Game won't compile, can't figure out issue II: the electric boogaling
13 replies to this topic
#1 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Sun Jul 23, 2017 6:46 PM
Same issue as before, syntax error, can't figure out what's wrong, losing hair.
So this issue started when I added my win state code which goes as follows:
	rem red win state
	;goto _skip_win_state
	if scoring < 62 then goto _skip_win_state
		AUDV0 = 0
		AUDV1 = 0
		if scoring < 123 && scoring + 1 <= 122 then scoring = scoring + 1 : goto _skip_win_state
			scoring = 62
			if pfc + 2 > 78 then pfc = 64 : goto _skip_win_state
				pfcolors:
				pfc
 				end
				pfc = pfc + 2
		if scoring > 122 && scoring + 1 <= 182 then scoring = scoring + 1 : goto _skip_win_state
			scoring = 123
			if pfc + 2 > 158 then pfc = 144 : goto _skip_win_state
				pfcolors:
				pfc
 				end
				pfc = pfc + 2
Please ask any questions you'd need.
#2 kdgarris OFFLINE
kdgarris
    Chopper Commander
  • 236 posts
Posted Sun Jul 23, 2017 7:20 PM
Edit: As noted by RT below, the intermediate calculations were not part of the problem - it was only the indentation of the end statements.
You need to do intermediate calculations separately and not as part of your if statements.  Also, the "end" statement always needs to not be indented.  Here's the relevant section of code.  I commented out your if statements, and put my broken-up version of the same in the lines below.  It at least compiles for me with these changes.
		AUDV0 = 0
		AUDV1 = 0
;		if scoring < 123 && scoring + 1 <= 122 then scoring = scoring + 1 : goto _skip_win_state
                temp1 = scoring + 1
		if scoring < 123 && temp1 <= 122 then scoring = scoring + 1 : goto _skip_win_state
			scoring = 62
;			if pfc + 2 > 78 then pfc = 64 : goto _skip_win_state
                        temp2 = pfc + 2
			if temp2 > 78 then pfc = 64 : goto _skip_win_state
				pfcolors:
				pfc
end
				pfc = pfc + 2
;		if scoring > 122 && scoring + 1 <= 182 then scoring = scoring + 1 : goto _skip_win_state
        temp1 = scoring + 1
		if scoring > 122 && temp1 <= 182 then scoring = scoring + 1 : goto _skip_win_state
			scoring = 123
				pfcolors:
				pfc
end
				pfc = pfc + 2
Edited by kdgarris, Mon Jul 24, 2017 6:01 AM.
#3 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,507 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sun Jul 23, 2017 7:42 PM
Your program will compile if you just get rid of the indentations before end.
Make sure that you have the latest version of batari Basic and bblint and you will get error messages like these:
warning(299):    The "end" command appears to be indented.
warning(297):    missing matching end to "   pfcolors:"
warning():    Found 8 commands that use end,  and 7 "end" commands.
#4 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Sun Jul 23, 2017 8:31 PM
Hey thanks for the help, guys! It works now thanks to de-indenting the end statements, and it seems to work fine with intermediate calculations in the if-statements, but I'm wondering if that wouldn't work on real atari hardware.
But now how do I get the Playfield to chage color? Does pfcolors not work with variables? The ball is black for me
Also the Install batch file says I need setX.
Edited by 8-bit_d-boy, Sun Jul 23, 2017 9:35 PM.
#5 Random Terrain OFFLINE
Random Terrain
  • 28,507 posts
    Replay Value
    Nonlinear
Posted Sun Jul 23, 2017 10:56 PM
At one time, batari Basic wouldn't let us do any kind of math in if…then statements. That was changed over the years, but you still have to keep an eye on it.
But now how do I get the Playfield to change color? Does pfcolors not work with variables? The ball is black for me
I don't see any variables used here:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernop_pfcolors
Be sure to check out the warning at the bottom of that section.
RevEng said "install_win.bat requires SETX, which comes with Windows XP SP2 and later versions of Windows. If you don't have SETX on the system, the batch file will let you know and explain the situation."
#6 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Mon Jul 24, 2017 12:23 AM
Thanks for the help
Tried it without pfheights, same issue, oh well. I wanted it to change the playfield to the winner's color and cycle through the lumas, but guess not.
I'm aware of this, but I'm not sure where to get it.
Thanks again.
#7 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Mon Jul 24, 2017 10:09 PM
So I decided to change the background color to match the winner and have it cycle thru that color's luminances by one color every second similar to combat, but it seems to just stick to the one luminance value and I can't figure out why.
Any pointers would be helpful.
	rem -------------------------
	rem        WIN STATE
		AUDV0 = 0
		AUDV1 = 0
		COLUBK = pfc
		pfc = pfc + 2
		if missile0x > 110 then gosub red_win
		if missile1x > 110 then gosub blu_win
_skip_win_state
red_win
	if scoring > 122 then scoring = 62
	if pfc > 78 then pfc = 64
	return
blu_win
	if scoring > 182 then scoring = 123
	if pfc > 158 then pfc = 144
	return
#8 Random Terrain OFFLINE
Random Terrain
  • 28,507 posts
    Replay Value
    Nonlinear
Posted Mon Jul 24, 2017 11:59 PM
If I stick in "scoring = 62", the background flashes like crazy, not once every second.
#9 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Tue Jul 25, 2017 11:00 AM
Where did you put that? I tried putting that in line 301, but I'm not getting that result.
#10 Random Terrain OFFLINE
Random Terrain
  • 28,507 posts
    Replay Value
    Nonlinear
Posted Thu Jul 27, 2017 6:07 AM
I either put it right before the if then that checks for that or I put it in the main loop.
#11 Tony The 2600 OFFLINE
Tony The 2600
    Moonsweeper
  • 382 posts
  • 1.19 MHz
Posted Fri Aug 4, 2017 7:13 AM
By the looks of it to me the first instruction is a 'goto' statement "_skip_win_state" so basically any code following is ignored until the _skip_win_state label.
Edited by Tony The 2600, Fri Aug 4, 2017 7:59 AM.
#12 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Fri Aug 4, 2017 10:55 AM
You're a little late to this thread, pal.
#13 RevEng OFFLINE
RevEng
  • 4,742 posts
  • Bitnik
Posted Fri Aug 4, 2017 11:04 AM
Even though I didn't say so, I'm all set with this issue. Thanks anyway!
Fixed that for you.
#14 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Fri Aug 4, 2017 12:15 PM
Fixed that for you.
That's what I meant to say, thanks dude!
