call load without 32k?
20 replies to this topic
#1 notwhoyouthink OFFLINE
notwhoyouthink
    Chopper Commander
  • 124 posts
Posted Tue Jul 11, 2017 4:46 PM
I know for a fact that assembly can be directly loaded and executed by the console, see the game morphy's special loader program from cassette.
(using a fake header on cs1)
That said, would it be possible to use that technique to inject a program to mimic call load in extended basic?
Or at least trick extended basic into thinking a call init had been done, without having a 32k memory attached?
Edited by notwhoyouthink, Tue Jul 11, 2017 4:58 PM.
#2 RXB OFFLINE
RXB
  • 3,021 posts
Posted Tue Jul 11, 2017 5:46 PM
No XB has a MAJOR BUG using CALL LOAD requires CALL INIT to be used first.
RXB fixed this XB bug in 2001 and with RXB you can use CALL LOAD without the need for CALL INIT first.
You can see the XB CALL INIT bug in RXB source code where I commented out that sections.
Edited by RXB, Tue Jul 11, 2017 5:46 PM.
#3 Tursi ONLINE
Tursi
  • 5,058 posts
  • HarmlessLion
Posted Tue Jul 11, 2017 11:14 PM
Morphy was a cool trick, but the Playground technique by Senior Falcon really broke the console wide open for TI BASIC, since it doesn't require any additional loads and works from disk, tape, or what-have-you. It's based on a buffer overflow in the OPEN command, it's not inconceivable that the same bug exists in XB...? I don't remember if anyone tried it.
But what would you gain? Once you're running assembly code, does it matter if you launched it from BASIC or XB?
#4 apersson850 OFFLINE
apersson850
    Moonsweeper
  • 489 posts
Posted Wed Jul 12, 2017 11:27 AM
The fact that you can't do CALL LOAD in Extended BASIC without first doing CALL INIT isn't a bug. It's by design. CALL LOAD calls the assembly program loader, designed to load assembly programs into expansion memory, and to do the bookkeeping of the loading using data structures set up by CALL INIT. Thus it's pointless without the memory expansion.
The different fact that CALL LOAD can be used as what's normally called POKE as well, that's also by design. That you in fact can't do a POKE without having the memory expansion, now that's a limitation, of course. Not a very big one, since most of what you POKE without the memory expansion will destroy Extended BASIC anyway, but yes, it's a limitation. But it's still by design, so it's not a bug.
#5 RXB OFFLINE
RXB
  • 3,021 posts
Posted Wed Jul 12, 2017 12:34 PM
LOL WRONG! It is stupid bug.
Why would you restrict a CALL LOAD from working if you are not using CALL LOAD(FILE)?????
You can do CALL LOAD to SCRATCH RAM all the time to do many things, why do you need a 32K for that??????
There is a whole list of them to do.....
Edited by RXB, Wed Jul 12, 2017 12:35 PM.
#6 arcadeshopper ONLINE
arcadeshopper
  • 3,291 posts
Posted Wed Jul 12, 2017 1:56 PM
ok well its a feature that you disagree with how's that?
In the meantime.. someone want to try the overflow exploit in xb?
Greg
#7 RXB OFFLINE
RXB
  • 3,021 posts
Posted Wed Jul 12, 2017 2:01 PM
Greg
Show me other computers that do this stupid move?
Every other Basic or Language does not restrict you to ONLY LOADING FILES with CALL LOAD or CALL POKE in this case.
#8 chue OFFLINE
chue
    Chopper Commander
  • 210 posts
Posted Wed Jul 12, 2017 2:15 PM
I just tried the exploit in XB (Triton SXB and TI XB) and it also works there.
#9 apersson850 OFFLINE
apersson850
    Moonsweeper
  • 489 posts
Posted Wed Jul 12, 2017 2:19 PM
Since you seem not to know what a "bug" is, I can inform you about that it's something that doesn't work as intended. Thus this is not a bug. It's as intended, by design. TI choose to provide the Extended BASIC with a more advanced version than then ordinary POKE, and gave us a tagged object code loader, which also can poke values into RAM. Since the main purpose is to work as an object code loader, it works without any bugs I've heard about. They also made a more advanced way to call assembly routines, by name via the CALL LINK statement, instead of just some version of EXEC at a memory location, which otherwise was common on contemporary computers.
Then if there should be a POKE, specifically to do just that, that's something else. It was available on other computers, but I've not seen any other computer of the same style which didn't have any CPU RAM (except for the 256 bytes). So it's much more meaningful on other machines.
Edited by apersson850, Wed Jul 12, 2017 2:20 PM.
#10 notwhoyouthink OFFLINE
notwhoyouthink
    Chopper Commander
  • 124 posts
Posted Wed Jul 12, 2017 2:45 PM
Have not got my Extended basic in the mail yet, but by overflow exploit, do you mean the trick morphy uses?
Or like the loader for playground?
Or something else?
And does it work with out 32k?
Edited by notwhoyouthink, Wed Jul 12, 2017 2:46 PM.
#11 chue OFFLINE
chue
    Chopper Commander
  • 210 posts
Posted Wed Jul 12, 2017 2:53 PM
This is the buffer overflow exploit that Tursi talks about above.  It works in BASIC, as well as XB.  I forget where I got the code from (probably somewhere on this site).
Edit: here's the original post: http://atariage.com/...994a/?p=2849894
Anyways, here is the code - It is a TI BASIC program that calls an assembly language routine that moves the words "hello world" across the screen:
Spoiler
Edited by chue, Wed Jul 12, 2017 2:56 PM.
#12 Opry99er OFFLINE
Opry99er
  • 9,524 posts
Posted Wed Jul 12, 2017 4:20 PM
Sooooooooo slick....
#13 RXB OFFLINE
RXB
  • 3,021 posts
Posted Wed Jul 12, 2017 5:53 PM
TI XB uses CALL LOAD as a CALL POKE, trouble is I know the source one hell of lot better than you do.
It was a mistake, bug, stupid oversight or whatever you want to call it.
Who in right mind would make a CALL POKE that will not work unless you have Expanded memory?  Why?
As I know the GPL source inside out for over 20 years I think I know a bug when I see one.
