barry.peterson Posted August 1, 2017 Share Posted August 1, 2017 I doubt I'll splurge but have noticed 3D printers can be much cheaper than I had assumed, but the set-up seems finicky. AND, there seems to be a steep learning curve. Right? (My experience is generally that you get what you pay for...) Quote Link to comment Share on other sites More sharing options...
+remowilliams Posted August 1, 2017 Share Posted August 1, 2017 I'm new to the hands on/owner aspect of the 3D printing area, like two weeks new. The prices have come down quite a bit and you can can get quite a lot for your money these days. Unsurprisingly higher end gear is generally well, higher end - the feature set and capabilities you are looking at are going to determine the price. There is absolutely a large learning curve to do this correctly. Overall though I have found the process to be immensely rewarding and insanely frustrating at times. I am getting better though I can also see why people pay many thousands of dollars for self leveling printers now... Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted August 1, 2017 Share Posted August 1, 2017 (edited) I bought a chinese delta dual print-head printer.. off ebay.. kit so I had to assemble it, the manual was an exercise in frustration. It prints, but it was a pita to assemble and calibrate in fact I need to re-calibrate it. It also didn't come with a parts fan so I had to get a fan duct printed and attach that.. It's supposed to "auto level" but that part has been highly problematic so I just do it manually. Dual printheads really made my print area smaller as I couldn't reliably get them both to work, so I just use one.. Delta has a cool factor, but the print area is actually smaller than a xyz printer.. it's good for tall objects but not for wide ones.. If I do it again I'll just order a prusa, the print quality is much better and its stupid easy to set up and operate. Unfortunately they are more like 900$ and there's a multi-month waiting list for delivery. Like you said, you get what you pay for.. Greg Edited August 1, 2017 by arcadeshopper Quote Link to comment Share on other sites More sharing options...
mdilling Posted August 2, 2017 Share Posted August 2, 2017 I own both a delta printer (Sintron) and a cartesian printer (Anet A8). The delta printers, while they do have a wow factor are very finicky to keep dialed-in and printing properly. The cartesian printers are much easier to work with. I'd say once a week or so, I re-level my Anet and reset the z-axis height. This takes approximately 15-20 minutes and is easy todo, just tedious. You also have to spend some time dialing-in each new type of printer filament that you use - PLA, PETG, PPLA, ABS... . Overall, it is very enjoyable. Regards, Michael Quote Link to comment Share on other sites More sharing options...
