Bypass the function keys
sio2sd fonction keys bypass xl
8 replies to this topic
#1 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Sun Jul 9, 2017 5:40 AM
Hi all,
I would like to put a SIO2SD inside 600XL that would be controlled by the aluminum function keys.
Is it possible to bypass the function keys to control the sio2sd by adding a pushbutton (N.O) on the 600XL which would be used as the "FN" key on the PC laptops?
I am not an electronics expert, if someone could help me ...
Edited by StaxX28, Sun Jul 9, 2017 5:44 AM.
#2 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Fri Jul 14, 2017 10:30 AM
I just finished the 600XL with SIO2SD+U1MB+Dual Pokey,
It's the first time I do "mod" like this, it was not easy for me
Not perfect but I'm satisfied :)
I'm still looking for the way to use the 600XL function keys with the SIO2SD...
#3 Stephen OFFLINE
Stephen
  • 7,590 posts
  • A8 Gear Head
Posted Fri Jul 14, 2017 10:56 AM
Cool mod.  Interesting idea of using the function keys for SIO2SD, but the machine will be unusable for almost every game in existence without Start, Select, and Option keys being properly wired.  Also, you'll never be able to disable built in BASIC without the Option key.
#4 flashjazzcat ONLINE
flashjazzcat
  • 14,498 posts
Posted Fri Jul 14, 2017 11:40 AM
You'd need some kind of five-contact switch on the console key lines which would cause the SIO2SD buttons to be pulled down in one position and the original console key lines to be pulled down in the other (normal) position. No doubt this could be done with a momentary switch and some IC and I'm sure someone cleverer than me could design a simple circuit for that, actuated by a little momentary switch you could position somewhere.
#5 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Fri Jul 14, 2017 3:20 PM
Stephen,
Yes i know,  that's why i need "FN Key" ;)
FJC,
Yes, that's exactly what I want to do without electronics skill ;p
So, I do some testing this afternoon...
On the keyboard connector, if I connect pins together 11, 19, 20, 21, 22, 23 , this disable de console key, but not sure if it's safe... I think no, i am wrong?
Thanks ;)
#6 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Tue Jul 18, 2017 11:00 AM
Well, in the meantime, I decided to do like this:
It was not easy to get everything inside  :P
Anyway, I'm still looking for...
#7 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Wed Jul 26, 2017 10:46 AM
Hi,
Just some updates on my 600XL:
added green, red and orange leds for SIO/SD activity and blue led for stereo enable...
And now, my desktop... ready to fly !  :-D
#8 Stephen OFFLINE
Stephen
  • 7,590 posts
  • A8 Gear Head
Posted Wed Jul 26, 2017 11:04 AM
Awesome mods!  How did you "stencil" the lettering on the plastic cover (for stereo, sio, etc.)?
#9 StaxX28 OFFLINE
StaxX28
    Chopper Commander
  • 203 posts
Posted Wed Jul 26, 2017 1:50 PM
With Photoshop, SF Atarian font, printed on photo paper ;)
Here is the psd file:
Attached File  Leds&Texts.zip   240.1KB   43 downloads
SF Atarian Font
Edited by StaxX28, Wed Jul 26, 2017 1:51 PM.
Also tagged with one or more of these keywords: sio2sd, fonction keys, bypass, xl