This is why when using just console and RXB you can use the CALL LOAD routines that everyone is fond of to do things:
 8192  , P        USE (PEEK,P) IF P<> 70 OR <>121 THEN DO A CALL INIT
  8194  ,           FIRST FREE ADDRESS IN LOW MEMORY
  8196  ,           LAST FREE ADDRESS IN LOW MEMORY
 -28672 , P       P=0 SPEECH NOT ATTACHED  P=96 OR P=255 SPEECH IS ATTACHED
 -31572 , 0 TO 255  VARY KEYBOARD RESPONSE
 -31740 , P , Q     PUT IN DIFFERENT TO CHANGE BEEPS,WARNINGS, ETC
 -31744 , 0 TO 15   CONTINUATION OF LAST SOUND (0=LOUD AND 15=SOFT)
 -31748 , 0 TO 255  CHANGE THE CURSOR FLASHING AND RESPONSE TONE RATES
 -31788 , 160     BLANK OUT THE SCREEN (MUST PUSH A KEY TO ACTIVATE)
        , 192          NO AUTOMATIC SPRITE MOTION OR SOUND
        , 224          NORMAL OPERATION
        , 225          MAGNIFIED SPRITES
        , 226          DOUBLE SIZE SPRITES
        , 227          MAGNIFIED & DOUBLE SIZED SPRITES
        , 232          MULTICOLOR MODE (48 BY 64 SQUARES)
 -31794 , P        TIMER FOR CALL SOUND (COUNTS FROM 255 TO 0)
 -31804 , X , Y   RETURN TO THE TITLE SCREEN (USE "PEEK (2,X,Y)")
        , P             CHANGE THE CURSOR FLASH RATE (0 TO 255)
 -31806 , 0         NORMAL OPERATION
        , 16            DISABLE QUIT KEY (FCTN =)
        , 32            DISABLE SOUND (USE NEG DUR FOR CONTINOUS SOUND)
        , 48            DISABLE SOUND & QUIT KEY
        , 64            DISABLE AUTO SPRITE MOTION
        , 80            DISABLE SPRITES & QUIT KEY
        , 96            DISABLE SPRITES AND SOUND
        , 128          DISABLE ALL THREE
 -31808 , P , Q   DOUBLE RANDOM NUMBERS (0 TO 255) NEED "RANDOMIZE"
 -31860 , 4         GO FROM EX-BASIC TO CONSOLE BASIC (NEED "NEW")
        , 8              AUTO RUN OF DSK1.LOAD
 -31866 , P , Q   END OF CPU PROGRAM ADDRESS (P*256+Q)
 -31868 , 0         NO "RUN" OR "LIST" AFTER "BREAK" IS USED
        , 0 , 0         TURNS OFF THE 32K MEMORY EXPANSION
        , 255 , 231 TURNS ON THE 32K MEMORY EXPANSION
 -31873 , 3 TO 30   SCREEN COLUMN TO START AT WITH A "PRINT"
 -31877 , P         P&32 = SPRITE COINCIDENCE  P&64 = 5 SPRITES ON A LINE
 -31878 , P         HIGHEST NUMBER SPRITE IN MOTION (0 STOPS ALL)
 -31879 , P         TIMER FOR VDP INTERRUPTS EVERY 1/60 OF A SEC (0 TOP 255)
 -31880 , P         RANDOM NUMBER (0 TO 99) NEED "RANDOMIZE"
 -31884 , 0 TO 5    CHANGE KEYBOARD MODE (LIKE "CALL KEY(K,...)")
 -31888 , 63 , 255  DISABLE ALL DISK DRIVES (USE "NEW" TO FREE MEMORY)
        , 55 , 215      ENABLE ALL DISK DRIVES (USE "NEW" TO FREE DRIVES)
 -31931 , 0            UNPROTECT X-B PROTECTION
        , 2                SET "ON WARNING NEXT" COMMAND
        , 4                SET "ON WARNING STOP" COMMAND
        , 14              SET "UNTRACE" COMMAND
        , 15              SET "UNTRACE" COMMAND & "NUM" COMMAND
        , 16              SET "TRACE" COMMAND
        , 64              SET "ON BREAK NEXT" COMMAND
        , 128            PROTECT X/B PROGRAM
 -31952 , P          PEEK  P=55 THEN 32K EXPANSION MEMORY IS OFF <>55 MEANS ON
 -31962 , 32        RETURN TO THE TITLE SCREEN
        , 255           RESTART X/B W/DSK1.LOAD
 -31974 , P , Q    END OF VDP STACK ADDRESS (P*256+Q)
 -32112 , 8         SEARCHES DISK FOR ?
 -32114 , 2         RANDOM GARBAGE
        , 13            SCREEN GOES WILD
        , 119          PRODUCE LINES
 -32116 , 2         RANDOM CHARACTERS ON SCREEN
        , 4             GO FROM X/BASIC TO BASIC
 -32187 , 0        UNPROTECT XB PROGRAM
        , 9             SET 0 LINE NUMBER
        , 128         PROTECT XB PROGRAM
 -32188 , 1        CHANGE COLOR AND RECEIVE SYNTAX ERROR
        , 127         CHANGE COLOR AND RECEIVE BREAKPOINT
 -32630 , 128    RESET TO TITLE SCREEN
 -32699 , 0        UNPROTECT XB PROGRAM
        , 15           SET "UNTRACE" & "NUM" COMMAND
 -32700 , 0       CLEARS CREEN FOR AN INSTANT
 -32729 , 0       RUN "DSK1.LOAD"
 -32730 , 32     RESET TO TITLE SCREEN
 -32961 , 51     RESET TO TITLE SCREEN
        , 149        SETS "ON BREAK GOTO" LOCKS SYSTEM
#14 mizapf OFFLINE
mizapf
  • 3,201 posts
Posted Wed Jul 12, 2017 6:01 PM
The fact that you can make some good use of CALL LOAD does not imply that Texas Instruments had any intention that you actually do that. I suppose that TI indeed tried to hide those features under higher-layer functions.
#15 RXB OFFLINE
RXB
  • 3,021 posts
Posted Wed Jul 12, 2017 11:29 PM
GPL code from TI XB source:
[0004]                      GROM >C000
[0005]               ***********************************************************
[0006]                      TITL 'EQUATES ALCS-359'
[0007]               ***********************************************************
[0008] 2002          FSLOC  EQU  >2002             Free Start LOCation in ERAM
[0009]               *                             Free end must follow it.
