DEBRO Posted July 5, 2017 Share Posted July 5, 2017 Hi there, I'd like to make a suggestion for an update to the BOUNDARY macro. The comments read to place data to a certain position inside a page however it doesn't work for me. As an example, I'm reverse engineering Barnstorming. There is a place in the code (i.e. $F3EF) where I need to push code 3 bytes into the next page. I send BOUNDARY 3 to the macro and it pushes to $F3F0 instead of $F403 because the mod of $F0 and 0 is 0. I'd like to define a constant for the filler byte as well. Currently this macro defaults to a filler byte of $00 but as I'm discovering with Barnstorming, you may want to define your filler byte differently. Barnstorming fills empty bytes with $EA. I'd also like to add a global variable (i.e FREE_BYTES) so it can be accumulated through out the assembly process. This will allow you to print out the free bytes remaining in the ROM or BANK (i.e. echo "***", (FREE_BYTES)d, "BYTES OF ROM FREE"). Below is my proposed update. Please let me know your thoughts. ;------------------------------------------------------- ; BOUNDARY byte# ; Original author: Dennis Debro (borrowed from Bob Smith / Thomas Jentzsch) ; ; Push data to a certain position inside a page and keep count of how ; many free bytes the programmer will have. ; ; eg: BOUNDARY 5 ; position at byte #5 in page IFNCONST BOUNDARY_FILL_BYTE BOUNDARY_FILL_BYTE = $00 ENDIF .FREE_BYTES SET 0 FREE_BYTES SET 0 .BYTES_TO_SKIP SET 0 MAC BOUNDARY IF <. > {1} .BYTES_TO_SKIP SET (256 - <.) + {1} ELSE .BYTES_TO_SKIP SET (256 - <.) - (256 - {1}) ENDIF REPEAT .BYTES_TO_SKIP .FREE_BYTES SET .FREE_BYTES + 1 FREE_BYTES SET FREE_BYTES + 1 .byte BOUNDARY_FILL_BYTE REPEND ENDM 1 Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted July 5, 2017 Share Posted July 5, 2017 If you want to define a fill parameter, I would prefer two versions of the macro, one with and one without boundary fill byte as parameter. Also we could incorporate my free space macros: ECHO_FREE SET 1 ; 1 = echo free space enabled FREE_TOTAL SET 0 ; use only once MAC OUT_FREE FREE_GAP$ SET - . {1} {2} FREE_GAP$ SET FREE_GAP$ + . FREE_BANK SET FREE_BANK + FREE_GAP$ ; has to be set to 0 for each bank FREE_TOTAL SET FREE_TOTAL + FREE_GAP$ IF ECHO_FREE && FREE_GAP$ > 0 ECHO "@", ., ": Gap:", [FREE_GAP$]d, "; Bank:", [FREE_BANK]d, "; Total:", [FREE_TOTAL]d, ";", {3}, {2}, {4} ENDIF ENDM MAC ALIGN_FREE_LBL LIST OFF OUT_FREE ALIGN, {1}, "ALIGN", {2} LIST ON ENDM MAC ALIGN_FREE LIST OFF ALIGN_FREE_LBL {1}, "" ENDM MAC COND_ALIGN_FREE_LBL ; space required, alignment, "label" LIST OFF IF (>(. + {1} - 1)) > (>.) ALIGN_FREE_LBL {2}, {3} ENDIF LIST ON ENDM MAC COND_ALIGN_FREE ; space required, alignment LIST OFF COND_ALIGN_FREE_LBL {1}, {2}, "" ENDM MAC RORG_FREE_LBL LIST OFF OUT_FREE RORG, {1}, "RORG", {2} LIST ON ENDM MAC RORG_FREE LIST OFF RORG_FREE_LBL {1}, "" ENDM Quote Link to comment Share on other sites More sharing options...
Kylearan Posted July 6, 2017 Share Posted July 6, 2017 Looking at that BOUNDARY macro makes you wish for an assembler/linker that takes care of code and data placement for you, observing such constraints as "align 256 offset PLAYER_HEIGHT" or "must not cross a page boundary but otherwise can be anywhere" or "this conditional branch must cross a page boundary", without having to fiddle around manually, doesn't it? (Almost there...) Quote Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted July 6, 2017 Share Posted July 6, 2017 See above: COND_ALIGN_FREE(_LBL) Quote Link to comment Share on other sites More sharing options...
DEBRO Posted August 19, 2017 Author Share Posted August 19, 2017 Not too much activity with this one. I guess I maybe the only one using the BOUNDARY macro. I like your suggestion of making another one and passing in the fill parameter. I got no response (though I hadn't followed up either) so I didn't place it in macro.h. Instead I'll just use it in the code I use. Quote Link to comment Share on other sites More sharing options...
