Preview - New integer basic interpreter
basic compiler interpreter
59 replies to this topic
#26 pirx OFFLINE
pirx
    Moonsweeper
  • 447 posts
Posted Fri Jun 30, 2017 7:17 AM
i'd love to code one minimalistic basic interpreter and call it "Basic BASIC"
#27 dmsc OFFLINE
dmsc
    Moonsweeper
  • 473 posts
Posted Fri Jun 30, 2017 7:33 AM
Hi!
But errmmm,
Fast Basic is not a good name, since there already exists a Basic with that name for approx. 20 or more years - Fast Basic by Tom Hunt (has no extra commands, it is just about 10%-30% faster than Atari Basic)...
Well, I'm really bad at naming things, so no surprise there is another BASIC with the same name.
I believe that this project deserves a unique name.
Flying Basic, FlyBasic, DMSC Basic, FI Basic, Jet Basic, Citus Basic...
Mmmm.... not sure I like any of those :P (and, what "Citus" means?)
Ha, this is a great name ;)
#28 baktra OFFLINE
baktra
    Dragonstomper
  • 596 posts
Posted Fri Jun 30, 2017 7:43 AM
It is a latin word. Citus means quick, swift, rapid.
#29 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 182 posts
Posted Fri Jun 30, 2017 9:03 AM
Hi dmsc,
First of all, congratulations on the project. It really shows that it is an interpreter that brings together the best of all the others. Make the quick a typical example to test and it really works well.
This example is a game that you have to guess the number that the atari thinks
POKE 82,0
SECRETNUM=RAND(10)+1
REPEAT
   PUT 125
   PRINT : PRINT "GUESS A SECRET NUMBER BETWEEW 1 AND 10"
   PRINT
   PRINT "YOUR GUES :";
   INPUT #16,GUESS
   PRINT : PRINT
   IF GUESS=SECRETNUM THEN PRINT "YOU GOT IT!"
   IF GUESS<SECRETNUM THEN PRINT "TOO LOW. TRY AGAIN."
   IF GUESS>SECRETNUM THEN PRINT "TOO HIGHT. TRY AGAIN."
   PAUSE 100
UNTIL GUESS=SECRETNUM
   PRINT : PRINT : PRINT "THE END":PUT 253
When I try this interpreter I think that the CHR$ command is missing for use with the PRINTs.
 IF GUESS<SECRETNUM THEN PRINT "TOO LOW. TRY AGAIN.";CHR(253)
regards
#30 dmsc OFFLINE
dmsc
    Moonsweeper
  • 473 posts
Posted Fri Jun 30, 2017 9:24 AM
Hi!
Hi dmsc,
POKE 82,0
REPEAT
   PUT 125
   PRINT
   INPUT #16,GUESS
   PRINT : PRINT
   PAUSE 100
regards
Yes, you can replace it with:
IF GUESS<SECRETNUM : ? "TOO LOW. TRY AGAIN."; : PUT 253 : ENDIF
#31 Synthpopalooza OFFLINE
Synthpopalooza
  • 1,472 posts
Posted Fri Jun 30, 2017 9:55 AM
How about FujiBASIC? :)
#32 Bryan OFFLINE
Bryan
  • 10,926 posts
  • Cruise Elroy = 4DB7
Posted Fri Jun 30, 2017 2:54 PM
I kinda like JetBASIC.
InsaneBASIC? FlashBASIC? NitroBASIC?
#33 ascrnet OFFLINE
ascrnet
    Chopper Commander
  • 182 posts
Posted Fri Jun 30, 2017 7:38 PM
Hi!
Of course, I said it because right here I miss it. ;-)
Now another command that I miss is the TEXT of TBXL is it possible to implement it? :?
And the last in a future is thought to make a binary compiler? :?
regards
#34 dmsc OFFLINE
dmsc
    Moonsweeper
  • 473 posts
Posted Fri Jun 30, 2017 11:10 PM
Hi!
I updated the interpreter, now it supports DATA and USR.
This is a sample of both:
' Define a Machine Language routine:
'  PLA / EOR $FF / TAX  / PLA / EOR $FF / RTS
data ml() byte = $68,$49,$FF,$AA,$68,$49,$FF,$60
' Calls the routine with different values
for i=0 to 1000 step 100
    ? i, usr(adr(ml),i)
next i
Note that DATA statements define an array with the data, so you must specify if it's "byte" or "word" type. Also, DATA can be continued over lines by skipping the last comma and the variable name in the next lines:
  DATA big() byte = $12,$23,$45,$00,$15,
  DATA       byte = $08,$09,$15
USR function passes arguments in the stack and expects the return value in A/X registers (A = low part, X = high part).
The updated sources are over github.
#35 Philsan OFFLINE
Philsan
  • 3,803 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Sat Jul 1, 2017 12:46 AM
Thank you very much for your PMG routine, now included in latest FastBasic version.
