Open source 3d printed shell for Ultimate Cart
ultimate cartridge cart 3d print sd multicart
30 replies to this topic
#1 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Thu Jul 13, 2017 10:04 AM
Hi all,
The original shell for my Ultimate Cart was a hacked Atari grey cart shell, which I spray painted blue. Unfortunately the paint has rubbed off a bit, and its now looking rather tatty.
So, now that I've got a 3d printer of my very own, I decided to design a shell for the Ultimate Cart. Like the rest of the project, this shell is open-source.
I've uploaded both the STL files and the design files (OpenSCAD) to the github site:
https://github.com/r...s/UltimateCart/
The shell should fit any PCBs produced using the board files on github. This should be most of the boards out there, with the exception of the redesign by Panos that he used for his later runs (but I think these came with nice shells anyway).
If you're not sure, compare your board to the pictures on github - if the connectors and screw holes are in the same places, it should fit.
The cart has been tested for fit in my 65XE, and 800XL. Flashjazzcat has been kind enough to test it for me in a XEGS, 800 and 1200XL, and reports it fits well.
If you don't have access to a 3d printer, I'm happy to make a few of these for others.
This would be using the same printer and filament colours (bronze & red) as the pictures above.
The price would be £22 + P&P (£1 to UK, £3 elsewhere).
Send me a PM if interested.
Robin
#2 Defender II OFFLINE
Defender II
  • 1,170 posts
Posted Fri Jul 14, 2017 1:07 PM
Is there anyone in the US that can print a couple for me in the same colors? Otherwise I'll need to order two from electrotrains.
Edited by Defender II, Fri Jul 14, 2017 1:08 PM.
#3 Fuji-Man OFFLINE
Fuji-Man
    Chopper Commander
  • 190 posts
Posted Fri Jul 14, 2017 1:11 PM
Hmm. Have printer, not those colors...
Edited by Fuji-Man, Fri Jul 14, 2017 1:11 PM.
#4 orpheuswaking OFFLINE
orpheuswaking
  • 5,833 posts
  • 1088XLD in progress
Posted Fri Jul 14, 2017 3:11 PM
Is there a cut out on the back for the programming header?
I'll also voice interest in a US based 3D printer owner running some of these up
#5 MrFish OFFLINE
MrFish
  • 5,474 posts
Nice looking case. It'd look good in gray, with that reddish-orange lettering, to match the XE's.
#6 poobah OFFLINE
poobah
  • 1,653 posts
Posted Fri Jul 14, 2017 6:41 PM
Time to fire up the printer and do a test print...
#7 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Sat Jul 15, 2017 1:07 AM
There is a recess rather than a cut out.
Robin
#8 Philsan ONLINE
Philsan
  • 3,886 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Sat Jul 15, 2017 4:18 AM
Awesome!
It would be nice other carts have a similar shell too!
#9 MacRorie OFFLINE
MacRorie
  • 1,045 posts
  • No matter where you go, there you are.
Posted Sun Jul 16, 2017 4:08 PM
I can do them in my array of colors.  I can match Robin's pricing.  Colors are attached.
#10 orpheuswaking OFFLINE
orpheuswaking
  • 5,833 posts
Posted Sun Jul 16, 2017 5:57 PM
Excellent MacRorie. I'll take a look at your colors
#11 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Tue Jul 18, 2017 9:31 AM
Many thanks for the files.  My first 3D printer should be arriving shortly and this would be a totally awesome thing to print after I get past my first set of adventures (disasters)  :D
#12 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Tue Jul 18, 2017 11:28 AM
You are welcome!
I'm sure you'll have great fun with your 3d printer - I'm really enjoying owning one.
But they do certainly require a lot of experimentation and learning what works. It's taken me several weeks to be able to reliably make cartridge shells with a perfect finish to the front and back faces.
Having said that, its probably easier to print other types of things where the first layer finish is not so important.
Robin
Edited by electrotrains, Tue Jul 18, 2017 11:29 AM.
#13 Larry OFFLINE
Larry
  • 4,109 posts
Posted Wed Jul 19, 2017 4:51 AM
Hi Robin-
You seem to have a printer that is quite capable, and has stamina to do quite a few projects. Could you share with us which one you bought? If doing it again, would you purchase the same brand?
