Atari 1040 STe 2 bombs: Bus error and TOS Error #35
3 replies to this topic
#1 SalsaPat OFFLINE
SalsaPat
    Combat Commando
  • 2 posts
Posted Wed Jun 28, 2017 8:57 AM
Hi, I have a Atari 1400 STe. But I have 2 errors.
The first is two bombs when I load disk from floppy disk.
The second is reboot ok when no disk and I view GEM but when i put disk and load .PRG I have a TOS error #35.
PS: I have never modified my motherboard.
Thank you
Edited by SalsaPat, Wed Jun 28, 2017 8:57 AM.
#2 SalsaPat OFFLINE
SalsaPat
    Combat Commando
  • 2 posts
Posted Wed Jun 28, 2017 10:06 AM
I thing I find the problem:
https://drive.google...ew?usp=drivesdk
Where I find this piece it's the new problem !
#3 ggn OFFLINE
ggn
  • 1,472 posts
Posted Wed Jun 28, 2017 11:43 PM
That seems to be the RF modulator. I'm not exactly convinced that it could be the source of your problems!
According to the documentation Error #-35 translates to "No more handles available" but you can get that error when you load an invalid .prg file. Two of the common faults here are that either the floppy drive has gone bad or the disks. Try using different disks and programs and see if you get the same error consistently - then it might be the floppy drive itself. If some disks can load the .prg files without erroring out then it's probably the floppy disks themseleves - either reformat them and try again or throw them to the bin!
Hope this helps (and oh it's probably better if you ask the moderators to move this post to the main forum instead of programming as you might get more people to notice it there).
#4 ParanoidLittleMan ONLINE
ParanoidLittleMan
  • 1,628 posts
Posted Thu Jun 29, 2017 1:03 AM
Cleaning is first thing you need to do.