[0010] 2006          INITF  EQU  >2006             INIT flag address INIT has be
[0011]               *                             called if ERAM (INITF)=>AA55
[0012]               * Free end initialized to >4000, (>FFF8 for debugger)
[0013]               * Free start is initialized to the first useable memory
[0014]               *  location for assembly language code
[0015] A040          CPUBAS EQU  >A040             Expansion RAM base
[0016]               **********************************************************
After some EQUats:
[0664]               ***********************************************************
[0665]               * ASSEMBLY LANGUAGE SUPPORT FOR 99/4
[0666]               *
[0667]               * LOAD, INIT, PEEK, LINK, CHARPAT      JDH  08/21/80
[0668]               ***********************************************************
[0669]               * FORMAT FOR LOAD:
[0670]               *  CALL LOAD open load-directive (comma load-directive)
[0671]               *            close
[0672]               *    load-directive = file-name / address (comma data)
[0673]               *                     (null / file-name)
[0674]               *    file-name      = string-expression
[0675]               *    address        = numeric-expression
[0676]               *    data           = numeric-expression
[0677]               *
[0678]               *  FILE TYPE = FIXED 80, DISPLAY , SEQUENTIAL FILE
[0679]               *
[0680]               * FUNCTION:
[0681]               *  LOADS ASSEMBLY LANGUAGE CODE INTO EXPANSION RAM
[0682]               *  ADDRESSES: >2000 - >>3FFF RELOCATING
[0683]               *  RELOCATABLE CODE INTO AVAILABLE MEMORY, ABSOLUTE CODE
[0684]               *  IS LOADED
[0685]               *  INTO ITS ABSOLUTE ADDRESS, ENTRY POINTS ARE DEFINED BY
[0686]               *  'DEF' STATEMENTS, AND ARE LOADED INTO HIGH END OF ERAM
[0687]               *
[0688]               *  RELOACATABLE OR ABSOLUTE CODE MAY BE STORED ON A FILE
[0689]               *  9900 OBJECT CODE FORMAT.
[0690]               *   VALID TAGS = 0, 5, 6, 7, 9, A, B, C, F,:
[0691]               *         TAGS 1, 2, I, M, ARE IGNORED
[0692]               *  THE SYMT OPTION IS NOT SUPPORTED.
[0693]               *  ABSOLUTE CODE MAY BE LOADED DIRECTLY FROM PROGRAM
[0694]               *  BY SPECIFYING AN ADDRESS INSTEAD OF A FILE NAME,
[0695]               *  FOLLOWED BY THE DATA TO BE LOADED (WHICH IS PUT IN THE
[0696]               *   RANGE 0 to 255
[0697]               *  THE RANGE OF THE ADDRESS OR DATA IS LIMITED TO
[0698]               *   32767 to -32768
[0699]               *  MULTIPLE DIRECT LOADS CAN BE IN THE SAME LOAD COMMAND
[0700]               *  PROVIDED THEY ARE SEPARATED BY EITHER A FILENAME OR A
[0701]               *   NULL STRING.
[0702]               *
[0703]               *  MVUP WAS USED TO TRANSFER DATA FROM CPU RAM TO ERAM
[0704]               *  SINCE IT WAS NOT KNOWN AT FIRST THAT THE MOVE
[0705]               *  INSTRUCTION COULD TRANSFER FROM CPU RAM TO ERAM
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0012
EQUATES ALCS-359
[0706]               *   (PROVIDED THAT >8300 IS SUBTRACTED FROM THE ADDRESSES)
[0707]               ***********************************************************
Please note the last few lines in these comments about the GPL MOVE instruction was not known by the Assembly programming team.
Now for the GRAMKRACKER fixing what I call bugs in XB and then my futher fixing the bug of CALL INIT before you can use any CALL LOAD:
0731]               * LOAD - LDP1 - LDP4 - LDP5
[0732]               ** CHKSUM is also used as a flag to test if a file has been
[0733]               ** opened (so that it gets closed)
[0734]               ** it is initialized to >0001 and will be changed to some
[0735]               ** other value if a file is used
[0736] C040 BF,02,00 LOAD   DST  >0001,@CHKSUM     {INITIALIZE FILE FLAG}
       C043 01
[0737]               * GKXB Change load routine. Delete check for INIT
[0738]               *      add to clear flag bits.
[0739] C044 06,C6,14        CALL GKLOAD
[0740] C047 D6,42,B7 GC047  CEQ  LPARZ,@CHAT       SYNTAX ERROR if no "("
[0741] C04A 45,30           BR   ERRSY1
[0742] C04C 0F,79           XML  PGMCHR            Skip over
[0743]               * MAIN PARESE LOOP *
[0744]               * Check for file-name or address
[0745] C04E 0F,74    LDP1   XML  PARSE
[0746] C050 B6              BYTE RPARZ           * PARSE up to ")" or ","
[0747] C051 D6,4C,65        CEQ  STRING,@FAC2      Process file name
[0748] C054 60,90           BS   LDP2
[0749]               * Otherwise it is an address
[0750]               * Convert address to integer, save in @PC
[0751] C056 0F,12           XML  CFI               Convert FAC to integer
[0752] C058 D6,54,03        CEQ  3,@FAC10          Check for overflow
[0753] C05B 65,29           BS   ERRN01
[0754] C05D BD,04,4A        DST  @FAC,@PC          Save in ERAM location pointer
[0755]               * Check for "," if there then data should folow
[0756]               *  else end of load statement, goto LDP5
[0757] C060 D6,42,B3 LDP4   CEQ  COMMAZ,@CHAT
[0758] C063 40,88           BR   LDP5
[0759]               * DATA follows or a STRING if no more data
[0760] C065 0F,79           XML  PGMCHR            Skip ","
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0013
EQUATES ALCS-359
[0761] C067 0F,74           XML  PARSE             Get data value or string if
[0762]               *                              end of data
[0763] C069 B6              BYTE RPARZ           * Parse up to ")" or ","
[0764] C06A D6,4C,65        CEQ  STRING,@FAC2      No more data
[0765] C06D 60,90           BS   LDP2
[0766]               * FAC contains a numeric
[0767] C06F 0F,12           XML  CFI               FAC to INTEGER
[0768] C071 D6,54,03        CEQ  3,@FAC10          Check for overflow
[0769] C074 65,29           BS   ERRN01
[0770]               * GKXB Code for CPU write moved to LOADDT. Add code to
[0771]               *      check VDP or GRAM bits and write to VDP.
