Kyle22 Posted July 6, 2017 Share Posted July 6, 2017 (edited) I have been looking for the DOS-XL disk for the Indus RAMCharger. I can't find it. Gooble was no help... One piece of advice, if you have RAM in your Indus, make sure there is a good insulator between the board and that drive mounting screw that sticks out. Mine (over time) developed an H0 error (Hardware). I folded a piece of heavy paper and put in between. Problem solved. Any and all versions of any Indus stuff would be appreciated. I want to tweak SuperSync again. Thanks in advance. Edit: Gooble was NOT a typo. Edited July 6, 2017 by Kyle22 5 Quote Link to comment Share on other sites More sharing options...
Faicuai Posted July 6, 2017 Share Posted July 6, 2017 I have been looking for the DOS-XL disk for the Indus RAMCharger. I can't find it. Gooble was no help... One piece of advice, if you have RAM in your Indus, make sure there is a good insulator between the board and that drive mounting screw that sticks out. Mine (over time) developed an H0 error (Hardware). I folded a piece of heavy paper and put in between. Problem solved. Any and all versions of any Indus stuff would be appreciated. I want to tweak SuperSync again. Thanks in advance. Edit: Gooble was NOT a typo. Dead-on advice (the insulation). Mine there, since the very first install (noticed the risk, right-away). I remember a ram-charger DOSXL disk (or files) that worked well, publically available... Not sure what the differences are with respect the .ATR you are looking for... It's always great to hear / read about IndusGT "perks".. 8-) 2 Quote Link to comment Share on other sites More sharing options...
Grover Torbel Posted July 6, 2017 Share Posted July 6, 2017 (edited) DOS XL images and lots of other cool stuff is available for download at: http://seriouscomputerist.atariverse.com/pages/dos/dos.other.htm Edited July 6, 2017 by Grover Torbel 1 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted July 6, 2017 Share Posted July 6, 2017 Dos XL 2.35.atr Nothing about the i2 part of name.. 1 Quote Link to comment Share on other sites More sharing options...
erichenneke Posted July 6, 2017 Share Posted July 6, 2017 I have been looking for the DOS-XL disk for the Indus RAMCharger. I can't find it. Gooble was no help... One piece of advice, if you have RAM in your Indus, make sure there is a good insulator between the board and that drive mounting screw that sticks out. Mine (over time) developed an H0 error (Hardware). I folded a piece of heavy paper and put in between. Problem solved. Any and all versions of any Indus stuff would be appreciated. I want to tweak SuperSync again. Thanks in advance. Edit: Gooble was NOT a typo. I just created this ATR directly from the original Indus GT System Master Diskette DOS XL that came with my drive. I don't think it has anything called RAMCharger though. -Eric IndusXL.ATR 1 Quote Link to comment Share on other sites More sharing options...
erichenneke Posted July 6, 2017 Share Posted July 6, 2017 While I was at it I made an ATR image off of the GT Estate Word Processor disk that came with the Indus GT drive also. Seems to all be intact and works fine. I also made an ATR image of the GT Albert E. Spread Sheet disk, but looks like this disk has issues. There were several read errors during the image copy and the ATR doesn't work. I went back and tried loading the actual physical source disk and it doesn't work either. Uploading it here anyway. -Eric GTWORD.ATR GTSPREAD.ATR 1 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted July 6, 2017 Share Posted July 6, 2017 Dos XL 2.35.atr Nothing about the i2 part of name.. Indus Master with Super Synchromesh.atr This one announces that it is 2.35i2 3 Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted July 6, 2017 Share Posted July 6, 2017 The complete disk is also posted here:http://atariage.com/forums/topic/104585-another-interesting-speed-comparison/?view=findpost&p=3759949 1 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted July 6, 2017 Share Posted July 6, 2017 Does the RAMCharger add track buffering? I added an ATR of my "OSS DOS XL - ATARI version 2.35I2" disk that I have (without a matching drive) in a previous thread where where I inspected the interesting SKEW on the real physical disk, and listed out all the different skews that the formatter utility written in BASIC will do. The physical disk uses a standard Atari 9:1 skew on tracks 0-3, and then a 4:1 skew on tracks 4-39. http://atariage.com/forums/topic/104585-another-interesting-speed-comparison/?p=3759949 2 Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted July 6, 2017 Share Posted July 6, 2017 The complete disk is also posted here:http://atariage.com/forums/topic/104585-another-interesting-speed-comparison/?view=findpost&p=3759949 You beat me to it! 2 Quote Link to comment Share on other sites More sharing options...
lemiel Posted July 6, 2017 Share Posted July 6, 2017 All vendor GTSync versions are here: http://www.atari.org.pl/forum/viewtopic.php?pid=144589#p144589 And one for Tygrys speeder: https://atarionline.pl/utils/6.%20Stacja%20dyskietek/Tygrys%20Turbo%20Utils/Tygrys%20Turbo%20Utils.atr 1 Quote Link to comment Share on other sites More sharing options...
Faicuai Posted July 6, 2017 Share Posted July 6, 2017 (edited) Fired-up my RAMcharger INDUS, with my own DOS disks, just curious about the actual DOS version, sizes, as well as content of the images posted here (which I took as samples). I immediately noticed the missing INITSYNC, RAM130 and other stuff (CMPTOOL) that actually come with these disks (not present on most of the links posted here)... There are two versions of Synchromesh ("Synchromesh" and "Super Synchromesh"). Track buffering seems to be enabled with the latter one, as you see a "bF" code on the Indus display, after loading and any regular operation. Most importantly, I also remembered the place where I got all my stuff... Look no further (it's all here and complete, as it should): http://trub.atari8.info/index.php?ref=cpm_en http://www.retrobits.net/atari/indus.shtml(extracted from above resource). Follow the links for a complete set of pretty much all images, as well as CP/M boot instructions, right from the drive. Cheers! Edited July 6, 2017 by Faicuai 1 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted July 6, 2017 Author Share Posted July 6, 2017 Thanks to everyone for their help. I'll check these out after work. Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted July 6, 2017 Author Share Posted July 6, 2017 All vendor GTSync versions are here: http://www.atari.org.pl/forum/viewtopic.php?pid=144589#p144589 And one for Tygrys speeder: https://atarionline.pl/utils/6.%20Stacja%20dyskietek/Tygrys%20Turbo%20Utils/Tygrys%20Turbo%20Utils.atr Is there anyone here who is a member on that site? I can't download it. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted July 6, 2017 Share Posted July 6, 2017 (edited) Found the register page by watching the hover URLs http://www.atari.org.pl/forum/register.php may have to revert to google translate if you get stuck after that second link there works without a login Edited July 6, 2017 by Nezgar 1 Quote Link to comment Share on other sites More sharing options...
lemiel Posted July 7, 2017 Share Posted July 7, 2017 From Atari Area. GTSYNC_ALL.ZIP 2 Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted July 7, 2017 Author Share Posted July 7, 2017 From Atari Area. Thanks. Those will be interesting to try out. Quote Link to comment Share on other sites More sharing options...
