Streaming Atari 2600
9 replies to this topic
#1 MoonlightKnight OFFLINE
MoonlightKnight
    Moonsweeper
  • 327 posts
Posted Fri Jul 7, 2017 12:32 PM
Hey guys, been a long time since I've been here, but I have a question I'm sure can be answered by this forum.
I was looking through the database and there are a few threads about streaming Atari to things like Twitch and now, Mixer, but I couldn't make heads or tails of what was being said in those threads.
I use Mixer, and I'd like to stream some of the old games to it directly from my old consoles. I've never been a fan of emulators because I find the games don't always play well when you use those.
I need a little help getting the signal to my computer. Here's the equipment I have so far:
An older Samsung TV with inputs from RCA all the way to HDMI.
An unmodified Atari
An Atari switch box with a COAX adapter
An Elgato HD60 capture device. This plugs into my computer via USB
XSplit streaming program.
So really, I need a way to hook the Atari to the TV so I can see the game, and then run the signal into my computer to capture it.
With what I have, what is the best way to get this accomplished, and what am I missing that I will need to add?
Thanks in advance for any and all advice.
#2 VectorGamer OFFLINE
VectorGamer
    Go Sleep In the Cold
  • 14,454 posts
  • \m/
Posted Fri Jul 7, 2017 12:38 PM
An unmodified Atari
Get a splitter and run coax to TV and USB
#3 up2knowgood OFFLINE
up2knowgood
    Chopper Commander
  • 241 posts
Posted Fri Jul 7, 2017 3:56 PM
And when you get it running, post link to said stream here so all of us can enjoy it. :)
#4 MoonlightKnight OFFLINE
MoonlightKnight
    Moonsweeper
  • 327 posts
Posted Sat Jul 15, 2017 7:25 AM
I may not have explained my situation correctly.
I have a switch box that will output to COAX. My TV will accept that, but it has to go through the Elgato before it gets to the TV. The Elgato only accepts HDMI input.
Do you know of a way to switch COAX to HDMI? If I have that, I think I can do it.
Even better if I can get a multitap with RCA inputs and a COAX output so I can have several systems on one box. As of yet, I haven't been able to find anything that would work.
#5 FireStar OFFLINE
FireStar
    Chopper Commander
  • 128 posts
  • also known as FireStarW elsewhere on the nets
Posted Sat Jul 15, 2017 9:05 AM
One major thing I'd suggest if you want to stream atari is use an av modded atari or a flashback 2, rf is just too prone to noise for it to give good video/audio.
With my vanilla atari 2600 hooked up to an s-vhs, I tried using it with my capture card with svideo, but the video and audio I got had tons of noise in it, I can imagine having a whole pc setup on near the atari adds to this.
I would recommend just getting a capture card with composite/s-video to go with this, converting composite to HDMI would be more expensive, and sd cap cards aren't very expensive, the elgato game capture HD is a good option, and theres even really cheap cards like the easycap that are ok options.
Perhaps an easier option for you would be a retron 77 when it comes out, but I do understand the appeal of streaming your own actual hardware.
Edit: also forgot to mention, getting a rca splitter is essential for streaming if the cap card you get does not have splitting built in, so you can plug both into your Card and your TV.
Personally I use this for composite/svideo: https://www.amazon.c...ck rca splitter
Edited by FireStar, Sat Jul 15, 2017 9:14 AM.
#6 MoonlightKnight OFFLINE
MoonlightKnight
    Moonsweeper
  • 327 posts
Posted Sat Jul 15, 2017 10:30 AM
Firestar, I assume you're suggesting something like this then?
https://www.ebay.com...n=ps&dispItem=1
#7 nanochess ONLINE
nanochess
    Processorus Polyglotus
  • 5,351 posts
  • Coding something good
Posted Sat Jul 15, 2017 10:51 AM
I think it would be better to record from LCD TV using a camera, because many Atari games have funny sync rates.
#8 maiki OFFLINE
maiki
    Dragonstomper
  • 689 posts
Posted Sat Jul 15, 2017 12:48 PM
A year ago I was recommended a cheap USB TV analogue tuner sold on Ebay over here and it works very well for capturing Atari 2600 games provided you use capable software like Virtual dub. There is no more noise than standard CRT TV if connected directly from console to USB even via splitter.
#9 VectorGamer OFFLINE
VectorGamer
  • 14,454 posts
  • \m/
Posted Mon Jul 17, 2017 7:48 AM
I was the one that made that recommendation. I have two of them and only paid $10 for them. I used the exact setup you have in the pic. For software I used Xsplit.
#10 MoonlightKnight OFFLINE
MoonlightKnight
    Moonsweeper
  • 327 posts
Posted Sat Jul 29, 2017 4:43 PM
Well guys, so far the best I've been able to manage is getting RCA inputs to my capture card. I haven't used my Atari 2600 or 7800 in so long, I'm not even sure they are working correctly since I can't seem to even get them working straight to my TV through COAX.
I'm still looking for a suitable converter, either from COAX to HDMI or a connector to RCA. I've purchased a mod kit from EBay for my 2600, we'll see how that goes.
Incidentally, if you guys are interested, the final product will be streamed live here: https://mixer.com/MoonLghtKnght
Eventually, anyway. My goal is to live stream retro games of all sorts. So far, there are very few who do that. I'm happy to fill the niche.