[0772] C076 DA,80,C2        CLOG >08,@GKFLAG       Check VDP bit
       C079 08
[0773] C07A 66,8A           BS   LDGRAM            No, check GRAM bit
[0774] C07C BC,B0,04        ST   @FAC1,V*PC        Yes, write to VDP
       C07F 4B
[0775] C080 91,04           DINC @PC               Point to next byte
[0776] C082 05,C0,60        B    LDP4              Continue with LOAD routine
[0777]               * RXB PATCH FILL EMPTY SPACE *****************************
[0778] C085 05,C0,60        B    LDP4
[0779]               * GROM ADDRESS >C088 FOR LDP5
[0780]               * Check for ")"  IF there return ELSE SYNTAX ERROR
[0781] C088 D6,42,B6 LDP5   CEQ  RPARZ,@CHAT       Return
[0782] C08B 61,E1           BS   LDRET
[0783] C08D 05,C5,30        B    ERRSY1            SYNTAX ERROR
[0784]               * LDP2
[0785]               * Process file name
[0786] C090 8E,51    LDP2   CZ   @FAC7             Check for null string
[0787] C092 61,D2           BS   LDNE2
[0788]               * GKXB Change 'LOAD FILE' to check for INIT
[0789] C094 06,C6,2D        CALL GKINIT
[0790]               *************** LOAD DATA INTO ERAM ***********************
[0791]               * LOAD FRESTA, FREEND from ERAM
[0792] C097 BF,16,20        DST  FSLOC,@VARB           Source
       C09A 02
[0793] C09B BF,00,83        DST  FRESTA,@VAR0          Destination
       C09E 08
[0794] C09F BF,5C,00        DST  4,@ARG                # of bytes to move
       C0A2 04
[0795] C0A3 0F,89           XML  MVUP                  Load
[0796]               * Initialize PC, OFFSET in case of no "0" tag
[0797] C0A5 BD,04,08        DST  @FRESTA,@PC
[0798] C0A8 BD,06,08        DST  @FRESTA,@OFFADD   Base address for load module
[0799]               * Read in one record, evaluate the TAG field
[0800]               * LDRD - LDTG
[0801] C0AB BF,02,00 LDRD   DST  0,@CHKSUM         Clear check sum
       C0AE 00
[0802] C0AF 06,C2,63        CALL READIT            Rear in a record
[0803] C0B2 35,00,05 LDTG   MOVE 5,V*BUFPNT,@TAG   Get TAG & field
       C0B5 10,B0,0E
[0804] C0B8 06,C2,00        CALL LDIPCS            Add 5 to BUFPNT, add ASCII
[0805] C0BB 05              BYTE 5               * Value of chars. Read to check
[0806]               * Convert @FIELD to numeric (from ASCII hex value)
[0807]               * Store result: HIGH BYTE to FIELD, LOW BYTE to FIELD+1
[0808]               * Convert HIGH BYTE first: @FIELD & @FIELD+1
[0809]               * Store result in field
[0810] C0BC A6,11,30        SUB  >30,@FIELD        >30 = "0"
[0811] C0BF CE,11,09        CGT  9,@FIELD          Subtract ASCII difference
[0812]               *                              between "9" and "A"
[0813] C0C2 40,C7           BR   GC0C7
[0814] C0C4 A6,11,07        SUB  7,@FIELD
[0815] C0C7 E2,11,04 GC0C7  SLL  4,@FIELD          FIELD=FILED*32
[0816] C0CA A6,12,30        SUB  >30,@FIELD+1
[0817] C0CD CE,12,09        CGT  9,@FIELD+1
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0014
EQUATES ALCS-359
[0818] C0D0 40,D5           BR   GC0D5
[0819] C0D2 A6,12,07        SUB  7,@FIELD+1
[0820] C0D5 A0,11,12 GC0D5  ADD  @FIELD+1,@FIELD   Add to HIGH BYTE
[0821]               * Now convert LOW BYTE: @FIELD+2 & @FIELD+3
[0822]               * Store result in LOW BYTE of FIELD to FIELD+1
[0823] C0D8 A6,13,30        SUB  >30,@FIELD+2
[0824] C0DB CE,13,09        CGT  9,@FIELD+2
[0825] C0DE 40,E3           BR   GC0E3
[0826] C0E0 A6,13,07        SUB  7,@FIELD+2
[0827] C0E3 BC,12,13 GC0E3  ST   @FIELD+2,@FIELD+1 Store in LOW byte of result
[0828] C0E6 E2,12,04        SLL  4,@FIELD+1        FIELD+1 = FIELD+1*32
[0829] C0E9 A6,14,30        SUB  >30,@FIELD+3
[0830] C0EC CE,14,09        CGT  9,@FIELD+3
[0831] C0EF 40,F4           BR   GC0F4
[0832] C0F1 A6,14,07        SUB  7,@FIELD+3
[0833] C0F4 A0,12,14 GC0F4  ADD  @FIELD+3,@FIELD+1 Add to low byte
[0834]               * Branch to evaluation procedure for TAG
[0835] C0F7 A6,10,30        SUB  >30,@TAG          >30 = "0"
[0836] C0FA D2,10,00        CGE  0,@TAG            If TAG < "0" ILLEGAL CHAR
[0837] C0FD 45,C5           BR   ERRUC1
[0838] C0FF CE,10,0A        CGT  >0A,@TAG          TAGS "0" to ":"
[0839] C102 61,1C           BS   GC11C
[0840] C104 8A,10           CASE @TAG
[0841] C106 41,48           BR   TAG0              "0" RELOCATABLE LENGTH
[0842] C108 40,B2           BR   LDTG              IGNORE "1" TAG
[0843] C10A 40,B2           BR   LDTG              IGNORE "2" TAG
[0844] C10C 45,C5           BR   ERRUC1            No external REF "3"
[0845] C10E 45,C5           BR   ERRUC1            No external REF "4"
[0846] C110 41,5D           BR   TAG5              "5" relocatable entry DEF
[0847] C112 41,60           BR   TAG6              "6" Absolute entry    DEF
[0848] C114 41,92           BR   TAG7              "7" check sum
[0849] C116 40,B2           BR   LDTG              "8" ignore check sum
[0850] C118 41,9F           BR   TAG9              "9" Absolute LOAD address
[0851] C11A 41,BA           BR   LDDNE             ":" end of file
[0852] C11C A6,10,11 GC11C  SUB  >11,@TAG          Subtract offset so
[0853]               *                              that "A" is =0
[0854] C11F D2,10,00        CGE  0,@TAG            ";" to "@" illegal char
[0855] C122 45,C5           BR   ERRUC1
[0856]               * Skip over "I" tag - 8 char, program ID that follows
[0857] C124 D6,10,08        CEQ  8,@TAG
[0858] C127 61,56           BS   LDTG2
[0859]               * Skip over "M" TAG -10 char, program ID that follows
[0860] C129 D6,10,0C        CEQ  12,@TAG
