RXB2015 on P-GRAM+ (finally)
5 replies to this topic
#1 aftyde OFFLINE
aftyde
    Chopper Commander
  • 238 posts
Posted Sun Jul 2, 2017 9:49 AM
Hi All,
If anyone wants RXB2015 for their P-GRAM+ just download the attached disk image.  Finally cracked the code.  Not being able to load it into the P-GRAM+ has been a nagging problem - recently, I made a RXB cart.  Was tinkering with the P-GRAM+ software and thought - hmmm... wonder if I can just dump the cart?
And it worked!   :)
Cheers, Arthur...
Edited by aftyde, Sun Jul 2, 2017 9:49 AM.
#2 RXB OFFLINE
RXB
  • 2,992 posts
Posted Mon Jul 3, 2017 4:25 AM
I give you the Source and PGRAM  files so do not understand why those do not work for yours?
It works fine for my TI99/4A with PGRAM?
#3 aftyde OFFLINE
aftyde
    Chopper Commander
  • 238 posts
Posted Mon Jul 3, 2017 6:23 AM
I remember, I think that was v5.55 which (even at the time) was a bit dated. If you have seven files I can load into mine for the latest version - I'd love to try it out.
#4 RXB OFFLINE
RXB
  • 2,992 posts
Posted Mon Jul 3, 2017 8:33 PM
RXB GRAM is the folder, I use Ti99Dir to convert them to TI only files and PC99 WRITE to send from PC to TI99/4A.
Edited by RXB, Mon Jul 3, 2017 8:33 PM.
#5 aftyde OFFLINE
aftyde
    Chopper Commander
  • 238 posts
Posted Tue Jul 4, 2017 9:07 PM
Hi Rich,
Gave it another go with markedly different results.  They just loaded!  Had to rename the files for the P-GRAM+ but it worked.  I'm wondering if the problems I was having before might be a result of the card hardware.  I recently fried the card, and Marc Hull was generous enough to take a look at it.  Other than some cooked voltage regulators / card support chips he noticed a non-standard part (some sort of memory chip) and replaced it with the one actually intended for the card.
Now the card did work before - mostly, as well as any other piece of 30 year old tech... :)
The RXB2015 version in the zip, is that the most recent?
I have noticed an interesting bug.  In RXB's EA - the [D]irectory function works well with DSK and WDS (except hard disk size is represented as an exponent), but not at all with HDX.  Seems true of the copy I have on the cart, the version I dumped from the cart to the PGRAM, and the version you just sent which I loaded directly into the PGRAM.
Still pretty awesome - my 8 year old son is learning to program in BASIC using RXB!  :)
Cheers, Arthur...
#6 RXB OFFLINE
RXB
  • 2,992 posts
Posted Wed Jul 5, 2017 8:36 AM
Hi Rich,
Cheers, Arthur...
Yea I need to fix this will make a note to fix it.
