
WSYNC;
However, almost all code that uses strobe registers is going to be in a function that's coded in assembly language anyway, so it should not be necessary.
#7 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 2:45 PM
void vtsync() {
  WSYNC;
  return;
Registers are already abstracted. So the code
VSYNC=2;
Compiles to
LDA #2
STA VSYNC
I allowed the use of a register as a variable as an advanced feature so redundant LDA's can be avoided.
#8 Mr SQL OFFLINE
Mr SQL
  • 2,094 posts
Posted Sun Jun 25, 2017 3:13 PM
This looks awesome! :)  Looking foward to seeing games and demo's in this tiny-c.
There is anothe similar project Atac-c that may be helpful, and you're also welcome to use the Flashback BASIC runtime which has a bit-blitter and other features that may give you some ideas.
#9 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 3:34 PM
Do you have a link to Atac-c. When I Googled it, I got too many unrelated hits.
#10 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 3:49 PM
void vtsync() {
  WSYNC;
  return;
There are other 6502 based systems that use strobe registers so, I modified the compiler to allow implicit assignments.
IMPLICIT ASSIGNMENTS
A statement consisting of only a simple variable is treated as an
implicit assignment of the A register to the variable in question.
This is useful on systems that use memory locations as strobe registers.
Examples:
  HMOVE;  //Move Objects (Atari VCS)
  S80VID; //Enable 80-Column Video (Apple II)
Note: An implicit assignment generates an STA opcode with the variable
as the operand.
Thanks for the idea.
#11 splendidnut OFFLINE
splendidnut
    Chopper Commander
  • 150 posts
Posted Sun Jun 25, 2017 3:58 PM
Ata-C by Gip-Gip:
https://github.com/Gip-Gip/AtaC
#12 splendidnut OFFLINE
splendidnut
    Chopper Commander
  • 150 posts
Posted Sun Jun 25, 2017 4:00 PM
Do you plan on allowing inline assembly code?
#13 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 4:26 PM
Already implemented. You can use either
#include "filename.asm"
which simply inserts the contents of the specified file, or
asm("label", "opcode", "operand");
which generates a single line of assembly language.
The latter is used in my example program in the second comment.
#14 tschak909 OFFLINE
tschak909
  • 3,163 posts
Posted Sun Jun 25, 2017 4:35 PM
This is pretty nice. :)
-Thom
#15 splendidnut OFFLINE
splendidnut
    Chopper Commander
  • 150 posts
Posted Sun Jun 25, 2017 5:37 PM
Ah.  I missed that the first time thru.  Nice to see easy inclusion of an assembly language file... But what about a block of inline assembly code?  I'll admit, that I was spoiled by Turbo Pascal in that aspect.  I don't think I've ever come across a C compiler that has done it as nicely as Turbo Pascal (version 6+).
Here is an example of a full procedure:
Procedure ClearMem(MSeg,size:word); assembler;
asm
	mov ax,MSeg
	mov es,ax
	xor di,di
	xor ax,ax
	mov cx,size
	shr cx,1
	stosw
end;
And an inline block;
procedure PrintError(s:string);
begin
	asm
		mov ax,03h
		int 10h
	end;
	writeln(s);
end;
That would be my feature request.  :)
#16 splendidnut OFFLINE
splendidnut
    Chopper Commander
  • 150 posts
Posted Sun Jun 25, 2017 5:43 PM
I just realized that this seems very similar to C--.
#17 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sun Jun 25, 2017 9:12 PM
asm
	mov ax,MSeg
	mov es,ax
	xor di,di
	xor ax,ax
	mov cx,size
	shr cx,1
	stosw
end;
begin
	asm
		mov ax,03h
		int 10h
	end;
	writeln(s);
end;
Tiny C uses the non-standard directives #asm and #asmend.
I should probably do something similar, where it takes the inline assembly and converts is to the form expected by the target assembler. This would allow me to embed the assembly language right in the header files instead of having a separate assembly file.
#18 Kylearan OFFLINE
Kylearan
    Chopper Commander
  • 210 posts
Posted Mon Jun 26, 2017 1:03 AM
Neat project! It reminds me a bit of macross or k65. I'm looking forward to see how it fares in a "real-world" project (small game or demo). :)
#19 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Thu Jun 29, 2017 10:33 PM
I've been working on a 2-line kernel library based on Random Terrain's Spiceware's Collect Tutorial.