[0861] C12C 41,35           BR   LDTG3
[0862] C12E 06,C2,00        CALL LDIPCS
[0863] C131 0A              BYTE 10
[0864] C132 05,C0,B2        B    LDTG
[0865] C135 CE,10,05 LDTG3  CGT  5,@TAG            TAGS "G" are legal
[0866] C138 65,C5           BS   ERRUC1
[0867] C13A 8A,10           CASE @TAG
[0868] C13C 41,9C           BR   TAGA              "A" RELOCATABLE PROGRAM ADDRE
[0869] C13E 41,A8           BR   TAGB              "B" ABSOLUTE VALUE
[0870] C140 41,A5           BR   TAGC              "C" RELATIVE ADDRESS
[0871] C142 45,C5           BR   ERRUC1            "D" ERROR
[0872] C144 45,C5           BR   ERRUC1            "E" ERROR - UNDEFINED
[0873] C146 40,AB           BR   LDRD              "F" END OF RECORD
[0874]               * TAG0 to TAGB
[0875]               * EVALUATE TAG FIELDS
[0876] C148 BD,06,08 TAG0   DST  @FRESTA,@OFFADD   NEW BASE ADDRESS
[0877] C14B BD,04,08        DST  @FRESTA,@PC       NEW PC
[0878] C14E A1,08,11        DADD @FIELD,@FRESTA    ADD LENGTH TO FIND END OF
[0879]               *                              RELOCATABLE PROGRAM WHICH IS
[0880]               *                              START OF NEXT PROGRAM
[0881]               * Make sure we won't run into routine name table now, so we
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0015
EQUATES ALCS-359
[0882]               *  don't have to check every time we load a value into ERAM
[0883]               *  routine table must make sure it doesn't run into
[0884]               *  relocatable assembly language code through.
[0885] C151 C9,08,0A        DCHE @FREEND,@FRESTA   OUT OF MEMORY
[0886] C154 65,53           BS   ERRMF1
[0887]               * SKIP OVER PROGRAM ID - 8 BYTES
[0888] C156 06,C2,00 LDTG2  CALL LDIPCS
[0889] C159 08              BYTE 8               * INC BUFPNT, COMPUTE CHECKSUM
[0890] C15A 05,C0,B2        B    LDTG
[0891] C15D A1,11,06 TAG5   DADD @OFFADD,@FIELD    Add starting offset
[0892]               * TAG6 is an absolute address so do not need to add offset
[0893] C160 35,00,06 TAG6   MOVE 6,V*BUFPNT,@INDEX    Get symbol name
       C163 5E,B0,0E
[0894] C166 06,C2,00        CALL LDIPCS            INC BUPNT, COMPUT CHECKSUM
[0895] C169 06              BYTE 6              *  We read 6 chars
[0896]               * Add symbol and its address - stopped in field - to the
[0897]               *  routine entry table. It is put at the end of the table
[0898]               *  (the end of the table is towards the low end of memory)
[0899]               *  Since the table is searched from the end first, if there
[0900]               *  are any duplicate labels the last one entered will have
[0901]               *  precedence over the early one(s).
[0902] C16A 97,0A           DDECT @FREEND          Set to address field
[0903]               * Load address (stored in field in CPU RAM) into routine
[0904]               *  Name table which is in expansion RAM
[0905] C16C BF,16,83        DST  FIELD,@VARB        Source
       C16F 11
[0906] C170 BD,00,0A        DST  @FREEND,@VAR0      Destination
[0907] C173 BF,5C,00        DST  2,@ARG             # bytes to move
       C176 02
[0908] C177 0F,89           XML  MVUP              CPUR RAM to ERAM
[0909]               * Load symbol into routine name table
[0910] C179 A7,0A,00        DSUB 6,@FREEND         Set to symbol field
       C17C 06
[0911] C17D BF,16,83        DST  INDEX,@VARB         Source
       C180 5E
[0912] C181 BD,00,0A        DST  @FREEND,@VAR0       Destination
[0913] C184 BF,5C,00        DST  6,@ARG              Move 6 bytes
       C187 06
[0914] C188 0F,89           XML  MVUP              CPU RAM to ERAM
[0915]               * Check to see if we've run into assembly language code
[0916] C18A C9,08,0A        DCHE @FREEND,@FRESTA   Out of memory
[0917] C18D 65,53           BS   ERRMF1
[0918] C18F 05,C0,B2        B    LDTG              If not then continue
[0919]               ***********************************************************
[0920]               * ROUTINE NAME TABLE ENTRY
[0921]               *
[0922]               *                     0   1   2   3   4   5   6  7
[0923]               *                   -----------------------------------
[0924]               *        FREEND     | S | Y | M | B | O | L | ADDRESS |
[0925]               *    (AFTER ENTRY)  -----------------------------------
[0926]               *        FREEND     |   |   |   |   |   |   |         |
[0927]               *    (BEFORE ENTRY) -----------------------------------
[0928]               *
[0929]               *  FREEND is initialized to >4000 by INIT, address is at
[0930]               *   a higher memory location then symbol
[0931]               ***********************************************************
[0932] C192 83,11    TAG7   DNEG @FIELD            Checksum is 1's compelement
[0933] C194 D5,02,11        DCEQ @FIELD,@CHKSUM    Check sum error
[0934] C197 45,AE           BR   ERRDE1
[0935] C199 05,C0,B2        B    LDTG
[0936] C19C A1,11,06 TAGA   DADD @OFFADD,@FIELD    PC = OFFADD ^ FIELD
[0937]               * TAG 9 is an absolute address so no need to add offset
[0938] C19F BD,04,11 TAG9   DST  @FIELD,@PC
[0939] C1A2 05,C0,B2        B    LDTG
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0016
EQUATES ALCS-359
[0940] C1A5 A1,11,06 TAGC   DADD @OFFADD,@FIELD
[0941]               * TAG B is an absolute entry so no need to add offset
[0942]               * Relocatable code is checked to see if it will run into
[0943]               *  is no need to check now. Absolute code can go anywhere.