-Larry
#14 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Wed Jul 19, 2017 5:45 AM
Hi Larry,
I bought a Wanhao Duplicator i3 v2.1. I think this is sold in the U.S. as the Monoprice Maker Select v2.
I'm generally very happy with it - I spent a long time researching 3d printers, and this seemed to be the best compromise between price and quality. If spending a bit more, and feeling a bit braver, I would have gone for an Original Prusa Mk2s kit - http://shop.prusa3d....i3-mk2-kit.html
I was really looking for something to produce enclosures for electronics projects, and other retro-computing projects. e.g. the Wanhao did a pretty fine job printing a SIO plug from thingverse:
https://www.thingive...m/thing:1831769
I've made the plug up into a cable which fits beautifully into an Atari and I was planning to build myself a new SIO2SD at some point, since my current one is a bit shabby looking.
Robin
#15 Philsan ONLINE
Philsan
  • 3,886 posts
Posted Wed Jul 19, 2017 8:38 AM
Robin, it would be nice a shell for Side2 cart.
I would buy it!
#16 poobah OFFLINE
poobah
  • 1,653 posts
Posted Wed Jul 19, 2017 5:40 PM
Hi Larry,
Robin
I have the 2.0 version of that printer, it is a good value, and lots of people making bits and pieces to improve it.
Adding diagonal braces, better bearings and a borosilicate glass bed really helped it make great prints
#17 Swami OFFLINE
Swami
  • 2,869 posts
Posted Wed Jul 19, 2017 9:49 PM
Not to derail, but while you are here...Up in the 7800 zone, I think some owners might like the option for a cart for the Concerto proto's that line the cart teeth up well with the port geometery, has openings for the micro-usb port and sd cart and on the front for the pokey chip. I like having the one that came with the Ultimate SD Cart.
#18 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Thu Jul 20, 2017 4:20 PM
Poor/nonexistent 3D skillset improving so I shall post my somewhat shabby in comparison picture.  First attempt (draft, ABS) went fairly well, programmed the extruder change myself for the badge text.  (yay!)
Not the colors I would have picked, but you get two random ABS spools for free and I got blue and that awful green :P
Sounded like a good idea, so I made that as my first 'useful thing' :)
#19 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Thu Jul 20, 2017 11:19 PM
Looks pretty good, though it doesn't seem to have printed the thin layer of plastic over the rectangle for the LED to shine through?
What printer did you get, if you don't mind me asking?
Robin
#20 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Thu Jul 20, 2017 11:23 PM
I got a sample of silver/grey PLA, so I took MrFish's suggestion, and printed one to match the XE colour scheme. I got lucky with the colour, since its very close - almost a perfect match depending on the angle and the light.
The LED doesn't "glow" so well through the thin window of plastic compared to the bronze colour, but I'm still pretty happy with it.
Robin
#21 remowilliams OFFLINE
remowilliams
  • 10,609 posts
Posted Fri Jul 21, 2017 9:25 AM
Robin
It actually did print with the thin covering but I removed it to see how it looked without it - it's better with it.
I went with the Flashforge Creator Pro.  I'm quite happy with it so far, its capabilities clearly exceed my competence.   :)
#22 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Sun Aug 13, 2017 1:23 AM
I've had a couple of messages confirming the design works well with MacRorie's initial batch of Ultimate Carts, so if anybody else wants a gold or silver one printed (as pictured above), just send me a PM.
Robin
#23 Fierodoug5 ONLINE
Fierodoug5
    Space Invader
  • 11 posts
Posted Wed Feb 27, 2019 6:08 AM
Anyone have the STL files for the front and back of this cart? Only the logo STL fiel was available on the github site.
Thanx
#24 _The Doctor__ OFFLINE
_The Doctor__
    Flux Capacitor Master Craftsman
  • 6,930 posts
Posted Wed Feb 27, 2019 6:19 AM
Robin
Not sure how I didn't see this earlier, I really like this.
#25 electrotrains OFFLINE
electrotrains
    Moonsweeper
  • 305 posts
Posted Wed Feb 27, 2019 6:43 AM
Thanx
Hi,
All the files are there - are you sure you are looking in the right place?
https://github.com/r...dge Shell Files
Robin
Also tagged with one or more of these keywords: ultimate, cartridge, cart, 3d, print, sd, multicart