Here's a simple program that uses the kernel to display both players:
#pragma origin $F800    //4k Cartridge
#include <vcsstub.h02>  //Initialize VCS
#include <vcslib.h02>   //VCS Library Routines
#include <k2line.h02>   //Two Line Game Kernel
#define KNLLNS = 96     //Kernal Lines (Scanlines/2)
#define P0HGHT = 10     //Player 0 Height
#define P1HGHT = 10     //Player 1 Height
//Color Table
char colors = {$86, $C6, $46, $00, $0E, $06, $0A, $00};
//Human Shaped Player Graphics
char human = {%00011100, %00011000, %00011000, %00011000, %01011010,
              %01011010, %00111100, %00000000, %00011000, %00011000};
/* Setup Code */
void setup() {
  setclr(&colors); //Set Color Table
/* Vertical Blank Code */
void vrtblk() {
  posobj(0,0);          //Set P0 X-Position
  p0prep(96, &human);   //Set P0 Y-Position & Graphics Pointer
  posobj(8,1);          //Set P1 X-Position
  p1prep(96, &human);   //Set P1 Y-Position & Graphics Pointer
void kernel() {
  dsplns();      //Display Playfield and Objects
void ovrscn() {
#include <digits.h02>   //Digit Graphics
Edited by CurtisP, Sat Jul 1, 2017 4:41 PM.
#20 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,982 posts
  • Always left from right here!
Posted Fri Jun 30, 2017 1:03 AM
Cool idea! :thumbsup:
However, at the moment the generated assembler code seems still pretty inefficient. E.g.
        LDA #37          ;  X = 37;
        TAX              ;
L_0001:                  ;  DO {
        DEX              ;    X--;
        TXA              ;  } WHILE(X);
        BEQ L_0000       ;
        JMP L_0001       ;
Compared to this:
        LDX #37          ;  X = 37;
L_0001:                  ;  DO {
        DEX              ;    X--;
        BNE L_0001       ;  } WHILE(X);
        RTS              ;  RETURN; }
#21 DirtyHairy OFFLINE
DirtyHairy
    Dragonstomper
  • 505 posts
Posted Fri Jun 30, 2017 4:56 AM
If that's what it is generating, then I think you have spotted a bug: the generated assembly does not do "WSYNC = A". Instead it does "WSYNC = X"  in a somewhat convoluted way  :) It will work anyway as WSYNC is a strobe, but still...
Edited by DirtyHairy, Sun Jul 2, 2017 5:26 AM.
#22 SpiceWare ONLINE
SpiceWare
    Draconian
  • 12,699 posts
  • Medieval Mayhem
Posted Fri Jun 30, 2017 10:10 AM
I've been working on a 2-line kernel library based on Random Terrain's Collect Tutorial.
That's my tutorial, RT reformatted it for his site (with my permission).
#23 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sat Jul 1, 2017 12:52 PM
Sorry about that. I'm getting names all mixed up, especially late at night.
By the way. I've found it quite useful.
Edited by CurtisP, Sat Jul 1, 2017 12:53 PM.
#24 CurtisP OFFLINE
CurtisP
    Moonsweeper
  • 260 posts
Posted Sat Jul 1, 2017 4:52 PM
        LDA #37          ;  X = 37;
        TAX              ;
L_0001:                  ;  DO {
        DEX              ;    X--;
        TXA              ;  } WHILE(X);
        BEQ L_0000       ;
        JMP L_0001       ;
Compared to this:
        LDX #37          ;  X = 37;
L_0001:                  ;  DO {
        DEX              ;    X--;
        RTS              ;  RETURN; }
I'm making a lot of design compromises. Originally, the compiler didn't even recognize registers. I added them in because I thought it might be useful.
Now compiling
X=3
into
LDX #3
is easy enough, but what about
X=TEMP+3
That would have to be
LDA TEMP
CLC
ADC #3
TXA
So my choices are to use the expression parser (which uses the Accumulator) followed by a TAX, not allow expressions when assigning values to X or Y, or write some extra complicated code to figure out what is after the equals sign.
At this point, I've decided that I want all assignments to work the same way and have predictable side effects.  In general, user programs won't be using the registers anyway, because they can be overwritten by the generated code.
#25 Mr SQL OFFLINE
Mr SQL
  • 2,094 posts
Posted Sun Jul 2, 2017 10:22 PM
You're tiny C compiler is very efficient, tremendously so for C, but you may still end up deciding it's better to have a pure Assembly Framework with a kernel and a pure Assembly runtime library for your tiny C to call.
It's really interesting to see the kernel created in a high level language like you are doing, you can definitely do it but to get optimum performance for games and demos it might be better to have just the gameloop in tiny C and call the runtime.
Neither has been done before with C as far as I'm aware using just the real hardware. Cool whichever approach you take - even cooler if you do both! :)
