PAL Antic / ROM Mod with Ultimate1MB
Xebec
Hey folks --
According to this, If you have a PAL ANTIC (in a NTSC machine), a ROM change will trick PAL software into working. (With some some timing/color issues as others have noted)
http://www.myatari.com/nirdary.html
"In order to "trick" software programs written for PAL machines to make the software think it's running on a real PAL machine, a minor modification of the OS is required. The required modification was very simple: I just changed address $C386 to be "1" instead of "0""
If I have an Ultimate 1MB Upgrade and a PAL Antic - can I literally just edit the bit at $C386 in a ROM and upload that to the U1MB? Or is there some ROM encoding I need to consider first?
Is C386 a hex address bit -- so I would go to position 50054 in the ROM file to make the change?
Thanks,
John H
Not sure... But IIRC the OS does a checksum check on powerup. If it does not match it jumps into ram/rom test in selftest.
I could be wrong... it has been quite a while since I modified OS ROMS... but I think it is true...
I don't think that's the case. I have a modified (padded out) version of OSb I use in my Ultimate 1MB for very rare instances when I need it; I've customized the Memo Pad header just a bit ... :)
The XL OS keeps a flag in Ram to signify Pal/NTSC. But the 400/800 OS doesn't.
I can't recall any 3rd party software that refers to it - the majority by far reads the PAL register on GTIA which in itself is flawed since it's Antic which determines if the system is 60/262 or 50/312.
IMO it's practically pointless changing the OS like that, and it will screw with the tape bitrate lookup (not a huge problem).
A benefit though is that it will correct the key auto-repeat which on a machine with PAL Antic/NTSC GTIA would otherwise slow down annoyingly.
Edited by Rybags
The order of the OS when in Rom files should be:
XL/XE
0000 - 0FFF corresponds to the OS normally living @ C000-CFFF
1000 - 17FF corresponds to the 2K Self-Test which switches in at 5000-57FF
1800 - 1FFF the FP Rom @ D800-DFFF
2000 - 3FFF the OS Rom @ E000-FFFF
400/800
0000 - 07FF FP Rom @ D800
0800 - 27FF OS Rom @ E000