[0944]               *
[0945]               * Load field into expansion RAM using MVUP routine
[0946] C1A8 BD,00,04 TAGB   DST  @PC,@VAR0           Destination
[0947] C1AB BF,16,83        DST  FIELD,@VARB         Source
       C1AE 11
[0948] C1AF BF,5C,00        DST  2,@ARG              Move 2 bytes
       C1B2 02
[0949] C1B3 0F,89           XML  MVUP              CPU RAM to ERAM
[0950] C1B5 95,04           DINCT @PC              We loaded 2 bytes
[0951] C1B7 05,C0,B2        B    LDTG
[0952]               ********* END OF LOAD FOR CURRENT FILE ********************
[0953]               *
[0954]               * FRESTA & FREEND are stored in CPU RAM (>8308)
[0955]               * While loading a file into expansion RAM.
[0956]               * So if the values of FRESTA or FREEND are to be changed
[0957]               * then word locations >8308 and >830A must be changed and
[0958]               * not expansion RAM.
[0959]               *
[0960]               * LDDNE - LDNE2
[0961]               *
[0962]               *   DONE WITH LOAD
[0963]               * Put FRESTA, FREEND back into expansion RAM
[0964]               * If FRESTA is odd then make it even
[0965]               *  so that the next program starts on an even boundry
[0966] C1BA DA,09,01 LDDNE  CLOG 1,@FRESTA+1       Low byte odd?
[0967] C1BD 61,C1           BS   GC1C1
[0968] C1BF 91,08           DINC @FRESTA           Force to next even boundry
[0969] C1C1 BF,16,83 GC1C1  DST  FRESTA,@VARB          Source
       C1C4 08
[0970] C1C5 BF,00,20        DST  FSLOC,@VAR0           Destination
       C1C8 02
[0971] C1C9 BF,5C,00        DST  4,@ARG                Load 4 bytes
       C1CC 04
[0972] C1CD 0F,89           XML  MVUP              CPU RAM to ERAM
[0973] C1CF 06,C2,77        CALL CLSIT             Close file
[0974]               * Check for end of load command ")"
[0975] C1D2 D6,42,B6 LDNE2  CEQ  RPARZ,@CHAT       Check for ")"
[0976] C1D5 61,E1           BS   LDRET
[0977] C1D7 D6,42,B3        CEQ  COMMAZ,@CHAT      Syntax error
[0978] C1DA 45,30           BR   ERRSY1
[0979] C1DC 0F,79           XML  PGMCHR            Skip comma
[0980] C1DE 05,C0,4E        B    LDP1              Continue in main loop
[0981]               *************** LDRET - LDRET2 ****************************
[0982]               *
[0983]               * Return to calling routine
[0984] C1E1 0F,79    LDRET  XML  PGMCHR            Skip over
[0985]               * Entry point for INIT
[0986] C1E3 06,6A,78 LDRET2 CALL CHKEND            Check for end of statement
[0987] C1E6 45,30           BR   ERRSY1            If not end then syntax error
[0988] C1E8 06,00,12        CALL RPL               Return to caller
[0989]               ********************** CHKIN ******************************
[0990]               * Check for INIT-FLAG = >AA55
[0991]               * MOVE ERAM(INITF) to CPU *FAC
[0992] C1EB          PAGE   EQU  $
[0993] C1EB BF,00,83 CHKIN  DST  FAC,@VAR0         Destination
       C1EE 4A
[0994] C1EF BF,16,20        DST  INITF,@VARB       Source
       C1F2 06
[0995] C1F3 BF,5C,00        DST  2,@ARG            2 bytes
       C1F6 02
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0017
EQUATES ALCS-359
[0996] C1F7 0F,89           XML  MVUP              Move it
[0997] C1F9 D7,4A,AA        DCEQ >AA55,@FAC        Syntax error
       C1FC 55
[0998] C1FD 45,33           BR   ERRSYN
[0999]               * No files have been opened so if there is a syntax error
[1000]               *  goto ERRSYN!
