bradhig1 Posted June 26, 2017 Share Posted June 26, 2017 Can the stand alone Adam use expansion module 1 to play atari 2600 games. Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted June 26, 2017 Share Posted June 26, 2017 Yep. 2 Quote Link to comment Share on other sites More sharing options...
NIAD Posted June 27, 2017 Share Posted June 27, 2017 Yes is the easy answer and is correct, but depending on what version of the Adam you are using will determine if you get LOW VOLUME output... - the Expansion Module #3 that connects to a ColecoVision will output sound correctly in it's unmodified state. If your CV is modded for Composite video output you might have the LOW VOLUME output issue due to incorrectly tapping into the sound output by the person who performed the mod. - the Stand-Alone Adam as shipped by Coleco incorrectly tapped into the sound and you will experience LOW VOLUME output with the E.M.#1 as well as Opcode SGM. The wiring that taps into the sound has to be corrected by connecting it to the CAP at C88 for proper sound output. 1 Quote Link to comment Share on other sites More sharing options...
RangerG Posted June 27, 2017 Share Posted June 27, 2017 I use the expansion module on an Adam to play Atari 2600 games. I use them both all the time and it works great. It saves space and the 2600 games through the A/V of the Adam look really good. I had to do the sound mod, but it is easy and worth it. Quote Link to comment Share on other sites More sharing options...
RangerG Posted June 27, 2017 Share Posted June 27, 2017 Here is the post where I discuss this and then Rey helps me: http://atariage.com/forums/topic/216331-atari-expansion-on-an-adam/?hl=%2Badam+%2Bsound+%2Bmod&do=findComment&comment=3449489 Like I said, it turned out great: one power supply, saves space, and excellent video out. 1 Quote Link to comment Share on other sites More sharing options...
Rey Posted June 27, 2017 Share Posted June 27, 2017 Keep in mind that if you ever decided to the F18A upgrade you would lose video from the expansion module 1. Composite outputs have been done to this module if one wanted both to function together. Quote Link to comment Share on other sites More sharing options...
RangerG Posted June 27, 2017 Share Posted June 27, 2017 A pic of the set-up 1 Quote Link to comment Share on other sites More sharing options...
Inky Posted June 27, 2017 Share Posted June 27, 2017 I wonder what would happen if you could plug the ADAM expansion into a stand alone ADAM ad infinitum Quote Link to comment Share on other sites More sharing options...
Swami Posted June 27, 2017 Share Posted June 27, 2017 I wonder what would happen if you could plug the ADAM expansion into a stand alone ADAM ad infinitum Quote Link to comment Share on other sites More sharing options...
NIAD Posted June 28, 2017 Share Posted June 28, 2017 That's been asked before and Kramer (above) answered this perfectly... his mind is blown as well as, probably, both ADAM Memory Consoles. I wouldn't try this unless you have a lot of extra systems and don't mind the risk. Quote Link to comment Share on other sites More sharing options...
bradhig1 Posted June 29, 2017 Author Share Posted June 29, 2017 A pic of the set-up Oh it goes in sidways. Quote Link to comment Share on other sites More sharing options...
Swami Posted July 7, 2017 Share Posted July 7, 2017 I wonder what would happen if you could plug the ADAM expansion into a stand alone ADAM ad infinitum That's been asked before and Kramer (above) answered this perfectly... his mind is blown as well as, probably, both ADAM Memory Consoles. I wouldn't try this unless you have a lot of extra systems and don't mind the risk. Orrrr... 2 Quote Link to comment Share on other sites More sharing options...
Inky Posted July 7, 2017 Share Posted July 7, 2017 I was tongue in cheek with my question.... Quote Link to comment Share on other sites More sharing options...
Swami Posted July 7, 2017 Share Posted July 7, 2017 I was tongue in cheek with my question.... Some guy tried to duplicate the bart mega-phone challenge in a youtube video. Truth is most megaphones have low decibel ranges for distortion. A lot of them can't even handle you yelling into them without garbled distortion coming out. The feedback was much louder than the actual amplified voice. I often find the same at bus/train/airport stations. You would need super high tech high fidelity mega-phones to remotely approximate the cartoon effect. I assume the analogy for the adam would be power limitations...or a fire. Quote Link to comment Share on other sites More sharing options...