Which is the easiest way to write, edit and launch FB programs?
EDIT
I read first post: "What is missing is an editor".
#36 Larry OFFLINE
Larry
  • 4,083 posts
Posted Sat Jul 1, 2017 2:30 AM
DMSC Basic had a nice ring to it. Great project!
-Larry
#37 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Sat Jul 1, 2017 5:27 AM
iBasic ?
Citus Basic - dunno, sounds a bit like Clitoris Basic.
#38 baktra OFFLINE
baktra
    Dragonstomper
  • 596 posts
Posted Sat Jul 1, 2017 8:23 AM
iBasic ?
iBasic - Is your budget big enough to beat a squadron of lawyers hired by Apple?
#39 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Sat Jul 1, 2017 9:26 AM
Screw 'em.  They don't have exclusive use of that letter as a prefix.  And the use of lower case e and i prefixes was a stupid fad that should have died with the dot-com boom/crash of the 90s.
#40 Bryan OFFLINE
Bryan
  • 10,926 posts
Posted Sat Jul 1, 2017 12:02 PM
iBasic ?
Clitoris Basic is really good if you can find it.
#41 devwebcl OFFLINE
devwebcl
  • 1,237 posts
Posted Sat Jul 1, 2017 12:36 PM
Veloz Basic
#42 miker OFFLINE
miker
  • 1,895 posts
  • Stay Atari!
Posted Sat Jul 1, 2017 1:00 PM
Maybe dBASIC (first letter of its author's nickname and inspired by neme of dBASE)? :)
#43 kenjennings OFFLINE
kenjennings
    Dragonstomper
  • 789 posts
  • Me + sio2pc-usb + 70 old floppies
Posted Mon Jul 3, 2017 6:12 PM
Duran Duran would have loved it.    :-)
#44 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Mon Jul 3, 2017 8:30 PM
dBasic is actually a Basic programming language product on the ST.  It was free to distribute but you had to buy the manual off them.
It doesn't seem to have made it to emulation as it uses a custom disk format with 9 x 1K sectors per track.
#45 ggn OFFLINE
ggn
  • 1,452 posts
Posted Mon Jul 3, 2017 11:48 PM
According to the author it wasn't exactly free...
(and btw yes I do intend to create this custom format at some point and then image it for emulators)
#46 Rybags OFFLINE
Rybags
    Gridrunner
  • 15,990 posts
Posted Tue Jul 4, 2017 12:10 AM
IMO it would have been a better product if it used the standard disk format and supported OS functions as well as having the command-line mode.
I wrote various programs using it and also found the assembler useful (as it was all I had).
I did my 1050 floppy emulator and also created a debugger for 6502 with 80x50 font which allowed me to transfer over large memory dumps to work on.  The aim was to try and crack AR:  Dungeon which I didn't do but was able to get a couple of stages worth through the encryption.
I don't have any of the disks remaining - gave them away when I sold the original 1040ST that I'd bought in the day.
#47 dmsc OFFLINE
dmsc
    Moonsweeper
  • 473 posts
Posted Tue Jul 4, 2017 10:54 PM
Hi!,
Another update of the interpreter, this time:
- Adds "ELIF" (else-if) statement, simplifies multiple choice:
IF a = 1
  ? "A is one"
ELIF a = 2
  ? "A is two"
ELIF a = 3
  ? "A is three"
ELSE
  ? "A is some other number"
ENDIF
- Adds "EXIT" from "PROC", this forces the return.
PROC Test
  IF x < 1
    Exit
  ENDIF
  x = 1234 / x
  ? "X = "; x
ENDPROC
- The interpreter is now a little smaller and faster thanks to parsing constants from 0 to 255 specially.
- The code is a little smaller now, at 6154 bytes.
Edited by dmsc, Tue Jul 4, 2017 10:54 PM.
#48 pirx OFFLINE
pirx
    Moonsweeper
  • 447 posts
Posted Wed Jul 5, 2017 5:51 AM
is saving parsed programs for quick execution possible?
would it be possible to make fb.com accept command line? would be much nicer than menu.
#49 vitoco OFFLINE
vitoco
    Moonsweeper
  • 320 posts
Posted Sun Jul 9, 2017 2:57 PM
I find very interesting that this version of BASIC has both the parser and the interpreter in the same module, As it has no editor, it just works like a compiler and a runtime... Hey, wait!!!! Why couldn't them be separated modules? A compiler/tokenizer and a linker/runtime. That could give extra RAM memory to the user program.   :grin:
Seriously, I was impressed to see that the parser was written for the 6502 processor and not for a current platform like DMSC's TBXL-Parser.
#50 Kyle22 OFFLINE
Kyle22
  • 3,817 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Sun Jul 9, 2017 3:40 PM
Any chance of a version that has been tweaked to take advantage of the 802/816?
Also tagged with one or more of these keywords: basic, compiler, interpreter