[1001] C1FF 00              RTN
[1002]               *********************** FILE ROUTINES *********************
[1003]               ***********************************************************
[1004]               * INCREMENT BUFFER POINTER by value after call statement
[1005]               * ADD VALUES READ TO CHECKSUM unless the first character
[1006]               * is a "7" = >37 , then add only "7" character to checksum
[1007]               * (other value is the checksum)
[1008]               *
[1009]               *************************** LDIPCS ************************
[1010] C200 88,15    LDIPCS FETCH @INDEXC          Index = # of bytes read
[1011] C202 D6,B0,0E        CEQ  >37,V*BUFPNT
       C205 37
[1012] C206 42,13           BR   GC213
[1013] C208 A3,02,00        DADD >0037,@CHKSUM     Add value of "7" to checksum
       C20B 37
[1014] C20C A3,0E,00        DADD 5,@BUFPNT         1 for "7", 4 for checksum
       C20F 05
[1015] C210 05,C2,24        B    GC224
[1016] C213 BC,4B,B0 GC213  ST   V*BUFPNT,@FAC1    Convert to 2 byte value
       C216 0E
[1017] C217 86,4A           CLR  @FAC              -----------------------------
[1018] C219 A1,02,4A        DADD @FAC,@CHKSUM      Add char to checksum
[1019] C21C 91,0E           DINC @BUFPNT
[1020] C21E 92,15           DEC  @INDEXC           Do it index # of times
[1021] C220 8E,15           CZ   @INDEXC
[1022] C222 42,13           BR   GC213
[1023] C224 00       GC224  RTN
[1024]               ********************** OPENIT *****************************
[1025] C225 BD,0C,50 OPENIT DST  @FAC6,@BYTES      Store actual spec length
[1026] C228 A3,0C,00        DADD PABLEN+80,@BYTES  Add in the PAB length and
       C22B 5A
[1027]               *                              buffer length
[1028] C22C 0F,77           XML  VPUSH             Push possible temp string
[1029] C22E 0F,71           XML  GETSTR             and try to allocate space
[1030] C230 0F,78           XML  VPOP              Restore original string data
[1031]               *
[1032]               * THE FOLLOWING VARIABLES CONTAIN IMPORTANT INFO
[1033]               *
[1034]               *   FAC4, FAC5    Start address of original device specific
[1035]               *   FAC6, FAC7    Length of original device specifications
[1036]               *   SREF          Location of PAB in VDP memory
[1037]               *   BYTES         Length of entire PAB including specificat
[1038] C232 34,50,E0        MOVE @FAC6,V*FAC4,V@PABLEN(@SREF)
       C235 0A,1C,B0
       C238 4E
[1039] C239 86,B0,1C        CLR  V*SREF               Clear the entire PAB
[1040] C23C 35,00,09        MOVE PABLEN-1,V*SREF,V@1(@SREF)
       C23F E0,01,1C
       C242 B0,1C
[1041] C244 BC,E0,09        ST   @FAC7,V@NLEN(@SREF)  Copy specifications length
       C247 1C,51
[1042] C249 BE,E0,08        ST   >60,V@SCR(@SREF)     Screen offset
       C24C 1C,60
[1043] C24E BE,E0,01        ST   4,V@FLG(@SREF)       Dis, fix, seq, input
       C251 1C,04
[1044] C253 A1,50,1C        DADD @SREF,@FAC6          Calculate the address of
[1045] C256 A3,50,00        DADD PABLEN,@FAC6          the buffer
       C259 0A
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0018
EQUATES ALCS-359
[1046] C25A BD,E0,02        DST  @FAC6,V@BUF(@SREF) Store buffer address in PAB
       C25D 1C,50
[1047] C25F 06,C2,7B        CALL DSRCAL
[1048] C262 00              RTN
[1049]               ***********************************************************
[1050] C263 BD,0E,E0 READIT DST  V@BUF(@SREF),@BUFPNT   INIT buffer pointer
       C266 02,1C
[1051] C268 BE,B0,1C        ST   2,V*SREF
       C26B 02
[1052] C26C BC,E0,05        ST   V@LEN(@SREF),V@CHRCNT(@SREF)
       C26F 1C,E0,04
       C272 1C
[1053] C273 06,C2,7B        CALL DSRCAL
[1054] C276 00              RTN
[1055]               ************************* CLSIT ***************************
[1056] C277 BE,B0,1C CLSIT  ST   1,V*SREF          Prepare to close
       C27A 01
[1057]               ******************** DSRCAL - DSKERR **********************
[1058] C27B BD,56,1C DSRCAL DST  @SREF,@FAC12      Compute start address of spec
[1059] C27E A3,56,00        DADD NLEN,@FAC12       Ready to call DSR routine
       C281 09
[1060] C282 06,00,10        CALL DSR               Call DSR thourgh program link
[1061] C285 08              BYTE 8               * Type = DSR (8)
[1062] C286 62,90           BS   DSKERR            Couldn't find the DSR
[1063] C288 DA,E0,01        CLOG >E0,V@FLG(@SREF)  Set condition bit if no error
       C28B 1C,E0
[1064] C28D 42,90           BR   DSKERR
[1065] C28F 00              RTN
[1066] C290 BD,04,40 DSKERR DST  @FREPTR,@PABPTR   Set up dummy PAB
[1067] C293 A7,04,00        DSUB 6,@PABPTR         Make it standard size
       C296 06
[1068] C297 BD,E0,04        DST  V*SREF,V@4(@PABPTR) Store error code
       C29A 04,B0,1C
[1069] C29D 06,C2,A4        CALL CLSNOE              Close File
[1070] C2A0 06,6A,84        CALL ERRZZ               Issue I/O error
[1071] C2A3 24              BYTE 36              *
[1072]               ********************** CLSNOE *****************************
[1073]               * Try to close the current file
[1074]               * Ignore any errors from the closing of the file.
[1075]               * Since the PAB is not in the normal PAB list
[1076]               *  then we have to close the file in the load routine.
[1077]               * ERRZZ will close the rest of the files.
[1078]               *
[1079]               ** CLOSE IT ONLY IF IT HAS BEEN OPENED
[1080] C2A4 D7,02,00 CLSNOE DCEQ 1,@CHKSUM         Check file flag
       C2A7 01
[1081] C2A8 62,B9           BS   GC2B9
[1082] C2AA BE,B0,1C        ST   1,V*SREF          Store close file code
       C2AD 01
[1083] C2AE BD,56,1C        DST  @SREF,@FAC12      Compute start address of spec
[1084] C2B1 A3,56,00        DADD NLEN,@FAC12       Ready to CALL DSR
       C2B4 09
[1085] C2B5 06,00,10        CALL DSR               CALL DSR through program link
[1086] C2B8 08              BYTE 8               * "8" is type of DSR
[1087] C2B9 00       GC2B9  RTN
[1088]               ***********************************************************
[1089]               * INIT                        JDH   9/02/80
[1090]               ***********************************************************
[1091]               * Check if expansion RAM present
[1092]               * Load support into expansion RAM from GROM
[1093] C2BA 8E,80,84 INIT   CZ   @RAMTOP           If no ERAM, SYNTAX ERROR
[1094] C2BD 65,33           BS   ERRSYN
[1095]               ** Load Assembly header, support routines **
[1096]               * GKXB Correct INIT routine.
