copper20 Posted August 1, 2017 Share Posted August 1, 2017 (edited) I was trying to get it to where my Xbox would close completely (if I pushed down on the top shell it would go down a little before) and when I screwed it all in, I found out the screws for the case pierced into the shell! Is there a way to cover the holes? Also the disc tray makes a popping sound when closing. AND it won't read discs very well anymore!! I really don't want to blow 45 dollars on another one, what do I do now?! Edited August 1, 2017 by copper20 Quote Link to comment Share on other sites More sharing options...
copper20 Posted August 2, 2017 Author Share Posted August 2, 2017 Sorry to double post but I got the thing reading discs again, but I still got the problem with the top shell not closing all the way... if I push down on it, it goes down a little still. So yeah, I'm in a sticky situation here... Quote Link to comment Share on other sites More sharing options...
RodLightning Posted August 2, 2017 Share Posted August 2, 2017 Original Xbox can be kind of a puzzle box to get back together. Try taking it apart and starting over. Space inside is tight by design. It sounds like the black plastic dvd drive bracket might not be seated properly. Go back in and inspect the power an ribbon cable to make sure nothing is binding. Ideally, you want to have the enclosure go back together with as little force as possible. I tend to look at teardown pictures as linked below when working on a console. It helps when trying to figure out what pieces go where and in what order, https://www.ifixit.com/Teardown/Xbox+Teardown/1308 As for screw piercing, are you using the original torx screws? The screws might be too long if they aren't the original. Quote Link to comment Share on other sites More sharing options...
copper20 Posted August 2, 2017 Author Share Posted August 2, 2017 (edited) I used the original screws - not sure what happened. But I have a broken screw post as well. Edited August 2, 2017 by copper20 Quote Link to comment Share on other sites More sharing options...
MNiceGuy Posted September 11, 2017 Share Posted September 11, 2017 The original Xbox is a little difficult to get back together. 1. Check to make sure all cables are tucked in where they should be. Specifically, make sure the ribbon is flat and the hard-drive power cables are tucked nicely in their little channel. 2. Look at the metal shielding on the lid. You will see some 'tabs' around the perimeter; specifically a long row at the back. Slowly lower the lid to the bottom and make sure these tabs are going where they're supposed to. From memory (i.e. don't take this to the bank), I believe the rear tabs slide to the interior of the bottom metal shield. 3. While looking at the front, there are plastic tabs on the ride side that can be problematic. Make sure those are going where they need to go as you lower the lid down. Hope that helps. If you're still stuck I can take a look at one of mine when I get home. Quote Link to comment Share on other sites More sharing options...