99/4 GPL-ASSEMBLER (Pass 3) correct                                   PAGE 0019
EQUATES ALCS-359
[1097] C2BF 31,04,EA        MOVE >04EA,G@ALCEND,@>2000
       C2C2 8F,9D,00
       C2C5 98,00
[1098] C2C7 05,C1,E3        B    LDRET2
[1099]               ***********************************************************
Missed this stuff in original post so have to edit this post:
[1624] C62D 0F,77    GKINIT XML  VPUSH        Save FAC
[1625] C62F 06,C1,EB        CALL CHKIN        Check for GKINIT
[1626] C632 0F,78           XML  VPOP         Restore FAC
[1627] C634 DA,80,C2        CLOG >C,@GKFLAG   Error if POKEG or POKEV
       C637 0C
[1628] C638 45,33           BR   ERRSYN
[1629] C63A 05,C2,25        B    OPENIT       Open the file
Just look at he freaking code and it shows the Assembly people did not know that GPL had the MOVE instruction or that requirements of CALL INIT before CALL LOAD
was implemented despite using CALL LOAD instead of a separate CALL POKE like everyone else in Basic or Extended Basic's!
It must have been extremely frustrating for the GPL to be forced to accommodate the Assembly people in measures like this.
I assume Assembly MANAGEMENT insisted on this ignorant short sided use of same CALL LOAD for both files and POKE.
And Miller Graphics also agreed with me on this BUG that created so many issues.
Why would you need to use CALL INIT if you wanted to CALL LOAD with just data into Expansion RAM anywhere in the RAM and use that RAM?
And you are right if the entire point is to hamstring the system users on purpose, goal accomplished.
Edited by RXB, Wed Jul 12, 2017 11:39 PM.
#16 apersson850 OFFLINE
apersson850
    Moonsweeper
  • 489 posts
Posted Thu Jul 13, 2017 1:49 AM
The point I was making is that it's not "whatever you want to call it".
A bug is something that doesn't work as intended. Period.
The behavior of CALL LOAD is clearly intended. By design. One can argue that it was anything from the right thing to do via a slight oversight down to downright stupid to not allow POKE, PEEK, POKEV and PEEKV in Extended BASIC, regardless of whether there is any memory expansion or not. But it's not a bug.
If you take a step back and look at what TI probably had in their mind, when they originally designed the TI 99/4, then it makes more sense. They came from the calculator division. They had been successful with the TI-59 and its software modules. They thought they'd make a super calculator, with a rather limited BASIC and pre-programmed modules for most everything they imagined people would otherwise.
It took them a long time to even come up with the Editor/Assembler package, as they thought software was better developed on a TI-990, using the DX10 assembler, than on the TI 99/4A itself. From that point of view, not allowing the user's to poke into memory unless they do intend to load assembly programs (they've executed CALL INIT) seems rather logical.
TI obviously didn't think too much about the exploring users, who want to dig into the interior of the system. Like you have done with Extended BASIC and I've done with the UCSD p-system. But there it was a bit easier, since the p-system wasn't designed by TI, but by people who actually thought you may want to port it to another computer system. Thus the internal architecture is described in good detail, and in documents that are published.
But it's not a bug. It's bad design choice.
#17 RXB OFFLINE
RXB
  • 3,021 posts
Posted Thu Jul 13, 2017 8:31 AM
OK BAD DESIGN, BAD CHOICE, BAD CONCEPT. Also pretty much non standard and goofy.
This reminds me of the old USSR that made 1.2 million left shoes and no right shoes as a management choice.
Edited by RXB, Thu Jul 13, 2017 8:34 AM.
#18 Casey OFFLINE
Casey
    Chopper Commander
  • 231 posts
Posted Thu Jul 13, 2017 4:19 PM
This discussion leaves me curious.  Extended BASIC with no memory expansion returns * SYNTAX ERROR for CALL LINK/LOAD/INIT/PEEK - yet it seems the code is in the Extended BASIC GROM and not added by the 32K memory expansion peripheral as it would seem.  It seems odd to me that the error handling would be such to return a syntax error on a statement that is legal.  If nothing else, why not a * NO MEMORY EXPANSION error message?   CALL LOAD is even worse.  It returns a syntax error until you've run CALL INIT.
Oddly, with Editor/Assembler in place, it's version of CALL LOAD does not require CALL INIT, but it's version of CALL LOAD also does not allow you to do CALL LOAD("CS1") where the one in Extended BASIC does.  Just strange to me they would behave differently.
#19 RXB OFFLINE
RXB
  • 3,021 posts
Posted Thu Jul 13, 2017 6:38 PM
YES! As one of the few GPL programmers I see this code and just shake my head in disbelief at how stupid this programming looks.
Really SYNTAX ERROR for CALL INIT and no Expansion RAM????
This is a logical standard?
Why Miller Graphics GRAM KRACKER XB fixed this and added CALL POKEV, CALL PEEKV and CALL POKE as an option to be a more logical standard.
#20 notwhoyouthink OFFLINE
notwhoyouthink
    Chopper Commander
  • 124 posts
Posted Thu Jul 13, 2017 9:44 PM
I'll just be as blunt as i can here: RXB, you are know gpl. Probably better then anyone else here.
Would it or would it not be possible to write a program (loaded from tape, with something like playground) that patches TI-XB to act like your Rich extended basic, that is, allow load without init?
That is, force the init, direct from gpl/assembly, then jump back to XB?
Edited by notwhoyouthink, Thu Jul 13, 2017 9:46 PM.
#21 RXB OFFLINE
RXB
  • 3,021 posts
Posted Fri Jul 14, 2017 2:55 AM
Unfortunately only way is to do something like Playground that exploits a bug in the TI99/4A.
This is first line of XB CALL LOAD in GPL and as you can see it just assumes CALL LOAD is ONLY for FILES!
Adding the later code for CALL LOAD to do a CALL POKE was clearly a afterthought, as was the idiotic idea that no one would ever use CALL LOAD for anything else?
What should happen is it looks for a string (path.file) and set the file flag,  if not string assumes it is a address POKE so does not need to set CHKSUM as no file loaded.
But instead it does 3 things wrong, first assumes only file access, second assumes init for file must be loaded before you can POKE a address, third says SYNTAX ERROR?
Unless you bypass the GPL code like RXB,  how would you get this to work?
Edited by RXB, Fri Jul 14, 2017 2:57 AM.
